Canon 4K MJPEG video for stills saved my day
Started Oct 21, 2017 | Discussions
Myrgjorf Regular Member • Posts: 457
6
Many has criticized Canon for using MJPEG for 4K on their DSLRs. I am a fan of having MJPEG as an option for getting high quality stills out of a video stream and yesterday that feature saved my photos. I think many posters here do not recognize the value of Canon's 4K implementation for stills in special situations.
I went to a sea battle event yesterday where I first tried to get ordinary photos. But of cause I couldn't get the timing with the cannons right. So I switched to 4K video and extracted the stills as JPEG and PP'ed in PS with some highlight reduction, shadow lift and foreground / background noise reduction. The JPEGs of cause had less headroom and DR for PP than RAWs but I am pleased to have that option when RAW is not an option.
I think you should consider 4K MJPEG before your next purchase.
- Bjarne
After extracting stills from MJPEG and some PP I got these pictures for my own private usage
The frigate is the beautiful Russian "Shtandart" sailing under Danish flag at this event
We had a lot of rain affecting the colors and the mood of the pictures
 Myrgjorf's gear list:Myrgjorf's gear list
Sony RX100 Olympus TG-5 Canon EOS-1D X Mark II Canon EOS M50 Canon EOS R5 +20 more
rxb dc Senior Member • Posts: 2,103
Re: Canon 4K MJPEG video for stills saved my day
Nice photographs and I agree, mjpeg is sometimes the way to go.
I have used mine for hummingbirds but rolling shutter seems to be an issue, less so for your example. I used M so I could set a higher shutter speed.
And just to note - sometime a 4mpix image with the right subject  is better than a 30mpix image of nothing
- Bjarne
Safety Warning: Bad taste unmitigated by moderate skill
 rxb dc's gear list:rxb dc's gear list
Canon EOS 700D Canon EOS 7D Mark II Canon EF 50mm F1.8 II Tamron SP 150-600mm F5-6.3 Di VC USD Canon EF-S 10-18mm F4.5–5.6 IS STM +9 more
hotdog321
hotdog321 Forum Pro • Posts: 21,044
Good post and great information. Thanks!
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
gimp_dad Senior Member • Posts: 2,415
Agreed. Also, 4k is 8MP but doesn't change your point.
Personally I don't get the concern about mjpeg. It's effectively all I-frames and many complain about not having an all I-frame mode with the 6D2.
Not staying I would never use a top quality H.265 format but if I could only record one format at time I would always choose mjpeg over H.265 for the flexibility. A $3000 camera (or $7000 for the 1DX2) and several $k in lenses and people quibbling about a couple of extra cheap flash cards.
- Bjarne
Alexsfo Senior Member • Posts: 2,358
Frame grab work well if there is not much movement. Typical shutter speed for 30p would be 1/60s which does not gurantee frame grab w/o motion blur. 100-150 mbps H264 should provide similar quality 8MP frame grab. Canon uses mjpeg codec because it doesn’t overheat the camera at all, pretty much no compression.
 Alexsfo's gear list:Alexsfo's gear list
Canon EOS 5D Mark IV Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM Canon EF 24-70mm F4L IS USM +4 more
OP Myrgjorf Regular Member • Posts: 457
This thread is not about grapping frames from a video stream optimized for video but grapping high quality JPEG stills from a video stream optimized for stills. You can select shutter speed for you still need (within the video FPS limit). In this case I used 1/25s in a 25 FPS video because of the lightning condition. You wouldn't normally do that for pure video.
Canon 4K MJPEG effectively gives you a 25 - 60 FPS 8.8 MP JPEG camera for special use cases. That is what I want.
No, H.264 is optimized for video, not for stills. JPEG is optimized for stills, not for video. JPEG will have a better IQ for each still than H.264
So JPEG is not compressed! Compression is the purpose of JPEG. But MJPEG has no cross-frame video compression. And of cause the output stream is much larger with MJPEG than with H.264 but that is only a minor issue in this use case.
Yossarian1
Yossarian1 Regular Member • Posts: 328
Thanks for this post.  I wondered how effective the frame grabbing was out of the 4K.  I am impressed.
 Yossarian1's gear list:Yossarian1's gear list
Canon EOS 5D Mark II Canon EOS 5DS Canon EOS 80D Canon EOS M50 Canon EOS R6 +16 more
