Godox TT350F
Started Oct 9, 2017 | Discussions
elfroggio
elfroggio Veteran Member • Posts: 3,228
Re: Godox TT350F
retroactivity wrote:
One thing for certain, Godox support is a myth.
Yes. It's cheap, they have to cut costs somewhere.
But if you buy the flash under the Adorama Flashpoint brand (in the US), just a repackage, you would get fairly good support.
http://www.sritch.com
The Dogs of Vancouver, BC
Rijodel New Member • Posts: 2
Re: Godox TT350F
I have a Fuji X-E4 and the Godox TT350F doesn't work because, according with the X-E4 (pag 146) when the camera is setting to electronic shutter, you cannot use an external flash. Then I turn the shutter to mechanical or Mechanical+electronic and the Godox works fine!
GMacF Contributing Member • Posts: 999
Re: Godox TT350F
I may be wrong but I’m nearly sure no flash works with electronic shutter on any Fuji camera.
 GMacF's gear list:GMacF's gear list
Fujifilm X-E3 Fujifilm X-H2S Fujifilm X-T5 Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +9 more
