Even updated to latest firmware (lens and camera), Eye AF is still limited
Started Oct 23, 2017 | Discussions
huremics Regular Member • Posts: 281
Using the A7rii in AF-C with the 85mm GM 1.4, Sony/Zeiss 35mm 1.4, and Sony/Zeiss 55mm 1.8, with all firmare updated for both camera and lenses, I find Eye AF to be quite limited. When shooting even at 1.4 or 1.8, I observe the following:
- Eye AF does work in scenarios with: lots of light, a subject whose head is straight and who is looking directly at the camera with both eyes open. The most "vanilla" or conventional shooting conditions possible.
But only about 50% of my portraits are like that. Beyond that, Eye AF falls down for me in virtually every other situation.
I find it especially frustrating it's not possible to easily toggle between eyes to focus on. Bizarrely, the Eye-AF function likes to select an eye that has hair or some other thing partially covering it, and not the other eye that is completely visible.
I very much hope that Sony can refine this feature and make Eye-AF a lot more flexible and capable in finding the eye in a greater variety of shooting situations.
Is this the experience others are having with the Eye-AF feature? Are there any suggestions folks have, who find the feature to be more adept at working in a greater variety of shooting situations?
rogerjosem
rogerjosem Senior Member • Posts: 1,775
Re: Even updated to latest firmware (lens and camera), Eye AF is still limited
I don´t have the A9, but I would really like a solution to enable forcing eye-AF to select the eye you want in the A7RII too...
 rogerjosem's gear list:rogerjosem's gear list
Sony Alpha a7R III Carl Zeiss Apo Sonnar T* 2/135 Zeiss Otus 1.4/55 Zeiss Otus 85mm F1.4 Sigma 20mm F1.4 DG HSM Art +13 more
OP huremics Regular Member • Posts: 281
I also find that, if only a single eye is visible, then the Eye-AF rarely works.
It seems like the engineers created Eye-AF to require two eyes being almost exactly level and mostly facing the camera directly in order to work. This is very limiting for more dynamic and creative shoots.
kilofox Contributing Member • Posts: 516
Unless you are doing a headshot or similar with a shallow depth of field.. then why even bother with Eye AF when Face Detect will do?
 kilofox's gear list:kilofox's gear list
Sony RX100 III Sony a9 Sony Alpha a7R III Sony FE 55mm F1.8 Sigma 50mm F1.4 DG HSM | A +7 more
Shooting at 1.4-2.0 it's nicer if the camera can focus directly on the eye, instead of having the nose sharp and the eyes blurry.
Yes, I do shoot manually sometimes, but that's a very slow process and sometimes when shooting with models, a more dynamic tempo yields more emotion and expressiveness.
