Flash that works with DP2x?
Started Oct 8, 2017 | Questions
Meomaxy Junior Member • Posts: 45
This is sort of a basic question. I haven't tried mounting an external flash on my DP2x. The manual describes the Sigma EF-140 as having TTL which makes it work together with the camera to get the exposure right. Are there other flashes that work that way with the camera too?
 Meomaxy's gear list:Meomaxy's gear list
Nikon D300 Nikon D500 Sigma 17-50mm F2.8 EX DC OS HSM Sigma 50-150mm F2.8 EX DC APO OS HSM +1 more
Sigma DP2x
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Re: Flash that works with DP2x?
On my DP2s, I use a Metz mecablitz 20 C-2. GN 20 and tilt head as opposed to the EF-140's 14 and fixed.
No TTL though, I'm not into auto-anything . .
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
danski0224 Senior Member • Posts: 1,465
The flash would need SA-TTL, Sigma compatible TTL metering.
Unless you are able to find another brand of flash that is compatible with Sigma TTL metering, I suspect that Sigma OEM flashes are it.
The Sigma hotshoe pinout on top of the camera is the same as Canon, so any Canon-compatible extension cords will work to move the flash off-camera.
Radio-control flash triggers (should) work, but everything will be full manual.
Moments in Time, a work in progress.... https://www.flickr.com/gp/142423236@N08/965cs3
PCummins Regular Member • Posts: 209
I've heard Cactus with the V6 II can convert Sigma SA-TTL to other systems so worth having a look here: https://www.cactus-image.com/special/X-TTL/
I've used the Yongnuo RF-603C II's fine with the Sigma cameras for manual flash triggering, typically you would pair with the YN-560 III or IV or YN-560-TX. As danski0224 says, you would get the Canon model to be pin compatible.
khunpapa
khunpapa Senior Member • Posts: 2,666
The DP series uses the in-lens leaf shutter.
You can use any shutter speed with flash of any brand!
Try it and be startled!
Flashes of my Memory.
 khunpapa's gear list:khunpapa's gear list
Sigma DP2 Sigma DP3 Merrill Olympus E-M1 Panasonic Lumix G X Vario 35-100mm F2.8 OIS Sigma DP1 +10 more
