My first prints from my GH5 are a disaster! Where am I going wrong?
Started Sep 21, 2017 | Discussions
C Sean Veteran Member • Posts: 3,423
I'm very new when it comes to developing my raw files to JPEG. It's only in the last year or so I been shooting less JPEG and spending more time developing raw files. While I wouldn't call myself a newbie but in reality I'm more in the experimenting stage and gaining confident. More time I spend in Lightroom, better the results will become.
In the last twelve months I also have an interest in printing. I would rather have my best holiday photos in books and assessable rather than locked away on a hard drive. I had my photos from the trips to Botswana and Kenya printed into three books and the results were a mix bag. The pictures lacked definition and sharpness. The later attempts I increased the contrast and sharpness and the results weren't improved that much. The pictures were acceptable and because it wildlife shots, they weren't that bad but they weren't clean. They were graining, lack sharpness and definition.
What I was doing was going to Lightroom and exporting the pictures to be printed on shiny thick paper. I then use the Jessops Photo program to create book using the exported pictures.
A few weeks ago I went to Goodwood Revival which is a car show with vintage car racing. I used the GH5 for most of my shots and it has a 20-megapixel sensor and no AA filter. So the pictures from the camera will be sharper than say the GH4. My shots from the GH5 at a zoo are sharper than my pictures I took with the GH4 in Africa.
I had a good day at Goodwood Revival and I decided to get my pictures printed in a book. This time around I used less sharpness so I wouldn't have so much noise, not have as much contrast and use noise reduction to clean the image. The book came today and they're no different to my African ones. The pictures are covered in noise, there's no sharpness to them and there is no definition.
So logically I'm either doing something wrong or my Lightroom skills are terrible. However, during Goodwood, I used a custom setting not realising the custom setting is JPEG only not JPEG + RAW. Some of the pictures I used for the book are in camera JPEG and they have the same problems as the developed raw files converted to JPEG.
I am planning to go to a Jessops store and bring one of my photo books with me to find out where I'm going wrong. My thoughts are even with a Sony A7r mkII and a super sharp prime I would get me the same results. The other thoughts are I'm throwing away money and I probably better off using an one inch sensor camera and use a cheap printer. The pictures in the book look like it was taken with an old compact camera. My other thoughts that the pictures are being blown up. So maybe I need to put in the exact resolution in the export stage but even on the Jessops program the pictures don't look dull.
Any thoughts?
Panasonic GH5 Panasonic Lumix DMC-GH4 Sony a7R
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
No idea.
18
We need to see sample images, either full size or crops of critical parts from them.
It's impossible to make any suggestions without anything to look at.
Regards.... Guy
Mark9473 Veteran Member • Posts: 6,428
Re: My first prints from my GH5 are a disaster! Where am I going wrong?
C Sean wrote:
Any thoughts?
Show us some images.
Mark
 Mark9473's gear list:Mark9473's gear list
Canon G1 X II Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85 Panasonic G85 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +21 more
OP C Sean Veteran Member • Posts: 3,423
I'm having some problems uploading the images and it getting late. So I will give this a miss for now however I think I cracked it.
I been looking at the Export settings and comparing the noise in the pictures and my Goodwood photo book. Some of the noise in the pictures could be be cleaner and this could be part of the problem. However, I thought a 10 megapixel file should be big enough to hide some of the noise for a book roughly 300 x 400mm.
The other problem I need to calibrate the monitor because the pictures on the screen are brighter than the book but it doesn't make a huge difference.
For the image resizing in Lightroom Export. I haven't pressed 'Resize to fit' and left it as default. The only thing that I had changed is the 300 per inch believing the 10 megapixel will have 300ppi and the Jessops program would resize the file. This could be the problem because width and height are each 1000 but they not highlighted.
I thought this could be the problem as I was typing this out so I checked the files. They're big so the pictures aren't less than 1-megapixel files and been blown up.
I will try to upload some images.
When replying, just click on the "insert image" icon, second from the right. Select 'insert image from your computer' for best results.
Mark
bmoag Veteran Member • Posts: 3,389
If your images look good to you on a monitor then it would seem you are either not correctly saving them in the form the printer requires, presumably sRGB, or the printing service stinks. An image may look sharper than it really is when viewed on something like the small camera LCD but even a small laptop screen should reveal whether the image is seriously out of focus or affected by movement.
It may be a combination of both your processing technique and the lack of quality control by the printing service.
A way to test the printing service is to send them a batch of jpegs made in the camera and do not alter the files in any way. If they can not print them with reasonable accuracy you have solved part of the mystery. You can also send some files processed in your usual manner to a different printing service and see what you get.
A frequent contributor to these forums has a site digitaldog.net with exceedingly helpful videos to learn about color spaces, color management and sRGB conversion. I can not think of a better place to start if you want to optimize your processes.
 bmoag's gear list:bmoag's gear list
Nikon D70 Nikon D3300 Panasonic Lumix DMC-GX8 Nikon Z6
Here are some of the images used for the book.
3dwag
3dwag Veteran Member • Posts: 4,674
Excellent advice, and if you then post in the Printers and Printing forum you will get some sage advice, including from DigitalDog (but he may first direct you to one or a few of his videos 😉).
 3dwag's gear list:3dwag's gear list
Fujifilm FinePix Real 3D W3 Panasonic Lumix DMC-ZS50 Panasonic Lumix DMC-GM5 OM-1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +19 more
JaKing
JaKing Veteran Member • Posts: 6,300
I downloaded all three of your images. They appear to be oversharpened, causing noise-like artifacts all through them. Look specifically at the roundel on the Spitfire tail, the woman's skin and cuff of the safety jacket.
br, john, from you know where
My gear list and sordid past are here: https://www.dpreview.com/members/1558378718/overview
Gallery: https://www.canopuscomputing.com.au/zen2/page/gallery/
 JaKing's gear list:JaKing's gear list
Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ Olympus 12-100mm F4.0 Olympus E-1 +29 more
Danielvr Veteran Member • Posts: 6,860
9
STOP!
These book printers use equipment and automatic corrections carefully tuned and calibrated to make the best out of plain out-of-camera snapshots. Don't try to outsmart them - just process your raw files to full-size (!) JPGs that look good on screen and you should be fine. The photos won't look as bright as on your monitor because paper has a smaller dynamic range - but they should otherwise look very good.
Again, be sure to submit full-sized images - in the case of your 20MP camera I think that would be 5184 x 3888 pixels (smaller only if you have cropped them) - don't resize them and don't have them resized in exporting. From your description of what went wrong (grainy, no sharpness and definition) I suspect that this is where it went wrong. Maybe you can still return this book? Most suppliers seem to offer a satisfaction guarantee.
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
Torsten Hoff Veteran Member • Posts: 3,787
When you output files for printing in Lightroom, you need to make sure that you set both the dimensions and print resolution appropriately.
Let's say you want to output a file for a 6x4 framed print. Ideally you would find out the resolution that your photo printing service uses, and enter that in the DPI setting, along with setting the dimensions to 6x4 and entering inches as the unit of measure. Also set the paper type appropriately if you want to apply additional sharpening during the output phase. If you do these things, Lightroom can use the correct sharpening algorithm, and your image won't need to be resized by the printing service.
The other thing you'll want to do is disable all post-upload "enhancements" that the service may offer. Red-eye removal, contrast optimization and exposure correction will mess up what you are outputting.
Make sure you have JPEG compression disabled and are outputting at 100%, and if the service supports "quick uploads", don't use them -- this causes large files to resized and compressed in the browser before they are sent to the printing service.
Finally, check which color space(s) the service supports, and stick to that.
I personally use Snapfish to send gifts like framed prints, and they only support sRGB and output at 300 dpi. Using the guidelines above, I've gotten great results.
Agreed, and I think that overly strong noise reduction was applied before that (hence the loss of detail).
The woman's skin in particular looks pretty bad. You'll need to find a different balance between noise filtering and sharpening. If you could upload the RAW of that image to a file hosting site, perhaps a few of us could try a different raw developer to show the difference.
In general, if you're shooting raw anyway, it is better to "expose to the right" i.e. maximize the exposure without clipping the highlights, then reduce the brightness in post-processing for the desired result. Zebra's on the GH5 are very useful for that, but check that their default setting isn't too low (I set them at 100%).
Mark
Salik Tirmizi Regular Member • Posts: 100
Well i might have a solution for you watch this to setup your images for printing he has done a good job also he is fan of printing large sizes.
https://www.youtube.com/watch?v=ykOVVuFLsZA
ShatteredSky
ShatteredSky Senior Member • Posts: 2,065
I print directly from LR to an inkjet, and never had any problems via sharpness and noise even with "higher noise images" (I am still amazed how good the prints are, and how far home-printing has come). The only issue is getting the colours right, which I achieved after some test prints.
Seems that there is a problem with your photobook provider. The ones I sent also never had any sharpness/noise issues (they were made using the native software of the provider though). Or my standards are just too low ...
Regards
"Blue for the shattered sky"
 ShatteredSky's gear list:ShatteredSky's gear list
Olympus XZ-2 iHS Panasonic LX100 Olympus TG-5 Panasonic LX100 II Samsung NX300 +5 more
MatLD Regular Member • Posts: 491
Could it be the book paper/printer ?
Maybe your files are fine but the quality that you can obtain in the book is not what you think it is: I would suggest that you try to see a well printed book from Jessop to see if your expectations from the print are not too high.
Another idea would be to print a test shot on good shiny photo paper to see if the quality is any better.
brentbrent Veteran Member • Posts: 5,766
Those four images are all full resolution, 20MP files.  In your earlier post, you said you exported from LR with some setting to output 10MP files.  You should upload here some examples of the actual 10MP files that you sent to the printer to be included in the book.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
Sorry for any confusion, like I said in my opening statement I'm experimenting stage with Lightroom. It was my belief that after I converted the GH5's raw files to JPEG, they would be roughly the same size as the GH5 in-camera JPEG aka 10-megapixels. However, you pointed out the JPEGs I had uploaded to Dpreview are 20mb files and not 10mb.
There are a few things I want to point out.
1. The photo books actually come from CEWE which Jessops partnered with.  Also on their FAQ website, CEWE add additional sharpening to the images. This could explain enhance noise in some of the images. However, I need to look again but they didn't say about getting the right resolution before uploading to CEWE program.
2. The prints from the GH4 in camera JPEGs are sharper and on average are the better photos compared to the GH5 converted raw files in term of sharpness and definition. The GH4's in camera JPEG would be approx 8mb.
3. While the photos aren't terrible, actually some are but the likelihood it's my fault. The point is the images on my 4k monitor are acceptable but when it comes to print that they are worst.
4. The books I used for the Goodwood and Africa are the large landscape. So it only crop a small fraction off the bottom and top of the photo.
The conclusion I came up with is CEWE add additional sharpening which explain why the pictures has a lot of noise but there were noise in the original JPEG to begin with. The pictures from the GH4 in camera JPEG are smaller files but they came off better than the 20mb GH5 JPEGs so it look like I will have to downsize the images.
I will go to Jessops next week to see what actually going wrong. However, I had done google searches and there articles saying for printing upload the whole file without downsizing. In the world of compacts and now mobile phones, are they referring to them or the big lens interchangeable cameras?
You're confusing megabytes and megapixels. Do not downsize your images.
Mark
Noted
Thanks for the link. I will check it out soon. At the moment I'm Anthony Morganti videos on how to print images with Lightroom.
