NX30 Dying Slowly
Started Sep 15, 2017 | Discussions
CagriY New Member • Posts: 10
NX30 Dying Slowly
I have already killed an NX30 before (mainboard fried for some reason) and I'm happily using my second now. Unfortunately, the image quality is slowly degrading. Images are less crispier and sharper. Shutter count is probably above 300.000. I use it in harsh weather conditions - including scorching hot deserts, extreme wind, high humidity and freezing cold. I have cleaned mud from all over the camera, I can feel the tiny sand particles scratching around dials, there may have been some rain as well.
So I think the sensor is getting dirty with enviromental factors. It's not a sealed camera after all. Although I made a habit of using the built-in vibration cleaning, it doesn't really help much.
Do you think I can save this machine? How should I proceed to clean the sensor? Or should I say my goodbyes
 CagriY's gear list:CagriY's gear list
Panasonic Lumix DMC-TS2 Samsung NX30 Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS
Samsung NX30
markyboy81 Veteran Member • Posts: 4,778
Re: NX30 Dying Slowly
Can you post any examples of the degradation in IQ?
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
If the sensor is dirty you relatively simply clean it using various kits available. But that tends to manifest itself  when shooting let's say sky and f/22 as dots or blotches.
Mr.NoFlash Senior Member • Posts: 2,374
With such abuse, clean the sensor, then let it slowly die
and buy a used one on ebay
CagriY wrote:
NX30 Dying Slowly....... Shutter count is probably above 300.000. I use it in harsh weather conditions - including scorching hot deserts, extreme wind, high humidity and freezing cold. I have cleaned mud from all over the camera, I can feel the tiny sand particles scratching around dials, there may have been some rain as well.
 Mr.NoFlash's gear list:Mr.NoFlash's gear list
Fujifilm FinePix Real 3D W1 Leica Digilux 3 Samsung NX300 Fujifilm X-M1
