Some Fungi with GH5 + Olympus 60mm Macro
Started Sep 23, 2017 | Discussions
DNature
DNature Regular Member • Posts: 310
7
I had two hours yesterday between the rain and decided to look around a local forest and see if there was any fungi around. It was mostly a cloudy dull day and had just stopped raining when I arrived, so not very bright, especially as I was there in the mid afternoon.
I was able to get a few photos of various fungi in the 2 hours I spent here before it started getting a bit darker and had to leave. The forest is quite large, so I was only able to check out a small part of it and only found a few fungi or probably would have found more.
All these shots were taken with my Panasonic GH5 and Olympus 60mm Macro lens and a tripod (the last image was taken with an Olympus 12-40 at 40mm f/5.6 and the second image was taken with my camera on the forest floor pointed up at the fungi with a 5 second shutter at ISO 320 as the small tripod I was using wouldn't go low enough.
I found the IBIS on the GH5 works really well with the second image, especially since I couldn't get the camera perfectly still while holding a light on my left hand ant trying to press the shutter while getting the correct composition and focus with my right hand.
I used mostly slow shutter speeds (between 1/6 and 1/20 second) at between ISO 200-320, and between f/6.3 and f/9.0. for all the images and took them in RAW.
To get a little more light, as I don't have a flash, I used an Aputure M9 LED light and held it close enough to the subject, without having my hand holding the light, in shot. I did this because I found using the light on the camera shoe with a macro lens, doesn't work as the light doesn't get into the lens and the exposure on the camera doesn't get any brighter. I might get another one or two and try that in the future to see if that adds enough light.
Bracket Fungi on branch
Bracket Fungi on branch (Close Up)
Another bracket fungi on fallen tree (Olympus 12-40 at 40mm)
If find that the best way to live life, is not in the pursuit of material possessions, but its to live in the pursuit of making positive differences to both other people and to the planet as a whole and if you can get others to do similar or the same, so much the better.
 DNature's gear list:DNature's gear list
Canon EOS 400D Canon EOS 500D Canon EOS 600D Panasonic GH5 Canon EF-S 18-55mm f/3.5-5.6 +9 more
Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic GH5
MNE Senior Member • Posts: 2,472
Re: Some Fungi with GH5 + Olympus 60mm Macro
A small LED light?  Brilliant idea (no pun intended:-). I will have to experiment,
great photos btw.
 MNE's gear list:MNE's gear list
Olympus OM-D E-M10 II Olympus E-M1 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-45mm F4 Pro +2 more
Gary from Seattle Veteran Member • Posts: 7,852
I like your images. Several are very colorful.
 Gary from Seattle's gear list:Gary from Seattle's gear list
Olympus E-M1 Olympus E-M1 II Olympus OM-D E-M1X Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 +7 more
Peter 1745 Senior Member • Posts: 2,022
Nice photos.
I sometimes find attaching the light source to the tripod and hand holding the camera is easier than having the camera on the tripod and hand holding the light. Depends on the circumstances of course.
Peter
'Keep taking the photos'
Peter Del Veteran Member • Posts: 7,988
I particularly like the colours in the first picture, but was wondering if it is upside down.
Peter Del
 Peter Del's gear list:Peter Del's gear list
Olympus OM-D E-M5 Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 Olympus M.Zuiko Digital 45mm F1.8 +5 more
DNature
OP DNature Regular Member • Posts: 310
Thanks everyone. I think I should have increased the colour saturation slightly on those before uploading as originally I took them in Adobe RGB and the colours looked better than they do here. If I get a chance. I am going to go out to see if I can find more fungi to take photos of in the area I found these.
enssorcel wrote:
Good to see fungi on the other side of the lens . I like projects like this using unusual and maybe 'boring' subjects. Usually turn out not boring at all like in your pictures
Well I am sure we all would rather have fungi as the subject in front of the lens, not on or inside the lens!
Peter Del
No, I found the fungi growing on a large branch, but couldn't photograph it where it was as it was covered partly by a fallen tree, so I took off the part of the branch with the fungi on it and laid it on the fallen tree and pointed my camera straight down on it and took that. The fifth image down is the same branch with the same fungi, only taken from a side angle.
DNature
Re: More Fungi on Nature and Wildlife Forum
I have posted more images of the fungi I took when I went back on Monday, on the Nature and Wildlife Forum if you would like to see more fungi I found here: https://www.dpreview.com/forums/post/60178870
