Should I buy a Canon EOS Rebel T5 DSLR (only with kit lens), or a Canon Powershot S540 (non intercha
Started Oct 9, 2017 | Questions
ivyphoto New Member • Posts: 1
I am looking to buy a camera and I'm having a hard time choosing either the Canon EOS Rebel T5, (comes with kit lens 18-55 mm), or this Canon Powershot S540 (non interchangeable 24-1200mm lens). I want to be able to take good portraits, but once I buy the DSLR, I have to stick with the kit lens and my budget does not allow me to buy another lens. But in the long run, I'm afraid that the powershot will be outdated in a couple of years and it doesn't have interchangeable lenses, and I think the DSLR will be useful in the future when I earn more money to buy lens. But then I'm going to be stuck with the 18-55 mm lens for a while. So which should I buy?
Canon EOS 1200D (EOS Rebel T5 / EOS Kiss X70)
T_Van Forum Member • Posts: 84
Pick what you need
If you are looking to take photos for fun, then the p&s would do.  The benefit of the dslr with the larger sensor would ideally be the shallower depth of field when paired with a large aperture lens.  Downside is large size of camera, more post processing work, and changes in lenses.
So depends on what you want from photo experience  you can pick whichever camera as a tool. There are always 2nd hand DSLRs as options too.
“You don't make a photograph just with a camera. You bring to the act of photography all the pictures you have seen, the books you have read, the music you have heard, the people you have loved.”
- Ansel Adams
 T_Van's gear list:T_Van's gear list
Canon ELPH 300 HS Canon EOS 1000D Pentax *ist DL Pentax K200D Pentax K-5 II +1 more
Dimi Koan
Dimi Koan Junior Member • Posts: 26
Re:
The key benefit from a large sensor is the ability to shoot in lower light.
HorHey9000 Regular Member • Posts: 104
Re: Should I buy a Canon EOS Rebel T5 DSLR
You'll still get better bokeh with the DSLR and kit lens over the super zoom due to the DSLR having a larger sensor so your portraits will look better with the DSLR. Plus you'll also get the other benefits of having a larger sensor.
 HorHey9000's gear list:HorHey9000's gear list
Canon EOS 80D Canon EOS Rebel SL2 Canon EF 24mm f/1.4L II USM Canon EF 50mm f/1.2L USM Canon EF 70-300mm f/4-5.6L IS USM +2 more
davev8
davev8 Veteran Member • Posts: 4,837
OR SL1
welcum to the forum
if you was going to do a bit of everything on  a tight budget i would say  the s540 (or similar} this type of camera tends to be a jack of all trades but master of fuw ....
however you mentioned portraiture that a different kettle of fish
you mentioned the T5   or 1200D in the UK ...the T5 is a VERY stripd out camera and not so good value
have a look at the SL1 /100D...in the UK   the SL1 was cheaper than the T6 was at launch  and the SL1 out spects it in every way never mind the T5
the SL1 normally comes with a much better STM 18-55 IS lens ..some lenses i see with the T5 are not even image stabilized .. the SL1 gets you  canons VERY good touch interface,  auto sensor cleaning,,a slightly better sensor ,much better LCD ,bigger viewfinder ,much better LV/video AF, bigger buffer (12 vs unlimited jpeg)  faster FPS ,better build, external mike jack .spot metering....SL1 has the Digic 5 processor as opposed to the Digic 4 of the T5....this should make the SL1 a bit more snappy to use    and its still the world's smallest DSLR
when funds permit if you do portraiture the 1st lens to get is the 50mm F1.8STM  $125 new or less S/H on ebay or gray market
a DSLR and a 50mm stm will be in entirely different league compared to the S540 for partairture
My 5D IS a MK1 classic
There is no argument for FF vs APS-c (or m43) with shallow DOF..as it's a law of physics and a very subjective personal thing if you want to make use of the shallow DOF only FF can offer
You are joking ....i have a sony nex ...i think the designers was an anti photographer sadist ...the only way to make it more less enjoyable to use would be to superglue a drawing pin to the shutter button...pin up
 davev8's gear list:davev8's gear list
Canon EOS 5D Canon EOS R6 Canon EF 50mm F1.4 USM +5 more
R2D2 Forum Pro • Posts: 26,551
Re: OR SL1
+ 100 to all of this (incl the "welcome to the forum" bit)
Here's what the Canon Refurb site has to offer right now...
SL1 deals
R2
davev8 wrote:
welcum to the forum
CPFan
CPFan Regular Member • Posts: 202
Re: T5 DSLR (only with kit lens), or a Canon Powershot SX540
First, I can't find an S540, so presumably you mean an SX540 (which is 24-1200).
Second, you made no mention of needing the telephoto reach, so it's difficult for me to recommend the SX540. Also, I'm a telephoto junkie, and I wouldn't buy the SX540 for myself because I think that long a reach is difficult to use. The lenses that I primarily use are 55-250mm and 18-250mm. On an APS-C camera like the T5 (and my cameras), that's about 400mm, and starting to get very difficult to handhold. My SX210 is 28-392 equivalent and I find it hard to handhold at the high end.
My recommendation...get a decent body and the EF-S 55-250mm STM lens. This lens is recommended by many, and should be fine for portraits at the low-end, and provides some telephoto reach at the high end. The lens is more important in many ways than the body.
Steve
 CPFan's gear list:CPFan's gear list
Canon PowerShot SD600 Canon PowerShot S5 IS Canon PowerShot SX210 IS Sony Cyber-shot DSC-QX10 Canon PowerShot SX620 HS +8 more
MikeJ9116 Veteran Member • Posts: 6,958
Get a DSLR with the EF 50mm STM lens (both refurbished)
You can buy the EF 50mm f/1.8 STM prime from Canon's refurbished web site for $90 and it will make for an outstanding portrait lens on a Canon DSLR. My advise is to forget about buying any cheap point and shoot cameras.
https://shop.usa.canon.com/shop/en/catalog/ef-50mm-f-18-stm-refurbished
Re: Get a DSLR with the EF 50mm STM lens (both refurbished)
Thats actually a great idea.
robbo2 Contributing Member • Posts: 987
For portraits with blurred backgrounds, the DSLR will do better. If you just want to have one camera to carry around and which probably has easier wireless xfer of pictures to your cellphone, the superzoom is probably better.  If you can hold off until Black Friday, you might get a better deal, especially on refurbs.
 robbo2's gear list:robbo2's gear list
Sony RX10 IV Panasonic Lumix DC-G9 Panasonic G95
deanimator Contributing Member • Posts: 719
Re: Should I buy a Canon EOS Rebel T5 DSLR, or a Canon Powershot S540 (non intercha
It depends entirely upon what your current and anticipated needs are.
For ME, any non-interchangeable lens camera is of no use at all.
If you buy a DSLR, you might not be able to upgrade the lens NOW.
With the fixed lens camera, you won't be able to upgrade EVER.
If that doesn't matter, buy whichever you prefer.
If it does, buy a DSLR.
