What does slightly chipped glass produce? (70-200 f/2.8 IS)
Started Sep 23, 2017 | Questions
My_name_is_Ben New Member • Posts: 6
I have the chance to buy a 70-200mm f/2.8 IS at a very very steep discount because the front element has a small chip, about the size of a half grain of rice. This lens is way out of my budget ordinarily (I'm just an amateur with gear envy), so should I just go for this? Or will every shot come out obviously messed up? Anyone have sample shots to show?
 My_name_is_Ben's gear list:My_name_is_Ben's gear list
Canon EOS 60D Canon EOS 6D Canon EF 24-105mm f/4L IS USM Canon EF-S 18-55mm f/3.5-5.6 IS STM Canon EF 50mm F1.8 STM
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Re: What does slightly chipped glass produce? (70-200 f/2.8 IS)
5
I think the worst effect will be a slight increase in lens flare, otherwise the lens should be fine. You can do an old photo trick of rubbing a tiny bit of carbon black on the chipped surface to minimize flare.
I would verify, however, that a lens element hasn't been knocked out of alignment since the lens obviously took a beating. The first thing I would do is shoot parallel to a textured wall, wide open in flat light and verify that all four corners are equally sharp/unsharp.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
BlueRay2 Forum Pro • Posts: 14,816
i concur with what hotdog321 suggested but you haven't indicated whether you have access to the lens in order to test it to make sure other elements inside are and not out of alignment. also to see how much flare the lens generates! if you have access to the lens and make sure everything is ok then it might be a good value (although you haven't indicated the selling price) also, i think replacing the front element is not prohibitively expensive, as far as i can remember, it is worth a try! good luck.
Scott Larson Veteran Member • Posts: 7,505
I managed to put a small chip into the front element of my 24-105mm. All it does it make this round flare sometimes.
I "fixed" it by putting a small piece of black tape over the chip. Yes, I have no shame.
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +17 more
a chip....what chip? and i do see a circle behind your girlfriend (standing)...is that happen to be the moon or the chip you are speaking about?
TigTillinghast Contributing Member • Posts: 528
Current eBay prices show about 950 to 1050 for the Mark I lens, which you appear to be referring to. Replacing the outer element might cost $400. I'd put the value of the lens at about $600. If you're getting a better deal than that, then I'd have no qualms.
 TigTillinghast's gear list:TigTillinghast's gear list
Panasonic Lumix DC-S1R Sony a7R IV Canon EOS R5 +1 more
BirdShooter7 Veteran Member • Posts: 9,134
One thing to consider is that Canon no longer services this model.  I found that out when my IS unit went out.
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
ed rader Veteran Member • Posts: 9,068
i paid right under $500 to replace front element on 24-70L II.
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
Michael Fryd
Michael Fryd Forum Pro • Posts: 16,059
As others have pointed out, the only optical issue from a small chip will be a small increase in flare, and a possible corresponding decrease in contrast.
If you take a black Sharpie and fill in the crack, that will solve your flare and contrast problem.  Once filled in, the chip should not cause a visible difference in the final image.
 Michael Fryd's gear list:Michael Fryd's gear list
Nikon Coolpix AW130 Canon EOS D60 Canon EOS 7D Mark II Canon EOS 5DS Canon EOS 5D Mark IV +16 more
