AF misses. Canon
Started Oct 1, 2017 | Questions
OP ohrid New Member • Posts: 9
Re: Indeed very soft
Thanks for the answers! I will take all the opinions into consideration and explore this problem more precisely the next time outdoors. I notice this problem only when upload photos to computer, never have time while shooting. But now I will explore it right away. I will let you know for sure! Thanks everyone!
ThrillaMozilla Veteran Member • Posts: 7,681
Re: AF misses. Canon
brightcolours wrote:
The f-value is not important, and it and the exposure time are in the EXIF.
The EXIF data are not available to me.  Do you have them?
And the F stop is relevant if it is very small, or if it is so small that the shutter speed is too low.  Anyway, I have no idea how the pictures were taken, except that it was broad daylight.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
brightcolours Forum Pro • Posts: 15,885
Download the images, they have the EXIF.
AnthonyL Veteran Member • Posts: 3,686
I get the Exif data just by clicking on Info when focussed on one image as below:
When requesting help on fine detail I still maintain that it is better for posters to upload a full size image to this site where all that data is readily available and also I don't think it helps analysis by having a fairly heavily compressed jpg - the other images the OP has posted are larger but still far smaller than the 450D produces.  Trying to differentiate between softness, OOF and having compression adding to the variables is unhelpful.
 AnthonyL's gear list:AnthonyL's gear list
Canon EOS 700D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +5 more
I see it now.  You have to click on the tools on the upper right.  I missed that.  The images don't download in the usual way.
It's hard to see an obvious cause.  I still suggest on of the four causes that I posted above, but it's hard to know.
I just checked.  My Canon will blink red to indicate which exposure spot is active in the viewfinder, but that definitely does not indicate an exposure lock.  It is quite possible to get that blink even though the camera is not focused at all.
You can get that blink even if auto focus is off, and even if it's not focused at all.  I strongly suspect user error.  I think you need to just read the manual and practice a bit to make sure you know how to use it.
I downloaded the first picture, with the brick building.  Unfortunately, the image is so strongly compressed that I could not diagnose the problem with any certainty.  Compression artifacts seem about equal to the image blur. The compression artifacts are so severe that I think that compression is a big part of the problem, but I think the image is also very out of focus.  I suggest that you store your images at the highest quality.
rwl408 Senior Member • Posts: 1,849
When an AF point blinks red, it means that AF point has acquired focus! The green focus confirmation light just reflects the fact that one or more AF points have blinked, nothing more. If the photo shows out of focus at the blinked AF point, something is wrong. Lens? AF sensor and image sensor chip not on the same plane? Or shooting technique? Put the camera on a steady tripod and figure it out.
No, that's the way it seems to work under most conditions, but it's not how these cameras actually work. I'm sitting here with my SL1 (which is working perfectly, in case you're wondering), and I can confirm that these cameras don't work that way.
With OneShot focus it's easy to get the center point to blink without a focus lock. I just focused on a nearby flat surface with no contrast, and held the shutter release half depressed. The center point blinked, and the green focus light flashed continuously but did not stay lit. The image is definitely way out of focus.
That's just one way to defeat auto focusing. There are others. I don't know exactly how the user's older camera works, but as far as I can tell, lots of people make that mistake and blame the camera. There's a reason the green light is called a focus confirmation light.
T_Van Forum Member • Posts: 84
Do you focus by half depressing the shutter or use the back button for focusing?  You may be able to improve the situation a bit by using the dedicated back button focusing.
I seem to be able to capture decent photos with old 400D and 1000D models.
best of luck,
Travis
“You don't make a photograph just with a camera. You bring to the act of photography all the pictures you have seen, the books you have read, the music you have heard, the people you have loved.”
- Ansel Adams
 T_Van's gear list:T_Van's gear list
Canon ELPH 300 HS Canon EOS 1000D Pentax *ist DL Pentax K200D Pentax K-5 II +1 more
I think in your test you have fixed the AF point, most likely to the center AF point. In this case as soon as you half-press the shutter button, the camera informs you the AF point to be used by blinking it immediately. The actually focus is acquired only when the (same) AF point blinks again (and the focus confirmation).
But if you set the AF point selection to AUTO, there will be only one blink from the AF points to indicate who is in focus after you half-press the shutter button. That is the confusion.
Yes of course. But it blinks and beeps when you have AF lock.
You can't take a photo in One Shot when you don't have focus lock.
Nonsense. You do not understand JPEG compression, it does not cause such unsharpness.
No.
Yes, I think the beep is a focus confirmation if you have it turned on. (I haven't tested to be sure.)
Good point. But you definitely can in AI Servo, for example. I see you already mentioned that.
I don't know how misfocusing due to user error is possible in live view, but I'm not ruling it out
Ordinarily, not with these camera images. But if not compression, then what caused this?
Ohrid's first photo
Notice the characteristic incoherence. I would say this suffers from extreme jpeg compression at some point in the chain. AnthonyL also mentioned this. It's probably also seriously misfocused. From the asymmetrical horizontal broadening of the flagpole, maybe also serious camera motion, or possibly loose elements in the lenses.
I still suspect user error, although camera malfunction can't be ruled out. Loose elements in the lenses could cause intermittent focusing problems. Ohrid, have the camera or lenses been dropped or received hard knocks?
Some lenses can't focus in live view (depending on camera model), like the Tokina 12-24mm f4 and the Sigma 18-50mm f2.8 EX DC. This is because they take too large steps, where the contrast never really is there, and the camera just judges that from one step to the next there was less contrast, so it takes a step back (into unfocus). But I had this issue with 3rd party lenses with the 450D, not with Canon lenses.
The OP, in the original post, did not mention live view focus though. I may have missed it in another post?
Also, in live view you can set the camera to use the PD AF sensor for focussing. That then will give the same results as normal OVF shooting.
The softness is caused by misfocus. The squares by JPEG compression.
Ohrid's first photo
Yes.
ohrid wrote:
As I tell camera most of the time takes good-focused shots, but sometimes happens such misses inspite af blinks red. I tested with Live view as you say. Result is the same. Mostly it is focused. But sometimes it is not focused.
And what do you think of the asymmetrical broadening of the flagpole and other vertical features?  Compare it to the better-focused picture of the same building.
Yes.
It looks like IS not having settled while the image is taken.
