Sigma 20mm 1.4 ART vs canon 16-35 2.8 III
Started Sep 30, 2017 | Discussions
Deorum Contributing Member • Posts: 780
Apart from the 1.4 factor, do you think the newest Canon comes close to resolution and clarity?
Most tests i've seen seem to indicate they are pretty close.
for example photozone.de
Sigma Art 20mm , tested at 50mp
Canon 16-35mm 2.8 III, @20mm tested at 50mm
Similar to this seem to be the result in other test sites, such as lenstip.com
Sigma 20mm art, tested with 5d3
Canon 16-35 2.8 III, center, tested with 5d3
Canon 16-35 2.8 III, FF edge, tested with 5d3
Does anyone has any personal experience or insigh with this dillema?
I dont care at this point for the zoom vs speed (1.4/2.8) debate. Just for the optics and IQ comparison of these two lenses.
Thank you in advance
George Spyros,
www.georgespyros.com / www.energyphotos.gr
 Deorum's gear list:Deorum's gear list
Canon EOS-1D Mark III Canon EOS-1Ds Mark III Canon EOS 7D Canon EOS-1D Mark IV Canon EOS-1D X +8 more
Canon EF 16-35mm F2.8L III USM Sigma 20mm F1.4 DG HSM Art
expro Senior Member • Posts: 2,274
Re: Sigma 20mm 1.4 ART vs canon 16-35 2.8 III
The whole point is exactly the 1.4 factor and that is why you have no responses....
you either need the prime or you need the zoom. Not sure anybody would decide between the two on optics alone...
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
Abu Mahendra Veteran Member • Posts: 5,312
if you don't care about aperture, go for the lighter, cheaper 16-35LIS.
>> I'm already lovin' my Canon 35IS lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
ed rader Veteran Member • Posts: 9,068
silly comparison.  silly that anyone cares about charts these days when all of the best lenses are "perfect"
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
OP Deorum Contributing Member • Posts: 780
That is why i ask, you think that all these new lenses are already so good that they've reached a plataeu, and IQ differences are miniscule?
George Spyros,
Sittatunga Veteran Member • Posts: 5,413
There are a whole lot of other factors that affect IQ.  That's why sites such as lenstip and photozone use so much space to talk about distortion, bokeh quality, coma, astigmatism, flare etc.  There's also colour rendering, contrast and microcontrast which don't get talked about so much as they're harder to measure or illustrate consistently.
These are my thoughts and i wanted to hear other people's thoughts.
 I cannot believe that the best quality-prime, will produce the same image with the best quality zoom.
 Yes, that is for shooting daylight landscapes, lets say @ f5.6-f8.
These tests seem to indicate that the lenses are more or less the same, smth that seems counterintuitive to me.
George Spyros,
ffabrici Senior Member • Posts: 1,353
I have the 20mm ART and I have tried the 16-35L II.
Both er super sharp in the center even wide open and their edge and extreme corner sharpnes are comparable for the same apertures. Doownsides are found when used at large apertures: Coma for the ART and vigneting for the zoom.
Both are highly recommendable so thendesition is more dependent on your needs and wants than their performance.
I do also have the 16-35L IS, but others would prefer the 2.8 zoom. I find primes more challenging and rewarding to use but zooms are way more versatile for events and reportage photo shoots.
you mean you have tried the 16-35L III (mark 3)
George Spyros,
Correct; the 16-35L III.
So more or less you agree with the first posts, IQ differences are miniscule. It all comes down to whether you need the speed of f1.4 or the versatility of the zoom.
George Spyros,
Look, the reality these days is that the top zoom lenses are exceedingly good, approaching, and in some instances, surpassing prime lenses (e.g. 24-70LII vs 24/2.8IS). You are not going to appreciable differences in resolving power at f/5.6 and beyond.
yes that's what i believe....
the lenses I have now ar "PERFECT"
