X-Trans ll vs X-Trans lll
Started Sep 25, 2017 | Discussions
afm Contributing Member • Posts: 574
Thinking of up-grading, but is there any real difference in IQ between the above sensors?
I am aware of all the advantages of the new camera line up, but it is IQ that interests me most as this will primarily influence my decision.  I would appreciate your views please.
Many thanks.
Regards. Alan
JayPhizzt Senior Member • Posts: 1,959
Re: X-Trans ll vs X-Trans lll
I would say no. In general there is very little difference between sensors regarding IQ, other than noise performance, dynamic range and resolution of course. Lenses are more important when it comes to IQ.
 JayPhizzt's gear list:JayPhizzt's gear list
Fujifilm X-T3 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 80mm F2.8 Macro +1 more
Artem Holstov Forum Member • Posts: 63
Many thanks.
Regards. Alan
Based on all of the available reviews and tests, I think that the only difference is the resolution. The dynamic range and high ISO performance are similar if not better on the older gen. sensors thanks to larger pixels.
 Artem Holstov's gear list:Artem Holstov's gear list
Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 35mm F1.4 R Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 16mm F1.4 R WR +2 more
Elemanzer Regular Member • Posts: 166
The sensor is notionally noisier if you don't account for resolution, but if you scale X-Trans III images down to 16MP then they'll look less noisy than the X-Trans II 16MP images. That means that prints of the same size will generally look better on X-Trans III, all else kept equal. Even if you don't account for resolution, the X-Trans III sensor has the Aptina dual-gain stuff, meaning that it's much less noisy past ISO 800 than the X-Trans II sensor was. For a given format size, and up to a point, large pixels don't count for much on modern CMOS sensors (look at the 12MP A7SII: for stills, no better in low light than the A7RII).
You get about a third of a stop more DR across the board, again rising to half a stop past 800. Notionally DR is worse at high ISOs (crossover at about 2500). That's because analogue amplification ends at ISO 1600 on X-Trans II. 3200 and 6400 are actually just 1600 plus instructions to the RAW processor to push the file. That, of course, means more highlight headroom. Of course, you can do the same manually.
24MP makes a big difference for some things, and hardly any difference for others. If you only ever do small prints and/or portraiture, you won't care much. If you do large landscape prints, you probably will.
In sum? You get about what you'd expect to get by moving from the NEX-5N sensor to the A6300 sensor: it's at least marginally better at everything, but 24MP rather than 16MP. It's just a question of whether there's enough improvement for you to care.
 Elemanzer's gear list:Elemanzer's gear list
Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 35mm F1.4 R +2 more
Many thanks.
Regards. Alan
https://nwinspeare.com/tag/x-trans-iii/
Here is a nice article with examples.
torppapa Contributing Member • Posts: 746
Many thanks.
Regards. Alan
In my opinion there are no significant changes between II and III except one.
Waxy skins at higher ISOs are mostly gone. I say mostly, because the rendering is much better than with Xtrans II but not completely since I'm still able to  produce waxy skins from time to time even with Xtrans III.
 torppapa's gear list:torppapa's gear list
Canon PowerShot G10 Canon PowerShot G15 Canon PowerShot G9 Panasonic LX100 Fujifilm XF10 +111 more
third son
third son Senior Member • Posts: 2,759
The foliage smearing issue has been somewhat resolved in X-TransIII.  I find that it is rarely a problem anymore just using LR but I find it does still occur in some instances.
-Paul
 third son's gear list:third son's gear list
Fujifilm X-T2 Nikon Z6 Fujifilm XF 100-400mm F4.5-5.6 OIS WR Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +14 more
This is not a sensor problem. It may have been resolved somewhat when using LR because Adobe have been making updates.
JS Burnie
JS Burnie Veteran Member • Posts: 4,280
Could be that the higher pixel density of the xtrans III sensor makes images less prone to worming.  I don't see that Abode has made any significant changes, but I'm using xtrans II.
 JS Burnie's gear list:JS Burnie's gear list
Fujifilm X-T1 Fujifilm X-E2 Fujifilm X-E3 Fujifilm X-H1 Fujifilm XF 23mm F1.4 R +5 more
OP afm Contributing Member • Posts: 574
Thank you very much for that, as you said, a nice article.  Thank  you also to everyone who kindly replied and provided most helpful comments.
Much appreciated.
Regards. Alan
DarnGoodPhotos Forum Pro • Posts: 10,878
If you are a JPG shooter the greatest improvement is that the high-ISO waxy skintones have been significantly reduced. Plus you get Acros.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F2 R WR +2 more
John Motts Veteran Member • Posts: 5,824
The biggest difference comes in low light and higher ISOs. The new sensor is a real improvement in terms of noise and overall image quality at higher ISOs.
Sure there will be those who say there is more noise on the newer sensor - this is absolutely not the case.  When compared side by side, size for size, the new sensor is a very significant improvement.
Below say 1600 I'm not sure you'll notice a big difference, although the extra resolution is significant for larger reproduction and cropping.
(I have both)
Thanks to you John and others who have responded. Most helpful.
Regards. Alan
I agree with John about one stop better performance; ISO12800 on X-Trans3 is as good as ISO6400 ion the XTrans2
ukeolo Regular Member • Posts: 187
I found this sentence in a review of the x-e3 that raises some concern on X-Trans III rendering compared to X-Trans II: "Nonetheless, I believe that sensor’s output looked much more analog than the newer ones" (https://www.thephoblographer.com/2017/09/21/first-impressions-fujifilm-x-e3-sample-images-included/)..
I am selling my x-e2 and pre-ordered an x-e3, I hope I will not regret it: not always better technical specifications lead to better results.. for instance I had bought the x-A3 and sold it since I found the new 24mpx sensor did not provide images as pleasing as those of the x-A1 or A2.
Many people think the X100 looks more analog than X-Trans1 and XTrans1 looks more analog than X-Trans 2, so that really is subjective.So assuming all of this is true, you either revert back to the first-gen cameras, or you accept the trade-off in exchange for improved functionality and speed.
Nothing wrong with staying with older cameras if you don't like the newer IQ. I stuck with my Pro1 over a T1 for just that reason. Now I have a Pro2.
It's funny. Similar discussions have been made in regards to the 5D, 5Dii, 5Diii and so on.
Myself I returned from 6D and 5DII to the original 5D for this reason. But I'm using also an XT2, so I have something from both worlds, old and new.
Iuvenis Senior Member • Posts: 1,394
Not my experience. I think the X-Trans III is noticeably better than X-Trans II, and that it looks just as analogue.
 Iuvenis's gear list:Iuvenis's gear list
Fujifilm X100V Fujifilm X-T3 Panasonic Lumix DC-S1R Fujifilm XF 16mm F1.4 R WR Fujifilm XF 56mm F1.2 R +4 more
retroactivity Regular Member • Posts: 229
If you compare any 2 cameras on DPreviews test scene widget, XTrans 3 clearly resolves more fine detain than XTrans2. Better low light performance is less clear and more subject to debate.
 retroactivity's gear list:retroactivity's gear list
Fujifilm X-E1 Fujifilm X-E2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 35mm F1.4 R +1 more
Joachim Gerstl
Joachim Gerstl Veteran Member • Posts: 8,642
Many thanks.
Regards. Alan
Based on my experience (side by side shooting with the X Pro-2 and X-T1) the dynamic range of the 24MP sensor is significantly. Resolution obviously is better and noise performance is at least at the same level or slightly better.
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Fujifilm X100F Sony RX100 IV Fujifilm X-Pro2 Fujifilm X-H1 Fujifilm XF 14mm F2.8 R +8 more
