Panasonic 100-300mm II may not be splash proof
Started Sep 5, 2017 | Discussions
pannumon Veteran Member • Posts: 4,130
Re: Rinsing it is not a splash i think?
Wasabi Bob wrote:
https://www.usatoday.com/story/tech/2014/12/18/phone-drying-systems/20212889/
Looks like USA Today ran the same story.
Rice is not the answer
Actually, they are not saying that rice does not work. They are saying that the system(s) they are trying to sell are better. I am pretty sure that they are right.
Still, rice seems to be a valid first aid in many situations, because it is readily available, simple to use, cheap and applying it does not have any special requirements such as electricity.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
drj3 Forum Pro • Posts: 12,632
Re: Panasonic 100-300mm II may not be splash proof
Wasabi Bob wrote:
drj3 wrote:
LMNCT wrote:
"Splashproof" is not listed under the specs for the 100 - 300 II. Guess you destroyed your own lens. The 100 - 400 is "Splashproof, but reasonable care should still be taken.
It takes about one minute to go to the Panasonic web and find
"Upgraded support for harsh weather conditions (Splashproof / Dustproof).:
http://shop.panasonic.com/cameras-and-camcorders/lumix-camera-lenses/H-FSA100300.html
Define "splash"?
If you order a drink at the bar and tell the bartender "with a splash", is that much water? Trust me, you are playing a game of semantics in what will likely be a loosing game.
Unless you see "water proof", you are only getting a small advantage, most likely very effective against condensation. And even with waterproof, the list of maintenance requirements is quite long.
If I through a quart of water at you, is that a "splash"?
I do understand that the equipment is not water proof and that it is unlikely that the manufacturer will repair a lens with salt water intrusion.  However, if the lens cannot withstand the splash of ocean water or a moderate amount of water on top of the camera, then, one may as well treat all cameras as not weather resistant.
I have had my Olympus E5 & E-M1.1 with the 12-60 and 50-200 SWD on the beach with ocean wave splashes, I have used both in moderate rain and both have had trips to a gentle running shower with no problems.  I am very careful not to zoom the lenses, without first wiping excess water from the zoom barrel or not zooming the lenses.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
Michael Meissner
OP Michael Meissner Forum Pro • Posts: 28,013
Update: Rice did not work
I suspected the rice would not work, and it didn't.
I'll take it in to Sanford Camera repair (in Arlington, MA) to see if they can fix it.  I suspect I will have to wind up sending to Panasonic repair in McAllen Texas.
Unfortunately, since McAllen is south of Houston, I don't know how the recent hurricane effected them.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
Michael M Fliegel
Michael M Fliegel Veteran Member • Posts: 3,683
Re: Update: Rice did not work
Just send it to Panasonic.  Sorry for your troubles.
 Michael M Fliegel's gear list:Michael M Fliegel's gear list
Olympus E-520 Olympus PEN E-PL2 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 14-42mm 1:3.5-5.6 +13 more
DDWD10
DDWD10 Contributing Member • Posts: 859
FWIW I've used my 100-300 II in a light drizzle for a few minutes to photo/video a family of bears at Yellowstone.  No issues, but I just wiped the barrel dry with my t-shirt before I retracted it.
 DDWD10's gear list:DDWD10's gear list
Pentax Q Panasonic Lumix DC-G9 Panasonic S1 Panasonic Lumix G Vario 7-14mm F4 ASPH Pentax 01 Standard Prime +9 more
Michael Meissner
Though there is a bit of difference between rain and salt water.  If it had just been rain, I would have done the same.  But with salt, it is important to try and get the salt out of the system.  But what's done is done.
As I said earlier, even if what I did caused it, I no longer have the trust in Panasonic's weather sealing on lenses and will only get Olympus sealed lenses in the future.
Gerry Siegel
Gerry Siegel Veteran Member • Posts: 3,244
One of the reasons I may, just may, be interested in the new Sony miniature model that fits in the palm of a hand.  Total waterproof and shockproof.  It may not be good for whale watching but it would be useful in a downpour and to have on hand for day to day stuff.  I am sorry the lens is funky sounding....with luck it will not cost you much except the nuisance factor.  I like the quality of Lumix product.  Never have stress tested them.  Live and learn I guess. Good observations here from others.
 Gerry Siegel's gear list:Gerry Siegel's gear list
Panasonic ZS100 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 +4 more
Wasabi Bob Contributing Member • Posts: 680
1. McAllen was not effected by the storm.
2. In most cases they will not repair water damaged products, especially lens, since related corrosion can takes months to occur. I was told that long term reliability could not be guaranteed. They will usually offer you a good deal on a factory refurbished lens.
In my opinion,. that's a very honest approach. I'd be very upset if a repaired product failed shortly after it was repaired.
Michael Meissner
Thanks for the info.
FrankS009
FrankS009 Veteran Member • Posts: 6,557
I found my lost (5 weeks) GF1 and 20mm 1,7 in a snow bank, and put them in rice for 2 and a  half weeks. They were fine.
F.
"We shoot the things that move us in ways that will move others." David duChemin
"What's the use of having a great depth of field if there is not an adequate depth of feeling?" - W. Eugene Smith
 FrankS009's gear list:FrankS009's gear list
Michael Meissner
In this case, given it is salt water, it may be more problematical than normal water damage.  I've seen many people who recovered electronic gear with just rain/snow/etc. using rice or other methods to dry out the camera.
FWIW, the lens was working fine while it was getting splashed.  So perhaps it was the rinising off, perhaps something else.
lcubed11 Contributing Member • Posts: 985
when we went to vietnam in 2014, my gh-4 w/ 12-35 f2.8 lens took a swim in halong bay.
1 meter for more than 30 seconds, definitely salt water.
everything except the polarizing filter was just fine after a fresh water rinse.
my iPhone 3 was not as fortunate.
 lcubed11's gear list:lcubed11's gear list
Canon PowerShot S5 IS Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GH4 Panasonic Lumix DC-G9 +11 more
spike29 Senior Member • Posts: 2,471
drj3 wrote:
......... I am very careful not to zoom the lenses, without first wiping excess water from the zoom barrel or not zooming the lenses.
beside's the unfortunate event of a ruïned 100-300mmii, what's the point of a moderate rain waterresistant lens if you can't use the zoom barrel freely? ( it is my first rw set by the way g80 12-60mmkitlens)
offcaorse you don't  dangle the camera+ lens when rain is  poring down just outside your own rainprotecting clothes. And  keep it as dry as posible but stil if you need to make a image you don't want to need to remember to use your feet as zoomlever....
knowledge is adictive, every time i get some i want more.....
 spike29's gear list:spike29's gear list
Fujifilm FinePix F70EXR Panasonic Lumix DMC-FZ200 Panasonic G85 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH +2 more
i think i've violated all of these rules since i tend to use my trio of panasonic splash proof lenses and GH4 in torrential conditions.
well if they still work the WR is quite good then. and also zoom in and out wile water is dripping of the barrel?
I am not experienced in WR gear and don't want to find out the border of the resistance the wrong (money costing) way.
MarkDavo
MarkDavo Senior Member • Posts: 2,458
My local store had a near mint Panasonic 100-300mm mark II lens for sale, and I bought it on Saturday to add to my weather sealed lens collection (Olympus 12-50mm, Olympus 12-40mm, Olympus 14-150mm mark II, Panasonic 12-60mm [G85 kit lens], plus the classic 4/3rds lenses 11-22mm, 14-54mm, 50-200mm, and 50mm).
I went on a whale watch on Monday (US Labor Day), and had the 14-150mm mark II mounted on the E-m1 mark I and the 100-300mm mounted on the G85. While the day was sunny, we got splashed quite a lot.
I had distilled water in the car to rinse everything off, and later rinsed everything under the tap once again to get any salt off the gear.
The E-m1 mark I works fine. The 14-150mm mark II works fine. The G85 works fine. They've been on whale watches before. However, the 100-300mm mark II unfortunately makes a loud buzzing when I turn it on.
So, I'm putting it in a sealed box with uncooked rice for a few days to see if the rice can draw out the water. Hopefully it will work, otherwise I will probably need to find where the Panasonic lens repair facility is. Bummer.
Michael,
I recently bought the 100-300 zoom (severe GAS attack to supplement primes) and while I'm sorry to hear of your predicament I thank you for the information. I otherwise have E-M1.2s and all Oly PRO lenses and so will be very careful on a two-week birding trip along the south coast of Western Australia where some spring rain is always around the corner.
I hope the repair is quick and inexpensive.
Cheers, Mark
Always asking
 MarkDavo's gear list:MarkDavo's gear list
Olympus OM-D E-M1X Canon EOS R5 Canon RF 100-500mm F4.5-7.1L IS USM +1 more
453C Veteran Member • Posts: 7,087
I think it's more of a question of preventative measures.
At some point, every seal will fail, and some of the seals used on "weather sealed" camera gear isn't exactly SUBSAFE grade. I know my WS gear should be able to handle the conditions I use it in, but I still carry it in a bag that's been treated with water repellent, or in a true waterproof bag. Why tempt fate?
For more on the perils of "weather sealing", here's a LensRentals article worth a read.
mg_k Veteran Member • Posts: 3,221
OP has got my chance imo.
As soon as Panasonic opens the lens and see salt deposit inside it's over and done.
 mg_k's gear list:mg_k's gear list
Ricoh GR Canon EOS R Canon RF 24-105mm F4L IS USM
Maybe, but it's also possible that the freshwater used for cleaning entered, which would be better all around. Salty water isn't very nice, no matter who gets the bill.
Re: i can understand that a seal is wiping of water but not the moist of the barrel
If i think of the carscreen wipers the drops are gone after the sealrubberstrip but the miccroscopic film of water not, i think. (window is still wet) thats why the wipers start squeeking when the window gets dry.
So  i could think of the same system when the barrel moves the drops are wiped off but the moistfilm is going inside the outerlensbarrel wile the inner barrel retracts?
In this matter only a innerzoomsystem can be truly waterresistance because of  the static seals.
So if i follow this theory WR means Dust resistance wile zooming and raindrop resistance wile you don't retract the barrel when wet.
Good to know when i go for a walk and it starts to rain and i still want to make pictures.
