Getting Even Closer - Macro for Oly EM5?
Started Aug 29, 2017 | Questions
Webreaper
Webreaper Regular Member • Posts: 157
Hi all,
My wife does a lot of macro photography. In particular, she does some bug photos, and some photographs of plants, such a miniature orchids. We have the superb 60mm Oly f2.8 macro, and it's wonderful, but we're starting to get to the point where she wants to get even closer to subjects, and are finding that we'd like something with more magnification and (potentially) a shorter focal length.
Here's a couple of sample pictures she's taken with the lens so far:
Hoverfly: http://www.pumpkinbeth.com/wp-content/uploads/2016/09/B7179796-1024x683.jpg
Hoverfly: http://www.pumpkinbeth.com/wp-content/uploads/2016/09/B8112534-1024x683.jpg
Lepanthopsis astrophora 'Stalky' flower: http://www.pumpkinbeth.com/wp-content/uploads/2016/02/A2050150-1024x683.jpg
Platystele flower: http://www.pumpkinbeth.com/wp-content/uploads/2017/04/B4137471-604x270.jpg
Note that the flowers in the last two images are tiny - the last image is a tight crop of a flower that's about 1-2mm long.
But we want to see if she can get even closer, maybe getting full frame pictures of the miniature orchid flowers. The question is, is there a macro available that will fit the Olympus body with even more magnification? And if not, what other options do I have?
Cost is a factor, but for the purposes of research, let's assume it's not. That said, I don't want to have to buy all new bodies, etc.
Thanks!
SiFu
SiFu Veteran Member • Posts: 6,375
your options...
Hello!
... are:
1/ adapting a lens that is designed for shooting beyond 1:1 (Canon MPE65, Minolta 1x-3x zoom lens) - a hassle free experience, not necissarily the best IQ;
2/ adding a diopter lens (fits on the front of your lens); Raynox DCR250 as a budget option, any other high quality two lens diopter designed for use with a 60mm lens - the most budget friendly option, the impact on IQ is moderate, but your close-up potential is limited;
3/ a TC - fits between body and lens (a 2x TC will give you 2:1 instead of 1:1); has some advantages such as doubled working distance at 1:1 and same working distance at 2:1), quality is depending on the TC used, limited close-up potential;
4/ lens reversal (on the body, on another lens) - budget friendly and potentially great IQ depending on the lens you use - limited by the working distance once you turn to the wider lenses;
5/ a dedicated bellows / modular extension setup - potentially best IQ and flexibilty possible with a vast selection of lenses from all ages and price ranges. Potentially more cumbersome to manage and handle.
Best,
Alex
carpe diem, quam minimum credula postero
Webreaper
OP Webreaper Regular Member • Posts: 157
Re: your options...
Thank you. I have a x1. 4 TC for our telephoto and have been impressed with it. I don't think it fits any other lenses though. Can you recomment any that would work well?
I read about diopters last week, but the impression I got was that they were really for underwater work. Again, any recommendations?
SiFu
Re: your options...
Hello!
If your TC does (physically) fit the macro lens, it would give you a slight boost (x1.4) putting you pretty much in between life size (1:1) and double lufe size (2:1) - btw, the FOV of 1:1 is allready "closer" on MFT.
Unfortunately I don't have experience with MFT TCs, as I don't like that option myself. Maybe others can help rearding compatibility with the 60mm.
Diopters (closeup addon lenses) I recommended through own use are the Raynox Diopters (the 250 being the cheapest, Canon 500D and 250D as well as the old Nikon 5T and 6T diopters. Strength and suitabilty for different focal lenghts do vary. I would start with the Raynox DCR250, especially since the closeup potential is limited with diopters as well
Best,
Alex
Webreaper
Re: your options...
The 1.4 TC I have is the one for the 40-150 f2.8 pro lens, and it only fits that lens, sadly.
There's a couple of TCs that look like they might fit, including this one:
Olympus ZUIKO DIGITAL EC-20 Tele-converter https://www.amazon.co.uk/dp/B000XCRE8G/ref=cm_sw_r_cp_apa_CjCPzbXFSZZZC
But it's not clear how good quality it is. I'll have to do some research, and will also look into the Diopter you mention. Thanks again!
will focus
will focus Senior Member • Posts: 2,640
Re: Getting Even Closer - Macro for Oly EM5?
Have you seen this thread?
https://www.dpreview.com/forums/thread/4198022
There are a few images in there that were taken with the 30mm that might be right up your alley.
 will focus's gear list:will focus's gear list
Sony a7R II Olympus OM-D E-M10 II Sony a7R IV Sony 70-200mm F2.8 G SSM II Sigma 24-70 F2.8 DG DN +1 more
Okapi001 Veteran Member • Posts: 5,145
Re: your options...
EC-20 is for the older 4/3, not for the m4/3 mount.
However, you can use MC-14 with a 60mm macro, if you add macro extension rings between the lens and the teleconverter. With a standard pair if extension rings you can get to approx. 2.5x magnification.
You can get even more magnification with a 30mm macro, but you have to come closer to the subject.
https://www.dpreview.com/forums/thread/4062331
 Okapi001's gear list:Okapi001's gear list
Olympus OM-D E-M10 II Olympus PEN-F Olympus E-M1 II Olympus OM-D E-M1X OM-1 +18 more
Webreaper
Yep, I saw that, but not sure if it gives more than the 1:1 zoom I'm already getting with the 60mm.
SiFu
Re: your options...
Hello!
TCs always have an impact on IQ in my experience (with Nikon, Canon, Sigma and third party TCs of the past) - and I doubt that even a 2x TC will be enough for your needs (2:1 is not THAT close after all).
You can always fake and optimize a micro zoom (like the Canon MPe65) using an old OM adapter plus the old OM-zoom extension tube and a Macro/bellows lens of your choice - you can go really close depending on the lens used and it is sort of a more solid, short bellows solution. Here is one of my setups for illustration purposes on another subforum here (depicted on a N1 body, I do use it on all of my cameras though) with an old Canon 35/2.8 macro bellows lens (one of THE best beyond 2:1 and relatively inexpensive):
bottom right is 2:1 btw
Best,
Alex
will focus
I think it does. If I read it right it's 1.25 or 2.5 in a 35mm equivalent...
http://www.getolympus.com/us/en/m-zuiko-ed-30mm-f3-5-macro.html
Webreaper
Re: your options...
Will the EC-14 fit? That seems a good option, and the IQ seems reasonable given the cost.
SiFu
Hello!
It is only 1.25:1 other than 1:1 - not that big a thing imho.
Best,
Alex
Webreaper
Re: your options...
Oh wow, just seen that thread about the guy with the extension tubes. That looks awesome, and relatively cheap to try with my existing TC. I'll give that a go!
will focus
SiFu wrote:
Hello!
Best,
Alex
I think that's what I posted, no?
SiFu
Hello!
I don't know, did you? (it seems so). That is the problem with flat view and posting at the same time as someone else on this site imho. You never know where you end up.
Best,
Alex
Skeeterbytes Forum Pro • Posts: 23,182
For the tiny blooms she could do well with one of these .
For the bugs, might be worth investigating one of the bodies that does focus bracketing with the 60mm. She seems quite close but doesn't have enough DoF.
Rick
Webreaper
Nice. I guess that's fixed focus though, so per the other thread makes things that move more challenging (although for the flowers it would work).
Going to start with my MC-14 and extension tubes. I presume I'll need one for each side where it sticks out? £45 seems a cheaper experiment than £400 for a new lens. 😁
will focus
SiFu wrote:
Hello!
Best,
Alex
I know. I had to go back and check myself. I thought I may have inadvertently  posted the 35mm equiv ratio for the mft instead of the other way around. I did post the oly link for the lens, so they have the specs there.
Webreaper
Ooh, that looks tempting....
I suspect that might just be the settings, I think the two bug pics might have been taken at f2.8-f4.5; we've got some others taken at f14-f22 where the DoF covered the entire insect and looked much better. But I hasn't heard of focus Bracketing, so will read up about that too, thanks!
Love macro photography, it's just so interesting!
will focus
It's not fixed focus. It is auto or manual focus, just like the others. You can use it in either mode. I had just made a suggestion of setting it in manual and moving the camera in and out for my next slug portrait because the auto focus was chasing the little guys rounded body all over the place. But the auto focus nailed it a couple of times, so I'm happy. I'm just getting to learn the lens. Your wife is probably better than I at technique so I'm sure she'd probably get more out of it.
