New (to me) panorama-making technique! (from Moosehead Lake, Maine)
Started Oct 17, 2017 | Discussions
Cynthia FarrWeinfeld
Cynthia FarrWeinfeld Veteran Member • Posts: 4,887
So this panorama gave me the very devil of a time putting it together! I took it handheld, standing on a dock, at 85 mm, and Photoshop CC repeatedly told me I hadn't overlapped the images enough for them to have workable information. Error, error, error! So I finally hit on this fix: Align all the images manually in a white "new document" that you create. Then select ONLY the images you want to blend (not the white document) and do Edit > Auto-Blend and toggle both the options within the Panorama menu and let 'er rip! Then it may say there is an error of some sort, but I ignored that, and flattened it. There were jagged white sections on the top and bottom b/c obviously I am not too great at taking a 180 degree pano while standing on a moving dock without a tripod! Haha! So I used the Magic Wand Tool in the tool bar, clicked in the white area, and selected the Fill > Content-Aware Fill option and once again, let 'er rip! Voila! Make sure you click on it to see it larger. And you can see it much larger here: https://cfwphotography.smugmug.com/Portfolio/Landscape-Nature/Moosehead-Lake-Region/
These are a few of the other panoramas that PS CC "liked'"
This is one of the side docks off of Wilson's of Maine on Moosehead Lake.
This is my favorite from the whole trip, for panoramas. . .  Once again, handheld. . .
This one is kind of weird, TBH. . .  But the colors were beautiful, so I kept it. . .
Thanks for looking!  Cindy
Cindy Farr-Weinfeld, Maine Landscape Photography
CFW Photography
http://www.cfwphotography.smugmug.com
 Cynthia FarrWeinfeld's gear list:Cynthia FarrWeinfeld's gear list
Pentax K-3 Nikon D750 Pentax K-3 II Nikon AF-S Nikkor 24-70mm f/2.8G ED Pentax smc FA 50mm F1.4 +7 more
OP Cynthia FarrWeinfeld Veteran Member • Posts: 4,887
Length of the first panorama, just for your info. . .
Forgot to mention that that first pano that I had so much trouble with has a native length of 75 inches!
CFW Photography
Younes B Senior Member • Posts: 1,257
Re: Length of the first panorama, just for your info. . .
Very nice set. Wonderful coors.
I don'T go in all your troubles when doing panos. I just use LR 6, which has a pano made ( you select the pictures, LR does all the rest..).
The only tip I have for the time of shooting is to shoot manual, in order to keep same exposure for all scnes ( you don'T want the camera to re meter while you change its position for next picture ). All focus set to infinity...( manually ).
Good job
 Younes B's gear list:Younes B's gear list
Pentax K10D Pentax K-30 Pentax K-5 II Pentax K-5 IIs Pentax smc DA 15mm F4 ED AL Limited +6 more
Yes, it was shot in manual, honestly.  The values were as "same" as they could be, however it was a 180 degree pano, stretching across the lake, from the side where the sun wasn't shining to the side where it was shining, hence it being brighter on the right side, as it should be.
I normally put panos together in PS CC using the Automate command, as everyone else does.  However, as I mentioned in my piece, I didn't overlap enough, shooting at 85 mm, and therefore, PS refused to put it together the traditional way.  So I resorted to this "when all else fails" kind of technique, which worked quite nicely.
Thanks for the kind words!
Cindy
Good job
CFW Photography
SoCalWill
SoCalWill Veteran Member • Posts: 6,299
Re: New (to me) panorama-making technique! (from Moosehead Lake, Maine)
Fun stuff, don't forget the pan-head tripod to simplify these shots. And mind the tint:
Digital Camera and Adobe Photoshop user since 1999.
Adobe Lightroom is my adult coloring book.
 SoCalWill's gear list:SoCalWill's gear list
Sony RX100 III Nikon D810 Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 50mm F1.4 DG HSM | A Apple iPhone XS Max
flektogon
flektogon Veteran Member • Posts: 6,226
They are all great, but the last one is simply amazing!
Peter
I actually CHOSE the tint.  Nothing wrong with handheld panos either.  This one went together just like this, without any straightening at all.
CFW Photography
Thank you so much, Peter!  Cindy
CFW Photography
DDoram
DDoram Forum Pro • Posts: 10,365
Nice work Cynthia; thanks for the info on the fix.
Dale
 DDoram's gear list:DDoram's gear list
Sony RX10 IV Pentax K-1 OM-1
Thanks Dale!  Cindy
Dale
CFW Photography
Gman58 Senior Member • Posts: 2,934
#2's a gem Cynthia. You did well with all these.
 Gman58's gear list:Gman58's gear list
Pentax K-5 II Pentax KP Pentax smc FA 50mm F1.4 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA 21mm F3.2 AL Limited +4 more
LightBug Senior Member • Posts: 2,818
Gorgeous fall colors!  Thanks for sharing these beautiful panoramas!
Joey
 LightBug's gear list:LightBug's gear list
Pentax 645Z Pentax Q-S1 Pentax KP Ricoh Theta V Pentax smc DA 15mm F4 ED AL Limited +19 more
Thank you so much!  Cindy
CFW Photography
Thank you, Joey!  Cindy
Joey
CFW Photography
