Ricoh GR II + GW-3: Feed for pixel peepers
Started Oct 19, 2017 | User reviews
CyeJoeBob Forum Member • Posts: 74
So far, I couln't find full res image samples of the Ricoh GR with GW-3 wide angle converter. So here they are with a short analysis. All processed with LR 5.7 - standard setting with highlight/shadow adjustments.
My analysis:
Center: Almost no loss of sharpness.
Middle: Definitly a bit less sharp, but not much.
Corner: Definitly less sharp and some CA. But nevertheless an excellent performance for a convertion lens.
Flare: Quite resistent against the sun. More prone to flares when the sun comes from the side. The tiny lens hood doesn't help here.
14mm w/ converter
18mm w/o converter
 CyeJoeBob's gear list:CyeJoeBob's gear list
Sony a7 III Tamron 17-28mm F2.8 Di III RXD Sony FE 35mm F1.8
CyeJoeBob's score
4.5
Ricoh GR II
borderplatz Regular Member • Posts: 297
Re: Ricoh GR II + GW-3: Feed for pixel peepers
yes, my converter always suprises me, really like getting close, I use my xpro2 for awhile, then always come back to my GR2, great shots
Csetoue New Member • Posts: 16
Wonderfull shots.
Im wondering if i get one of these!
Overall do you think its worth?
OP CyeJoeBob Forum Member • Posts: 74
It depends of what you are doing with your Ricoh GR. I think you won't use it very often for street photography. But it's great for landscape and your next sightseeing tour.
And I can't think of any 21mm lens that cheap and with such a great performance at the same time. So I would say it's a no brainer, especially if you can get a used one for less than 100$/€.
I think I will get one of these.
Actually, I'm a bit concerned about having a lot of gear...
After I got my Ricoh GR, Im almost not touching my big dSLR anymore. I don't know if it's good or bad, but all my expenses on my big dSLR and its lenses are collecting dust.
I also thought in selling my GR, buying a better smartphone to take OK photos (not GR like, cause it's impossible), and trying to not ruin my investments on my dSLR stuff and taking it for a walk once a while.
The most probably decision is buying everything and keeping everything.
