18-55 VRii kit lens doesn't work on a D300S ??
Started 7 months ago | Discussions
vaughanB
vaughanB Senior Member • Posts: 2,718
Picked up a D300s on Ebay for my freelance work, 55-200VRii works fine, neither of my 18-55VRii lenses work on the D300S but work fine on a D5600 surprisingly ??, its not a big deal any ideas anybody ??
 vaughanB's gear list:vaughanB's gear list
Canon PowerShot G1 X Nikon D7200 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR II Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR II
Nikon D300S Nikon D5600
Cycletourer Regular Member • Posts: 284
Re: 18-55 VRii kit lens doesn't work on a D300S ??
G'day VaughanB,
have you checked that the firmware of the camera is up to date?
 Cycletourer's gear list:Cycletourer's gear list
Nikon D500 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S Nikkor 50mm f/1.4G Nikon AF Nikkor 135mm f/2D DC +5 more
vaughanB
OP vaughanB Senior Member • Posts: 2,718
Cycletourer wrote:
G'day VaughanB,
Firmware is up to date but thanks for the suggestion I hadn't checked, no matter, I need another lens in any case, strange, but it definitely doesn't work  thanks again
I think my next step would be to clean the contacts on both the lens and the camera body.
I've read in other threads of this fixing issues with lenses but don't remember if any of them specific to your body and lens.
I know the AF-P lenses had backwards compatibility issues but I've not heard before of any inherent AF-s problems like your describing simply for VR2 compatibility.
My money is dirty or worn contacts on the D300s body due to the lens working fine on your D5600
Look forward to your update.
Sagittarius Veteran Member • Posts: 5,259
Make sure the lens is properly seated. I had a lens which required a bit of additional effort to turn all way back to engage.
Best regards
 Sagittarius's gear list:Sagittarius's gear list
Nikon D810 Nikon D500 Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +4 more
Labe
Labe Veteran Member • Posts: 7,184
If its the AFS 18-55vrii that is collapsible, make sure it is fully extended all the around to 55mm before turning the camera on.
If its a AF-P lens then it won`t work correctly .
I`ve just got a sigma 24-105 f4 DG OS lens £599 new . lovely .
cheers Paul UK
 Labe's gear list:Labe's gear list
Fujifilm FinePix IS-1 Panasonic Lumix DMC-FZ300 Sony Alpha NEX-3 Sony a5000 Sony a6000 +1 more
vaughanB
cheers Paul UK
Thats it then, its an AF-P 18-55 and it doesn't work properly as you said    thanks
I mentioned the AF-P lenses in a previous post (as above).
Even a D7000 wouldn't have saved you and the D7100/D7200 lack full compatibility.
There are lots of threads about the AF-P lenses and their incompatibilities  within the forum.
Apologies, my copy of the AF-P 18-55 VR has no marking of VR11 or VR2 on it, so found it difficult offer a clearer answer.
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 14,288
Re: Now AF-P lens compatibility on Nikon bodies
https://www.nikonimgsupport.com/eu/BV_article?lang=en_GB&articleNo=000035705
Leonard Shepherd
Some say if some of your photos are not good the camera you use is only a recording device.
Nikon D810 Nikon D7200 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Micro-Nikkor 60mm f/2.8G ED +17 more
