X-T2 not saving RAW/JPG
Started Oct 9, 2017 | Discussions
cybersimba
cybersimba Senior Member • Posts: 1,724
I recently tried this mode but my X-T2 saves Raw/Raw on both cards. Any ideas about any settings I could be missing?
thanks,
-Cybersimba
Its all about light
http://www.sachinsawephotography.com
 cybersimba's gear list:cybersimba's gear list
Sony a9 Sony a1 Sony a7R IVA Sony FE 90mm F2.8 macro Sony FE 85mm F1.8 +12 more
Fujifilm X-T2
cybersimba
OP cybersimba Senior Member • Posts: 1,724
Re: X-T2 not saving RAW/JPG
I found the answer to this question myself. Posting it here in case anyone else comes across same issue. I had set the Image Quality to RAW and that made it save Raw to both cards. I had to select Image Quality Fine + Raw OR Normal + Raw. In that case, it saves Raw to one slot and JPG to another.
thanks,
-Cybersimba
Its all about light
Exit10 Senior Member • Posts: 2,264
thanks,
This is interesting - although its not an option I ever choose.
I would have assumed that you would have to choose Backup to get the files written to both cards but apparently not.
 Exit10's gear list:Exit10's gear list
Canon EOS Rebel T6i Fujifilm X-T3 Canon EF 200mm f/2.8L II USM Canon EF 24-105mm f/4L IS USM Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
cybersimba
Exit10 wrote:
thanks,
yup. not the most intuitive
-Cybersimba
Its all about light
michaeladawson Forum Pro • Posts: 18,315
Exit10 wrote:
thanks,
"Backup" is exactly what the word means, it writes the same files to both cards so that you have a backup.  If you have the camera set to raw + jpg and choose backup you get both raw and jpg files written to both cards.  You wouldn't choose backup if you wanted raw on one card and jpg on the other.  Seems intuitive enough to me.
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Nikon D7200 Nikon D5 Fujifilm X-T2 Nikon D850 Fujifilm X-E3 +39 more
cybersimba
michaeladawson wrote:
Exit10 wrote:
thanks,
I wasn't talking about word "Backup" not being intuitive. Please look at my original post and the solution I found. It wasn't intuitive to me that when I choose Raw/JPG mode that I have to select image quality to be Raw + Fine or Raw + Normal. I would think even if I choose Image quality as just RAW... the 'saving" mode as Raw/Jpg should simply override image quality and save jpegs on second card rather than my having to select image quality explicitly as Raw+Fine or Raw+Normal. Now that is not intuitive enough for me.
-Cybersimba
Its all about light
Exit10 wrote:
thanks,
And even stranger that it should write raw to both cards - even though you haven't selected backup
cybersimba
Exit10 wrote:
Exit10 wrote:
thanks,
exactly. in that case it is behaving as a "backup" though you did not select that option for 'saving' files
-Cybersimba
Its all about light
Peter Foiles
Peter Foiles Senior Member • Posts: 2,389
Exit10 wrote:
thanks,
I didn't understand your OP but now I see the problem. The one and only place you choose to save RAW + JPEG is in the image quality menu, as you note raw+fine or raw+normal. The Raw/JPG you see in the save data setup is not a "mode." To the extent there is such a thing it is set in the image quality menu. You will notice that there is a "/" not a "+" in the save data menu. The "/" indicates that you save raw to the first slot and jpg to the second. If one wanted to save raw+jpg it never occurred to me (or apparently Fuji) to go anyplace other than the image quality menu. So if you want raw + jpg you set that in image quality then in the save data menu you can choose where you want those files saved. Seems a logical straightforward arrangement to me.
 Peter Foiles's gear list:Peter Foiles's gear list
Sony a1 OM-1 Fujifilm X-H2S Fujifilm X-H2 Sony a7R V +23 more
cybersimba
Peter Foiles wrote:
Exit10 wrote:
thanks,
Not really because when you say Fine + Raw or Normal + Raw... the notion of saving those applies even to camera bodies with one card. So its not logical or intuitive in my mind that that is somehow tied to two card saving logic. I mean I would have not intution that hey if I don't select Fine + Raw then for "two card" saving logic Raw/Jpg won't work. If on the other hand its taught to the user that "Fine + Raw" option applies only for bodies with two cards then its understandable to make that a logical statement that hey don't you know that if you don't select Fine + Raw that Raw/Jpg won't work.
makes sense why I say its not intuitive?
-Cybersimba
Its all about light
I'm sorry, but no.  I don't know what to say.  It works the same way on my Nikon cameras.  Maybe because I have used Nikon dual slot bodies for so long before picking up a Fuji it all made sense to me.
Mike Dawson
Rectify Forum Member • Posts: 88
There are two separate settings in two separate menus that control these functions.
In the I.Q. Menu, select raw, normal jpeg, fine jpeg or a combination of raw + a jpeg mode.
in the Setup Menu under the Save Data Setting, choose how to use the two cards. As sequential, backup, or raw/jpeg where the raw files are stored on Card 1 and the jpeg files on card 2.
Once you understand the separate settings it should start to make sense.
Hope this is helpful.
Randy
 Rectify's gear list:Rectify's gear list
Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 16mm F1.4 R WR
Ron J Handy New Member • Posts: 4
thanks,
Fantastic answer. Such a simple thing once you get shown but I was tearing my head out until I found your solution.
Many thanks, and Happy New Year for 2023
cybersimba
Ron J Handy wrote:
thanks,
haha, funny how we all land up on some old threads and find our answers. That has happened to me to. Glad what I shared was useful to you. Happy New Year 2023 !!
-Cybersimba
Its all about light
https://www.instagram.com/sachinsawephotography/
