E-M1 Mark II + ED 75-300mm II combination (pics inside)
Started Sep 12, 2017 | Discussions
JohnGR
JohnGR Forum Member • Posts: 96
7
Hi all,
Having seen the lens for some time, I would like to share some images on the combination of the two. The lens seems to be given its price and specifications quite capable with good image quality (at least my copy is).
I found also that image stabilization works much better in position IS-auto than at IS-1.
Overall i am quite happy with the combo.
All images processed to taste with ACR
 JohnGR's gear list:JohnGR's gear list
Pentax K-3 II Olympus E-M1 II Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8 Pro Pentax 16-85mm F3.5-5.6 WR +2 more
Fujifilm FinePix IS-1 Olympus E-M1 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II
aodi
aodi Senior Member • Posts: 1,678
Re: E-M1 Mark II + ED 75-300mm II combination (pics inside)
Excellent IQ.
Anatoli
www.transformingphoto.com
Skeeterbytes Forum Pro • Posts: 23,182
I've seen dubious resolution from this lens in the past and these are anything but, so well done!
Rick
JohnGR
OP JohnGR Forum Member • Posts: 96
aodi wrote:
Excellent IQ.
Thank you Anatoli.
Zephir 750 Senior Member • Posts: 2,039
Nice set. Regards, Joseph
 Zephir 750's gear list:Zephir 750's gear list
Canon EOS 50D Leica M8.2 Olympus E-1 Olympus E-3 Leica M9-P +19 more
Jeff4500
Jeff4500 Senior Member • Posts: 1,921
Very nice work, and my 75-300II works as yours. This lens is unforgiving of improper use. Kept mine when I got the PL100-400 as a long travel lens.
Jeff
 Jeff4500's gear list:Jeff4500's gear list
Panasonic 12-35mm F2.8 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix DC-GH6 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +9 more
Vikramdev Rao Regular Member • Posts: 184
I agree. The price for the combo is very good value. A few of my photos with the 75-300 II taken in Kenya are attached for your viewing and comments
 Vikramdev Rao's gear list:Vikramdev Rao's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +2 more
aodi
Excellent set!
Anatoli
JohnGR
Thanks Joseph
Baenwort
Baenwort Regular Member • Posts: 123
I do wish they would release a weather resistant version. I don't want to give up Pro Capture and other special features of the EM1.2 by getting a non Olympus lens.
Threads like this just make me wish harder.
 Baenwort's gear list:Baenwort's gear list
Olympus 14-150 F4-5.6 II Fujifilm X100S Olympus E-M1 II Sigma 16mm F1.4 DC DN (MFT)
Thank you
JohnGR
Very nice shots.
John
JohnGR
Hi Jeff,
I totally agree with you. The lens is capable for very good results but requires very careful handling. Even minimal movements cause blurry images especially at the longer edge.
Regards
John
JohnGR
Handheld SOOC
Very clean atmosphere.
BigMacIain
BigMacIain Regular Member • Posts: 476
Care to say more, Jeff?
"If it's not fun, why do it?” - Jerry Greenfield
 BigMacIain's gear list:BigMacIain's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +2 more
Jeff4500
Jeff
It's a 600mm EQ fov light lens and even with IS you need to use good technique. The DOF requires proper focus setting which may differ from your normal settings. Take a look over at 43users and look at the native image forum and see the 75-300 images posts - lots of great images.
BigMacIain
Well, that's what I was hoping you would elaborate on. The reason I asked is that I spotted your post just as I was on my way out the door to trade-in my 4/3 70-300 for a spanking new 75-300. What do you consider good technique? And can you say are about proper focus setting for DOF? (I don't get to play wth my new toy until tomorrow, so I can read up on it tonight.)
Iain
Jeff4500
Take a look at these links:
For Images
For me it's small focus box, 1/1000mm without IBIS and 1/600 with IBIS, squeeze shutter like shooting a gun, use shutter speed and let fstop float. When below these shutter speeds lean against something if you can.
Jeff
BigMacIain
Thanks, Jeff. I wasn't aware of that other website.
Everything you say makes sense and is technique I've been using for a long time; left hand supports the camera and cradles the lens (I do wish our modern lenses still had the aperture control on the lens rather than the camera) with the right just operating the shutter, and both elbows braced against the ribcage -- breathing out while firing the shutter. I hadn't thought about the floating f-stop. I came to digital from my OM-2 and as a result, I don't think I've ever knowingly used the camera in shutter-priority mode. I don't normally shoot moving objects (or at least, I don't set out to) but the advice to use the electronic shutter is also well made.
Thanks again,
Iain
JohnGR
Some new shots. I found also that the C-AF with this lens works very well with firmware 2.0.
I hope you like it.
