Panasonic G85 with Olympus 40-150 2.8 AF?
Started Oct 3, 2017 | Discussions
Kwick1 Contributing Member • Posts: 910
Hi,
Considering buying the Olympus 40-150 2.8 to go with my Panasonic G85.  I'm curious about the AF speed of this combination.  I normally stick to Panasonic lenses, but hope this combo will work well.  I realize that I won't have Dual IS capability, but the IQ may be worth it.
Can anyone comment on the AF speed of that combo?
 Kwick1's gear list:Kwick1's gear list
Canon EOS 6D Canon EF 50mm f/1.2L USM Canon EF 28-135mm F3.5-5.6 IS USM Canon EF 70-200 F4 II +3 more
Olympus 40-150mm F2.8 Pro Panasonic G85
OP Kwick1 Contributing Member • Posts: 910
Re: Panasonic G85 with Olympus 40-150 2.8 AF?
No one?
Paul80 Regular Member • Posts: 101
Hi
I use the 40-150 on my G80 so the same as yours and the focus is lightning fast as you would expect with this lens.
No IOS as the lens has none built in but the IBIS still works fine, image IQ is superb.
Paul
 Paul80's gear list:Paul80's gear list
Panasonic Lumix DMC-G6 Panasonic G85 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +8 more
Thanks, Paul  I just ordered one!
eques Veteran Member • Posts: 4,115
GX7 with Olympus 40-150 2.8 AF
I can campare the 2,8/40-150 on the GX7 with the EM5ii: I find AF with both bodies is comparable, with the GX7 being slightly faster and hunting a little less in low light.
A fantastic lens, if you don't mind the weight.
Peter
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
