Fujifilm FinePix S5 Pro
Started Oct 6, 2017 | Questions
SamfromAL Regular Member • Posts: 242
Re: Fujifilm FinePix S5 Pro
i assume that is your daughter, lovely well lit moment!
I think this and my pic show that "specialness"
fPrime
fPrime Veteran Member • Posts: 3,727
Thanks, she is! I used a tiny Nissin i40 for balanced fill flash here. One of the unsung advantages of S5 is that you can also use Nikon's flash control lighting system.
Indeed they do.  Skin tone rendering from this camera is simply superb.  Every time I open up a RAW image from the S5 in Lightroom I say to myself "OMG, I love this camera!"  Like you, I'll never part with it.
fPrime
 fPrime's gear list:fPrime's gear list
Canon EOS 5D Fujifilm FinePix S5 Pro Leica M8 Nikon D60 Nikon D1X +3 more
grazuncle
grazuncle Veteran Member • Posts: 5,764
is that fill flash?
fPrime wrote:
Absolutely, yes, get it especially if you can still find a minty one in 2017 like I did last year. It's now one of my all time favorite bodies. Why? It delivers a filmic look from its rich CCD colors and soft highlight roll off (much like color negative film).
My recommendation is to pair it with sharp Nikkor glass to offset the strong AA filter a bit. Here I used the 17-55F2.8G which has beautiful 3D Pop in addition to contrasty colors.
i know it is 1/2000th sec but HSS flash perhaps?  .. seems like flash shadows although light is behind her.
Just curious,,
fPrime
There is a very fine line between 'hobby' and 'mental illness.' :'!':
 grazuncle's gear list:grazuncle's gear list
Nikon 1 V1 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 PD-Zoom +1 more
grazuncle
Re: is that fill flash?
Just curious,,
Doh!
just read exactly the same thing in one of your replies..
Still a good shot!
fPrime
fPrime
Just curious,,
Correct, HSS flash.  I like to use the 17-55F2.8G at f/2.8 to f/3.2 because this lens produces the most 3D Pop for me in this aperture range.  On a sunny day that will necessitate a high shutter speed which, in turn, necessitates HSS fill flash mode.
The Nissin i40 supports Nikon's TTL-BL-FP high speed sync mode natively which allows the S5 Pro to balance the sunny ambient light with just enough fill light on the subject for a pleasing photo (the correct flash subject distance is measured by the lens during AF).
fPrime
John Motts Veteran Member • Posts: 5,854
Dean66 wrote:
I'm looking for overall performance such as concert Shooting, Weddings and Landscapes.
By all means buy one if it's cheap for enjoying its nice colours at low ISOs from its CCD sensor. But for the needs you list, no it's not a great buy and has long since been superseded.
Weddings - I assume you mean as a guest, in which case it would be okay but only in good light at lower ISOs.
Landscapes - not really. You'd want more resolution than this, (in effect you'll get the equivalent resolution of about 8mp) and it's really optimised for people and skin tones.
Concerts - you need a camera that performs well in low light. The S5 is not that camera.
