Question?Is The Fujifilm FinePix S5 Pro 12.3 MP Better than the new Canon DSLR Cameras?
Started Oct 7, 2017 | Questions
Dean66
Dean66 New Member • Posts: 21
No text.
 Dean66's gear list:Dean66's gear list
Fujifilm FinePix S9100 Fujifilm FinePix IS-1 Fujifilm X-T30 Fujifilm XF 56mm F1.2 R Fujifilm XF 50-140mm F2.8 +1 more
Aoi Usagi Veteran Member • Posts: 3,224
Re: Question?Is The Fujifilm FinePix S5 Pro 12.3 MP Better than the new Canon DSLR Cameras?
The S5 Pro was great because of its wide dynamic range.  However, I believe any new dslr can do better.
You might want to ask the Fujifilm X system/SLR forum instead.
nikkor35f2 Contributing Member • Posts: 779
if u think so just get the s5...they are so cheap now.
surge
 nikkor35f2's gear list:nikkor35f2's gear list
Fujifilm X-T1 Fujifilm XF 18mm F2 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR +4 more
grazuncle
grazuncle Veteran Member • Posts: 5,764
this IS...
the Fujifilm X/SLR forum isn't it?
There is a very fine line between 'hobby' and 'mental illness.' :'!':
 grazuncle's gear list:grazuncle's gear list
Nikon 1 V1 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 PD-Zoom +1 more
grazuncle
I have  had all of the S# Pro models.
The only thing that 'might' be better is the subjective colour output over other brands.
In nearly all other areas it will be inferior.. However what it lacks may be of no consequence to you personally
TwoMetreBill Senior Member • Posts: 1,992
The S2/3/5 Pro bodies were terrific at low ISO and produce terrific images if you're not a pixel peeper. Plus there is a huge array of pro grade Nikon lenses available at quite reasonable prices.
There are battery issues with all of them. Were I buying one, it would be the S5 and I'd pick up the grip and several extra AA cell cartridges (they break). I'd use Eneloop 2100 AA cells as the Eneloop Pro cells don't seem to actually have any more capacity.
None of these bodies can be focus calibrated so expect all your images to be out of focus unless you use small apertures. These are not bodies for f/1.2 lenses unless you use manual focus. I had no problems with the Nikon 24-85 f/2.8-4 at f/8 or the 200 f/2.8 at f/11. My pair of S2s and S3 were more accurate than my S5 and could be shot 1-2 stops wider than the S5.
One tip, the circuit boards for the memory card socket had a tendency to break so try to use a single large card and transfer your photos with the USB cable. I used a 32GB card toward the end.
Lastly, while I recommended the S5, the S3 delivers almost identical IQ and is substantially cheaper. The S5 is superior in most other ways. The S3, as a cheaper entry into the system, might be the way to test it out. I preferred the handling and simpler setup of the S3.
Bill
 TwoMetreBill's gear list:TwoMetreBill's gear list
Fujifilm X-T3 Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR +2 more
