Panasonic 100-300mm II shutter shock on Olympus
Started Sep 1, 2017 | Discussions
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,013
I noticed my camera store has a used Panasonic 100-3mm mark II in stock, claimed to be in mint condition. My salesman will be holding it for me, and I will go in Saturday or Sunday to check it out. Just to be clear, this is the mark II that is weather sealed, and not the mark I.
I've seen some references to shutter shock on Olympus bodies. Could somebody list what to look for with SS? I have 2 main bodies (Olympus E-m1 mark I and Panasonic G85), but occasionally I may drag the E-m5 mark I or E-pm2 out of semi retirement, but for the moment consider the E-m1 mark I and G85 will be the only 2 cameras I would use the lens on.
I assume I probably don't have to do anything with the G85.
For the E-m1 mark I, I see using either 0 second anti-shock or electronic shutter to be the recommended practice for this lens. Now, I've tried the electronic shutter after the E-m1 mark I firmware came out, and I didn't like it too much (too much subject movement for the quick tests that I did). I don't recall if I'm using anti-shock at this point.
If push comes to shove, I could always just use it on the G85 (where the dual IS and DFD options of the lens would be used). I would prefer whatever option used on the E-m1 is one that I could use all of the time.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
Olympus E-M1 Olympus OM-D E-M5 Olympus PEN E-PM2 Panasonic 100-300mm F4-5.6 II Panasonic G85
Chrisd999
Chrisd999 Senior Member • Posts: 1,365
Re: Panasonic 100-300mm II shutter shock on Olympus
If you are concerned about SS, electronic shutter is the way to go. I use it whenever my EM1.2 allows me to use it (it is blocked in some cases with long exposure and with Hi-Res I believe), and I've seen no issues with it so far. I use it with my PL100-400, no issue, no risk of SS.
 Chrisd999's gear list:Chrisd999's gear list
Sony a7R V Venus Laowa 12mm F2.8 Zero-D Sony FE 200-600 F5.6-6.3 Sony FE 12-24mm F2.8 GM Sigma 85mm F1.4 DG GN +7 more
drj3 Forum Pro • Posts: 12,632
The electronic shutter on the E-M1.1 will be fine for stationary targets.  It is not good for things that are moving with any great speed.  I used it exclusively for stationary birds, landscape, flowers, people (not moving), but not for BIFs or with artificial light.  The zero anti-shock is better than the normal mechanical shutter for shutter speeds below 1/320, but according to Imaging Resource, not as good as the Electronic shutter for stationary photography.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
Michael Meissner
OP Michael Meissner Forum Pro • Posts: 28,013
Yeah, I remember getting the movement effects when I tried the electronic shutter on moving targets.  Thanks.
Michael Meissner
I bought the lens
I bought the lens for $469US with taxes bringing it up to $499. Now we'll see how well it works.
