A99II above ISO 6400
Started Sep 24, 2017 | Discussions
lim yau tong
lim yau tong Veteran Member • Posts: 3,863
I always have the fear of going above ISO 6400 when shooting with A99II. Is my fear warranted? Is it ok to go above ISO 6400 instead of suppressing the exposure speed to get a lower ISO?
yau tong
 lim yau tong's gear list:lim yau tong's gear list
Sony Alpha DSLR-A350 Sony Alpha DSLR-A700 Sony Alpha DSLR-A550 Sony SLT-A55 Sony SLT-A77 +33 more
garykohs
garykohs Veteran Member • Posts: 4,690
Re: A99II above ISO 6400
5
ISO 16,000 with the 300/2.8 HS wide open.
ISO 20,000 - same lens, wide open.
ISO 12,800 - same
 garykohs's gear list:garykohs's gear list
Konica Minolta Maxxum 7D Canon EOS-1D X Sony a99 II Sony a9 Canon EF 85mm f/1.8 USM +16 more
tbcass
tbcass Forum Pro • Posts: 39,218
ISO 12800
Tom
Look at the picture, not the pixels
 tbcass's gear list:tbcass's gear list
Sony RX100 Sony RX10 IV Sony a99 II Tamron SP AF 90mm F/2.8 Di Macro Sony DT 35mm F1.8 SAM +10 more
Michael Fritzen Veteran Member • Posts: 5,695
Nothing to do with this thread but this shot caught my attention. It's probably because of the high contrast / shallow DOF provided by the lens in combination with the already dropping DR of the sensor at this ISO which gave the shot a look similar to the "Miniature" style. Seriously I had to look two times because at first glance it looked as if  those were playmobil toy figures.
Michael Fritzen
DrFzs Regular Member • Posts: 103
These picture about 50 % crop
 DrFzs's gear list:DrFzs's gear list
Sony a99 II Sony DT 11-18mm F4.5-5.6 Sony 70-300mm F4.5-5.6 G SSM Sony 70-400mm F4-5.6 G SSM II Sony 24-70mm F2.8 II +8 more
garykohs
And then again it might be that the guy at left is about 5'2". He plays a lot bigger than that though!
sybersitizen Forum Pro • Posts: 11,395
Can't you perform your owns tests and decide? We all have different opinions about what is acceptable or unacceptable.
garykohs
Theatre shots
5
ISO 8,000:
ISO 10,000:
ISO 16,000
tbcass
Good point. A few test shots would answer his question.
Tom
pizdets17
pizdets17 Contributing Member • Posts: 732
iso 10,000, SOOC
 pizdets17's gear list:pizdets17's gear list
Sony a6300 Sony a99 II Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 85mm F1.4 ZA Carl Zeiss Planar T* +11 more
Trevor_S
Trevor_S Regular Member • Posts: 387
This is true... The tbcass pic above, the first thing I noticed was the noise, very distracting BUT it's still pretty darn good, I was impressed with how little there was.
I never go above 1600 on my A99 as the noise gets two distracting and my ability to remove it in PP seems ... lacking.  Before that I never went above 800 on my old Nikon D300 for the same reason.
I was hoping 3200 on the A99ii but it looks like 6400 might be great as well, whih his impressive to me and then only above that does does it start to get iffy, depending on your own noise tolerance of course.
I might wait another year or two and try and grab a cheaper used 99ii
 Trevor_S's gear list:Trevor_S's gear list
Sony Alpha a99 Sony a6000 Sony 70-200mm F2.8 G Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 85mm F1.4 ZA Carl Zeiss Planar T* +6 more
tbcass
I'll take some noise over too much detail reducing noise reduction any day.
Remember that when viewed at 100% a 42mp image is hugely magnified and noise is magnified as well. Here's the same image reduced to 8 MP. Do you see much noise now?
Here's resized to 24mp.
Tom
FDecker Senior Member • Posts: 1,668
You have the camera. What keeps you from giving it a try???
nt
Lensmate
Lensmate Senior Member • Posts: 2,891
Re: Theatre shots
garykohs wrote:
ISO 8,000:
ISO 10,000:
ISO 16,000
Great shots there Gary....how are you processing your shots and what noise reduction are you using? Are you also using compressed or uncompressed RAW files?
cheers
-Martin P
https://www.flickr.com/photos/photosauraus_rex/
tbcass
Re: Theatre shots
From my experience with the A99ii that type of high iso performance is possible with JPEG's with noise reduction set to low to retain detail.
Tom
