jalywol
Re: Questions about Panasonic 100-300 lens
6
Charley123 wrote:
My professional photography does not reqiure any telephoto lenses longer than 60mm. Mostly, I use normal and wide-angle prime lenses for architecture and landscapes.
I'm currently wanting to shoot super telephoto of wildlife for fun. I have no prior experience with super telephoto or wildlife photography.
I've read the reviews of Panasonic 100-300 and 100-400 lenses. I know 100-300 is not as sharp as the 100-400, but would I notice the difference in sharpness at the sizes/resolutions I display photos at?
I display photos 8 x 10 print or 1280 x 920 on-screen. Never larger. I want to see good sharpness at those resolutions.
There are two answers to this question.
In absolutes? The 100-300mm, when used with care (using e-shutter when possible, keeping aperture at around 7.1, keeping shutter speed up, and not expecting miracles at above 270mm or so) can indeed give you excellent results. I used the original one for years, and after the first year learning how to get the most out of it, I had great results with it. I would not hesitate to recommend it as a place to get started with long teles, especially the version II, which has improved a number of performance weaknesses of the original (although optically both 100-300mms are still pretty much the same).
However, if you think you are going to want to shoot at the long end (300mm) all the time, and/or do a lot of cropping, then the 100-400mm will make a difference even for your lower resolution purposes. It also has better color rendition (although the 100-300mm is pretty good, the 100-400mm is better in that respect), and the 100-400mm has noticeably less CA on bright edges of things. The question is, are those differences enough for the extra $ and weight? For me they absolutely were, and I have been very pleased with the 100-400mm. For your purposes? Maybe not? Only one way to see, and that is to find a way to try them (rent or try in store, if there's one near you).
So, yes, you may see the difference in sharpness between the two, if you shoot long, wide open, and crop, or no, you may not, if you shoot shorter, stop down, and not crop.....
-J
