Deleted Photos
Started Sep 25, 2017 | Discussions
Confused of Malvern Senior Member • Posts: 1,278
Deleted Photos
I've accidentally deleted two days worth of vacation photos from the S D card (I was actually trying to back up the photos for safe keeping but had the opposite affect). It's a Sandisk ultra card. I haven't reformatted it or over-written the original images. Can they be recovered and if so, how?
Confused of Malvern
'The greatest fool can ask more than the wisest man can answer'
 Confused of Malvern's gear list:Confused of Malvern's gear list
Pentax K-3 +1 more
LightBug Senior Member • Posts: 2,351
Re: Deleted Photos
Searching on google turns up some choices of SD card recovery.  I have no experience in this so can't really recommend any of them but maybe they are worth a look.
 LightBug's gear list:LightBug's gear list
Pentax K-S2 Pentax Q-S1 Sony Alpha a7R Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 40mm F2.8 Limited +10 more
Labe
MOD Labe Veteran Member • Posts: 8,193
Re: Deleted Photos
5
sandisk have their own recovery software. Its printed on every packet . Try their website to get a download from them.
I use software called don't panic myself and select deep scan ( its a bought software )
 Labe's gear list:Labe's gear list
Fujifilm FinePix IS-1 Sony Cyber-shot DSC-RX10 Sony Alpha NEX-3 Sony SLT-A68 Samsung Galaxy S7 edge
Donald B
Donald B Veteran Member • Posts: 9,768
Re: Deleted Photos
I had exactly the same thing happen a few years back. Dont get a free programe they dont work i paid $30au and it worked perfectly.
Don
Olympus EM5, EM5mk2 my toys.
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1
trungtran Contributing Member • Posts: 702
Re: Deleted Photos
7
I have used easeus.com in the past and it has done the job.
If you have another SD card. You can test out the software. Delete the files and try and recover it before running it on the card that needs to be recovered.
 trungtran's gear list:trungtran's gear list
Sony Alpha a7 II
Paul-D700 New Member • Posts: 10
Re: Deleted Photos
Hi,
I had a similar situation several years ago.  I used software called "Recuva," and was able to recover the deleted images.  I recommended the same to a friend, and he had similar success.
Paul
griddi
griddi Veteran Member • Posts: 5,262
Re: Deleted Photos
Good advice !!!!!!!
Griddi.....
Gato Amarillo Veteran Member • Posts: 5,309
Re: Deleted Photos
Very good thinking. Try to repeat the process as you did it with the vacation photos using a spare card some junk photos, then try the software.
SpiltMilk Senior Member • Posts: 1,644
Re: Deleted Photos
I also recommend the free "Recuvva" program from the people who make CCleaner.
It's good, it works well.
The main "secret" is to do NOTHING with the SD card - find some undelete software then mount the card to the computer and run the undelete.
merops
merops Senior Member • Posts: 2,195
Re: Deleted Photos
I bought several Sandisk Extreme Pro cards, and got a paper token with a serial number on for a free one-year subscription to RescuePRO, their 'Deluxe recovery software' with each of the cards. If you'd like the serial number etc off one of these let me know and I will pm it to you.
Donald93 New Member • Posts: 15
Re: Deleted Photos
Recuva is strongly recommended. But if you use a Mac computer, here is also a freeware called RePicvid to recover deleted photos. I used it several times and it worked well.
OP Confused of Malvern Senior Member • Posts: 1,278
Disaster Averted!
Thank you for the very kind offer Merops, which is much appreciated.  I've waited until I got home to check but you reminded me that I also had the same free subscription that came with the card.
Thanks everyone for your other helpful suggestions
In the end I haven't needed to use card recovery software - I'm pleased to say that the external back-up I was making when I thought things had gone wrong did in fact work and I had a copy of everything safely on my external drive (Jobo Giga One Ultra ) even though it had then wiped the original memory card which I hadn't intended.  Phew!
The Jobo has been an excellent device that's served me well for a number of years and is really useful for backing up on short trips when you don't want to take a laptop but you can't be absoutely confident it has worked until you connect it to a PC.  Maybe it's time for me to look for a replacement strategy.
Confused of Malvern
Pentax K-3 +1 more
merops
Re: Disaster Averted!
Excellent news. Really glad for you that you've got this sorted out
abe4652 Senior Member • Posts: 2,026
Re: Deleted Photos
Search "recuva" from piriform
