Am I the only one that doesn’t like the Fujicron Trinity 23,35,50 f2 Lenses?
Started Sep 14, 2017 | Discussions
biza43 Forum Pro • Posts: 15,074
Re: Am I the only one that doesn’t like the Fujicron Trinity 23,35,50 f2 Lenses?
At the end of they, one has to choose based on the intended use. Often, people end up with both f/1.4 and f/2 version of the same focal length. If you often shoot in low light, reportage, street, where you need a higher light gathering capacity to get the shot, then a faster lens is useful. Personally, I think that the necessity of f/1.4 lenses in a world where one can shoot clean ISO 3200 or 6400 and still print big, is not as high as in the past.
Therefore, I am quite happy with the 23 f/2 and 50 f/2, they are appropriate tools for me.
50 f/2.
50 f/2.
23 f/2.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
Flying Fijian Senior Member • Posts: 1,623
Gary Martin wrote:
Fuji has diabolically made every lens they offer at least somewhat desirable for one reason or another.
Haha you could say the same about their bodies too!
BTW I'm also not a fan of the Fujicrons, had the 35 & 50 but sold them...love the 35 1.4 & the 56 1.2. Also got the x100v for the 23mm WR.
 Flying Fijian's gear list:Flying Fijian's gear list
Ricoh GR III Fujifilm X-E3 Fujifilm X-T4 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R +13 more
Miguel-C
Miguel-C Senior Member • Posts: 2,321
Sufstreet wrote:
Yes off course. The 1.4 is smoother and fades nicer.
This has been demonstrated to be false. If you pick the 35mm f2 and the 35mm f1.4 at f2 the bokeh roll off will be identical.
Neither are super smooth in busy backgrounds.
Cordial Regards
 Miguel-C's gear list:Miguel-C's gear list
Fujifilm X-T2 Canon EOS M5 Panasonic Lumix DC-S5 Canon EF-M 11-22mm f/4-5.6 IS STM Fujifilm XF 35mm F2 R WR +3 more
(unknown member) Regular Member • Posts: 389
I tried them both and I don't agree.
Everywhere is home
@sufstreet
@xftales
jjz2 Veteran Member • Posts: 4,396
It's not that I didn't like them... I did prefer the small size, and better AF, and silver color...and it was an initial affordable gateway for me into Fuji. I think I switched in 2017???
But ultimately wanted the faster versions of the 23 f2/60 2.4 especially (now have 23 1.4, 56 1.2) for portraits, and it also stopped me from going Full Frame.
For some reason, I really prefer the rendering of those 2nd gen lenses, more so than the initial 3, or newer lenses like the fujicrons... referring to the 14, 23, 56...
I like the focus clutch of the 14 / 23 also.
I finally feel "settled" on all my fuji lenses...now time to upgrade bodies haha...
 jjz2's gear list:jjz2's gear list
Nikon Z6 Nikon Z5 Nikon Z 24-70mm F4 Nikon Z 35mm F1.8 Nikon Z 85mm F1.8 +1 more
Miguel-C
Theres plenty of side by side comparisons on YouTube, are they all wrong?
Cordial Regards
Not sure how this would be, but maybe so... but the MTF curves are quite different, different central sharpness to out-of-focus edges on a tighter portrait. The 35 f2 if I recall, has a more even sharpness across the frame, whereas the 35 1.4 has more microcontrast in the center then dives into smoother, not so sharp edges, esp at the first few stops.
I had the 35 f2, the 35 1.4, and the 35 1.2 7 artisans all at the same time. I'm not a pixel peeper or know how to do scientific tests, but to me, they all had a diff "look" to them. I am kind of picky about color/bokeh though. Sure, it's subtle, as they are all the same focal length after all, but it was there.
I do agree neither have "Great" bokeh, but pretty good... The 56 1.2 is better than both, IMO.
There's millions of videos on YouTube explaining things. It does not mean they are right.
I don't follow charts and for me it's the printed photographs who are the end result.
The F2 has a different type of sharpness and rendering,  especially in B&W.
Everywhere is home
@sufstreet
@xftales
Miguel-C
My comment was simply in relation to the bokeh and background rendering. I understand the F2 lens is a bit more contrasty.
DoF differences aside, same rendering, same bokeh balls, same shapes, same everything.
You can't really refute image comparisons. What makes these comments worse is that perpetuates this myth that the 35mm F1.4 is a superlative lens, and whenever someone tries to describe why they use words such as "magic" "character" "feelings". I'm quite the one for scientific results, so abstract notions are meaningless to me.
Cordial Regards
That's just one photo! Lenses render different in different light, angles and depending on how far away the subject is etc... I've taken thousands of photos with the 35s and the difference is there no matter if you like it or not.
I believe in magic, soul and feelings. The 35mm1.4 had given me all that. Long before I read reviews.  And I've shot nice Leica lenses, Nikon, Canon, Sony etc. The XF35MMF1.4 is still my favourite lens of all time. On paper it looses to most fancy 35mm/50mm lenses.  But I believe whats ends up on a print when you can't zoom in and just enjoy the photographs,  that's where the XF35mmF1.4 shines.
Everywhere is home
@sufstreet
@xftales
roberthd12 Contributing Member • Posts: 872
The 50mm f2 is the favorite lens I own, among many. The images are wonderful, bokeh is great, construction is good, and not too expensive. Focuses fast, too. To each his own, I guess.
 roberthd12's gear list:roberthd12's gear list
Fujifilm X100F Fujifilm X100V Olympus PEN E-PL1 Fujifilm X-Pro1 Fujifilm X-T1 +12 more
Miguel-C
Rendering is rendering, I never had a lens change its rendering based on conditions. Rendering is optics based, not conditions based. This image is taken with the same lighting, same distance to subject and same color profile. If there was a difference in rendering it would show.
And if your lenses change rendering based on light conditions then i would say you have a faulty lens. Bokeh balls, light roll off should be consistent otherwise it would be difficult to determine which lens to bring to a job. If a lens struggles with flare, it will always struggle. If a lens has onion shaped bokeh balls, they will always be there. It doesn't change if its a cloudy day, haha.
That's fine, but not really relevant to the conversation. We are comparing apples to apples, and these apples look the same.
If you printed that image above, both out of focus areas would look the same, and that's the point. Your statements are very broad that say more about your attachment and enjoyment with a lens more than its actual quality.
And i hope you don't misunderstand my tone, its great that you prefer the f1.4, many here do. But i hope members of this forum also understand the difference between abstract statements and verifiable comparisons. Otherwise we may be talking with Flat earthers.
Cordial Regards
Nirurin Senior Member • Posts: 1,152
Not really part of this discussion, just read the thread out of curiosity but... you keep saying both those photos look the same, but they don't... the 'bokeh' / out of focus areas look pretty different. Different parts of each have different characteristics. If you think they both look identical, then it may just be that you have a much wider tolerance of what you 'like' compared to other people.
I think they both look fine, but I can also see they're both different enough that I would be able to pick a favourite. And thats an image where the background is very separated so it's a best-case-scanario,  I know from experience a lot of Fuji lenses will fall apart as soon as the background is slightly within the focus area (extremely jittery and 'nervous' bokeh is a common problem with fuji lenses for some reason).
(unknown member) Forum Member • Posts: 58
Hello nice to be back ....
Nope you are not the only one ....
I tried a couple of them and to me they are a poor cousin to the faster primes.
As for weather resistance I've used the faster lenses in some pretty rough conditions weather wise and have never had a problem.
I love the 50mmf2 by far my favourite of the F2s,  but we where talking about the XF35MMF2.  Which is 50mm equivalent to Canon,  Leica, Nikon etc.
Everywhere is home
@sufstreet
@xftales
Rakosky Regular Member • Posts: 289
They render slightly different, 35 f2 has more contrast, digital look than 35 1.4. In my opinion 35 f2 is a good lens but the worse of the bunch of Fujicrons. Best fujicron is 50, then 23, 16 2.8 and 35 f2 (assuming 90 f2 isn’t a fujicron).
 Rakosky's gear list:Rakosky's gear list
Fujifilm X-Pro2 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R Fujifilm XF 35mm F2 R WR +4 more
