Fujifilm FinePix S5 Pro
Started Oct 6, 2017 | Questions
Dean66
Dean66 New Member • Posts: 21
Should I Buy The Fujifilm S5 Pro?
 Dean66's gear list:Dean66's gear list
Fujifilm FinePix S9100 Fujifilm FinePix IS-1 Fujifilm X-T30 Fujifilm XF 56mm F1.2 R Fujifilm XF 50-140mm F2.8 +1 more
grazuncle
grazuncle Veteran Member • Posts: 5,764
Re: Fujifilm FinePix S5 Pro
Hmmmmm...
Tell us why you're looking at buying one first..
We might give a better view on the subject.
There is a very fine line between 'hobby' and 'mental illness.' :'!':
 grazuncle's gear list:grazuncle's gear list
Nikon 1 V1 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 PD-Zoom +1 more
Dean66
OP Dean66 New Member • Posts: 21
I'm looking for overall performance such as concert Shooting, Weddings and Landscapes.
puttin
puttin Veteran Member • Posts: 7,958
Yes if you have some Nikon lenses.
 puttin's gear list:puttin's gear list
Nikon Coolpix A Canon G9 X II Nikon D3 Sony Alpha NEX-7 Sony a7 II +25 more
Dean66
Thank you.
The Davinator
The Davinator Forum Pro • Posts: 24,707
Then really, no, no and no.  The rez is very limited for landscape.  Ditto for weddings if one needs any cropping or low light shooting.  The AF is average at best.  The same holds true for concert shooting.
It may be fun to play woth a bit..but you'd be better of with any of the new Fuji gear.
Dean66
What kind of old Fuji Gear should I get?Because I have The Fujifilm X-S1 and The Fujifilm s9600,
Serge 07
Serge 07 Regular Member • Posts: 447
5
I've had the S5 Pro for around two years. IMO, the reason to own one is for its rich colors, highlight dynamic range plus it is a pro  build Nikon body with access to all Nikkors, Ai and forward. The skin tones are beautiful. Professional wedding photographers used the S5 for many years for good reasons.
Yes, it is a low resolution camera by current standards, the super CCD low light capabilities are limited to ISO 1600 in use and it is no machine gun. However, the color output and highlight dynamic range that made this camera are present today.
If you like toys that are not expensive & have lenses, why not.
A couple of interesting reads:
http://women-and-dreams.blogspot.com/2015/04/fuji-s5-ship-forever-sinking.html
http://www.stevehuffphoto.com/2014/08/26/flashback-the-fuji-s5-pro-gorgeous-color-reproduction/
Serge
 Serge 07's gear list:Serge 07's gear list
Fujifilm FinePix S5 Pro Nikon D40 Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8
Dean66
I read the specs and I believe they have The Color Temperature Selection K as Kelvin?
Pete Silver
Pete Silver Contributing Member • Posts: 896
I used the camera for many years but it is oudated now but did produce some really nice colours.
Ok though if budget is tight or you already have some Nikon lenses.
I still have mine but I haven't used it for a long time.
Oh, and I wouldn't use it for concerts.
Pete Silver
 Pete Silver's gear list:Pete Silver's gear list
Fujifilm X-H1 Nikon Z7 II Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Nikon AF-S Nikkor 70-200mm F4G ED VR +1 more
TheGingerFrog Regular Member • Posts: 180
The S5 pro is a slow camera in term of operation, burst shooting and AF by today's standard.
So if by performance you mean speed then it is not a good candidate.
I'd look for a used X-T1 or X-T2 if you are shooting concert and wedding professionally.
TheGingerFrog
 TheGingerFrog's gear list:TheGingerFrog's gear list
Fujifilm XQ1 Fujifilm FinePix S5 Pro Nikon 1 V1 Fujifilm X-Pro1 Fujifilm X-E1 +2 more
The Davinator
Serge
First off, there is no such thing as "highlight dynamic range."  Second, the dynamic range has been matched and surpassed by the current Sony sensors in Sony, Nikon, Pentax cameras.  Even Fuji's latest range with DR400 setting does better with less noise and tonality breakdown.
Serge 07
Serge
Agree that modern sensors substantially outperform the S5's SuperCCD in the areas of shadow recovery, resolution & high ISO. In the areas color reproduction, highlight retention and their their film like soft clipping, not so much.
Perhaps the term " highlight dynamic range" may be in error but have certainly come across it in several articles/reviews as per the below.
"Highlight Dynamic Range" Nikon D600 vs Fuji S5 Pro:
http://betterfamilyphotos.blogspot.com/2012/10/nikon-d600-vs-fuji-s5-pro-highlight.html
Nikon D800E vs Canon 5D vs Fuji S5 Pro Dynamic Range (highlight recovery):
http://www.colda.com/?p=963
I am quite familiar with the software manipulated DR settings of the Fuji XE-1 and XE-2 which also owned. Personal preference with XE cameras is exposing for highlights @ DR100 & addressing shadow recovery in LR.
Serge
The Davinator
Serge
a
As modern sensors have a larger dynamic range, they can better maintain the entire tonal fange than the S5 can.  Highlight clipping comes from not metering correctly.  If the sensor can handle the whole range, then clipping is user error.
Dynamic range is the tonal range ofnthe entire scene from absolute balck to absolute white.  What people call highlight dynamic range is really to do with latitude above mid grey.
Serge
In my opinion, itbis nit so much the dynamic range but the fact the S5 has a less linear tonal response than modern sensors due to the second set of sensors dedicated to highlights.
So it captures light differently in the highlights.
Whether it looks better or not is a personal preference.
TheGingerFrog
The Davinator
TheGingerFrog
Very true.
SamfromAL Regular Member • Posts: 242
Yeah as they said it comes down to purpose.
The S5 in it's day was considered "special"  I have it and an XE-1.  There is a definite look to the an S5 pic.  I do often use the XE-1 to set K exposure when I have both.
I think the S5 is a very good camera and will print well, with a good lens it makes very good pictures.  The other thing that is very true about it even with respect to K exposure is that the WB is very well rendered.
I don't see my self parting with my S5, the skin tones as said are a big sell point.  For people it is difficult to beat,  without a lot of PP fuss, which I have never done.  And it is tone agnostic, black folks look just as vibrant.
Hispanic girl here
bobogdan78 Forum Member • Posts: 60
I bought this camera in 2017 used and I agree with what everybody's saying - it's a wonderful camera with beautiful colors and unique silky smooth and refined looking output. Skintones are unmatched to this day. However it's quite old and there are some shortcomings - for landscape it lacks details but the colors are wonderful; for concerts it lacks high iso capability; for weddings it could still be usable but it is no longer supported by Fuji so if it brakes...
 bobogdan78's gear list:bobogdan78's gear list
Fujifilm FinePix S5 Pro Olympus PEN E-PL3 Olympus E-PL7 Nikon AF Nikkor 24mm f/2.8D Nikon AF Nikkor 50mm f/1.8D +2 more
markusw Senior Member • Posts: 1,705
And reverse: if you do not own Nikkors, leave it and get one of the latest Fuji bodies. With the S5pro, you'll invest in the Nikon ecosystem.
M.
https://www.flickr.com/people/126876759@N02/
fPrime
fPrime Veteran Member • Posts: 3,727
Absolutely, yes, get it especially if you can still find a minty one in 2017 like I did last year. It's now one of my all time favorite bodies. Why? It delivers a filmic look from its rich CCD colors and soft highlight roll off (much like color negative film).
My recommendation is to pair it with sharp Nikkor glass to offset the strong AA filter a bit. Here I used the 17-55F2.8G which has beautiful 3D Pop in addition to contrasty colors.
fPrime
 fPrime's gear list:fPrime's gear list
Canon EOS 5D Fujifilm FinePix S5 Pro Leica M8 Nikon D60 Nikon D1X +3 more
