Re: Rinsing it is not a splash i think?
Wasabi Bob wrote:
1. In this weekend's local paper (The Record - Bergen County, NJ) there was an article that confirmed the myth about rice - it does nothing to dry out your device. The same results can be achieved by letting it sit, unused, for the same time. The proven method is to have the device in a vacuum chamber, with a temp of about 175F for abt 30 min. Two companies are offering this for phones.
Do you have a link?
2. Panasonic's lens are "Splash Resistant" - not Splash Proof, not "Weather Sealed". The IPX rating suggests it is designed to survive the morning dew. More important, any testing uses fresh water - NOT salt water.
Keep your fingers crossed.
Note, i went to the Panasonic USA web site, and here is the quote about the 100-300mm mark II:
Brave the elements in nearly any kind of weather or shooting location. This lens features a splash/dustproof construction* that is tough enough to withstand even heavy field use. It protects the lens system inside from sand, rain and more, making it perfect for shooting under harsh conditions. Now there is nothing holding you back from capturing the creative nature or landscape shots you want.
*The lens supports this feature in conjunction with splash/dustproof LUMIX cameras.
And here is what the manual has to say:
Lens Care
Please read these instructions carefully before using this • This lens has a dust-proof and splash-proof product, and save this manual for future use. construction. When using it, please be careful of the following. If the lens is not working properly, consult the dealer or your nearest Service Center.
- Please attach the lens to a dust-proof and splash-proof digital camera.
- When detaching the lens from the digital camera, take care to ensure that sand, dust, splashes of water etc., do not get into the lens or the terminals.
- This lens is not waterproof and cannot be used to record underwater. For splash-proofing, the lens is constructed to resist the entry of water. If splashes of water etc. do adhere to the lens, wipe after use with a soft dry cloth.
- To improve the dust-proofing and splash-proofing of this lens, a lens mount rubber is used in the mounting portion. After changing the lens a number of times, you may find that the lens mount rubber has marked the mount portion of the digital camera body, which does not affect its performance. For information on changing the lens mount rubber, contact your nearest Service Center.
- Do not press the lens with excessive force.
- When there is dirt (water, oil, and fingerprints, etc.) on the surface of the lens, the picture may be affected. Lightly wipe the surface of the lens with a soft, dry cloth
before and after taking pictures.
- To prevent dust and other particles from accumulating on or entering the lens, attach the lens rear cap when the lens is not in use.
- To protect the lens contact points 1, do not place the lens with its mount surface facing down. In addition, do not allow the lens contact points to become dirty.
Note, I had the lens on the G85. Being a non-lawyer, I would certainly interpret that as being able to withstand strong splashes. Now, it doesn't mention salt water, but I would certainly argue that 'creative nature' type shots include shooting by the ocean.
In any case, I suspect I will go back to buying Olympus weather sealed lenses.
My next big purchase is going to probably be a wide angle lens, and I had been trying to figure out whether it would be the Olympus 7-14mm or the Panasonic-Leica 8-18mm. For now, it moves me to the 7-14mm camp.
