Northern Lights in Norway (XT20).
Started Oct 3, 2017 | Photos
edorf_71
OP edorf_71 Regular Member • Posts: 236
Re: Northern Lights in Norway (XT20).
deednets wrote:
edorf_71 wrote:
Andrew in Norway wrote:
Nice pictures, but a few words of advice:
I used to live in Mo i Rana, which is near the Arctic circle in Norway. There I took aurora pictures on film, using Fuji 400 negative film. It was never as green as in your pictures, as it was winter there was snow on the ground so any tint is instantly noticeable. Next time you take aurora pictures set the white balance manually at daylight (5600K) and RAW + JPEG, with the film simulation at Provia (normal). Take at least some pictures at these settings. Don't be afraid to use a high ISO. sometimes the aurora is not simply a green curtain or veil. I have seen (but not photographed) orange and red aurora, a correct white balance would be crucial then.
Thanks for your suggestions! Will play with different settings in LR.
You feel like providing a RAW file?? maybe one that you don't feel too precious about?? Would be a great opportunity for those who "saw" the image differently.
Deed
Here:
https://1drv.ms/i/s!Ai6T_F2m-OeotQY1hXlfWB9ppeIm
edorf_71
 edorf_71's gear list:edorf_71's gear list
Nikon Z9 Nikon AF-S Nikkor 800mm f/5.6E FL ED VR Tamron 15-30mm F2.8 Nikon AF-S 70-200mm F2.8E FL ED VR Nikon 500mm F5.6E PF +3 more
deednets Forum Pro • Posts: 13,887
TIF edit ...
Deed
Here:
Thanks for that! You don't shoot RAW??
Deed
 deednets's gear list:deednets's gear list
Leica Q2 Fujifilm X-Pro3 Sony a7 IV Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
edorf_71
Re: TIF edit ...
Deed
Here:
Deed
Yes I do.
edorf_71
Re: TIF edit ...
Deed
Here:
Deed
Yes I do.
Would have benen more interesting then the 136MB file you had saved ... but thanks for providing it anyway, lust doesn't seem to have the same headroom than the RAW
Deed
edorf_71
Re: TIF edit ...
deednets wrote:
Deed
Here:
Deed
Yes I do.
Deed
Ok can put up the rawfile tomorrow. 👍
edorf_71
Would be great!! NT
edorf_71 wrote:
deednets wrote:
Deed
Here:
Deed
Yes I do.
Deed
Norm S Junior Member • Posts: 33
Re: TIF edit ...
cool!
might be going to (hopefully) see the lights in yellowknife in a few weeks. what settings and lens did you use? any tips and pointers?
edorf_71
Re: Would be great!! NT
Here you go Deed (DNG format):
https://1drv.ms/u/s!Ai6T_F2m-OeotTziclQfnwDYyk_y
I don't have the raw's anymore as I use Iridient XTransformer to make dng's.
edorf_71
edorf_71
Different exposures
Norm S wrote:
cool!
Hi Norm! I used a little different settings on those shots. Tried different shutters and iso. Lens on all was the Fujinon 14mm f2.8
Examples: Just hold your mouse over the shot and exif info will show:)
edorf_71
Difficult ... ;-(
Thanks for that! Difficult I found this to colour edit as I have no idea what I was aiming for
Deed
robert1955 Veteran Member • Posts: 7,299
my try
Can't upload to dpr [no Flash in my browser] and this is a first for me so I hope it works: onedrive
What I've done is based on the way I processed my own shots from Finland from March this year. There are two big differences:
- there was snow on the ground and some moonlight behind me [making WB easier]
- hardly any light pollution.
- no clouds [not that there was much to reflect on them anyway.]
I've used more or less similar Lr settings as in my own shots, with one big exception. I tried [not completely satisfactory] to reduce the effects of the streetlights, by reducing Orange saturation in the HSL tab. In that tab, I also changed the Hue for Purple to the left, which makes the dark parts of sky bluer.
I did not move the Exposure slider much. That worked for m in my own shots. It also makes the stars come out nicely. Notice though that they are starting to trail, because of the 30s shutter speed. I think this is a situation where [as long as you don't try to lighten the image too much in processing], there should no be a problem in using higher ISO (up to 6400 should be good with your camera) and shorter shutter speeds.
A final OT remark: even if you use IXT now, I'd still keep the RAF. The DNG from IXT is demosaicked and while you can do a lot of processing without damage, you cannot go back if a better demosaic comes along
edorf_71
Re: Difficult ... ;-(
Deed
Hm. That looked kindof strange? Not my style  👍
edorf_71
olynik969 Senior Member • Posts: 1,895
Awesome
Bob (formerly bobmax)
 olynik969's gear list:olynik969's gear list
Olympus E-M1 II Olympus OM-D E-M10 III Nikon Z6 Fujifilm X-T3 Nikon AF-S Nikkor 50mm F1.8G +7 more
michaeladawson Forum Pro • Posts: 18,313
Thought I would give it a quick go.  Here's my version.  Seems similar to some of your initial posts.  Was fun to play with though.
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Nikon D7200 Nikon D5 Fujifilm X-T2 Nikon D850 Fujifilm X-E3 +39 more
edorf_71
That looks good Mike😊
edorf_71
edorf_71
Re: my try
Hi Robert! Thanks for tips and suggestions😊
I think your edit looks more how it really looked and very true to life👍
edorf_71
