85/1.4 vs. 85/1.2 MTF charts
Started Aug 29, 2017 | Discussions
J A C S
OP J A C S Forum Pro • Posts: 14,028
Re: 85/1.4 vs. 85/1.2 MTF charts
J A C S
full resolution sample
mordor_74 Contributing Member • Posts: 615
Re: full resolution sample
I think i could make myself a reason of that sharpness wide open!
STM Trinity in progress! 18-55+55-255+24 Actually
http://samsungnxtips.blogspot.com
 mordor_74's gear list:mordor_74's gear list
Sony Cyber-shot DSC-HX5 Canon EOS Rebel SL1 Samsung NX1100 Samsung NX 30mm F2 Pancake Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) +7 more
Powerdoc Veteran Member • Posts: 3,496
J A C S wrote:
85/1.4 http://www.canon.com.hk/en/product/catalog/productItemDetails.do?domainID=10010&prrfnbr=201243
85/1.2 II http://www.canon.com.hk/en/product/catalog/productItemDetails.do?prrfnbr=10256
How to read an MTF chart
Not as good as the 35LII:
Thanks for the MTF charts
According to canon engineers this lens is a balance between bokey and sharpness.
It's all about photography
 Powerdoc's gear list:Powerdoc's gear list
Fujifilm FinePix X100 Fujifilm X-Pro1 Canon EOS 6D Panasonic Lumix DMC-GX7 Fujifilm X-T1 +35 more
pokesfan
pokesfan Contributing Member • Posts: 500
Looks good!
This is much easier to read than a chart. I don't see any deficiency with sharpness or bokeh rendering. They could use a better photographer however, judging from the set of sample images
Now can we move the shipping date up to September, so we can actually use this lens during wedding season?
 pokesfan's gear list:pokesfan's gear list
Fujifilm X-T2 Canon EOS 5D Mark IV
Tazz93
Tazz93 Senior Member • Posts: 2,076
From the samples things look good, but... at least to me, the MTF chart doesn't seem to match this sample. On Canon's website, there's more full res samples and one seems to match the MTF chart's projected performance, but the two others seem a little better than the charts would suggest. Granted it's all a guesstimation, but I'm curious to see its performance first hand, or in a third party resolution measuring matrix.
What is great and seems pretty obvious, is they have worked very hard on CA and keeping it in check wide open. If accurate, that's a big strong point.
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 7D Mark II Canon EOS 5DS Canon EF 70-200mm f/2.8L IS USM Canon EF 100mm f/2.8 Macro USM +14 more
Scott Larson Veteran Member • Posts: 6,317
Where did you read this?
 Scott Larson's gear list:Scott Larson's gear list
Canon EOS-1D Mark III Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +14 more
J A C S
Re: Looks good!
The skin tones are horrible.
I see a hint of green fringing, and that is. No nervousness in the transition area, very nice overall.
MAC Forum Pro • Posts: 13,826
been waiting for 85 with IS and great bokeh
will study photos
maybe a purchase by spring
 MAC's gear list:MAC's gear list
Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 7D Mark II Canon EOS Rebel T7i Canon EF 70-200mm f/2.8L USM +8 more
aftab
aftab Forum Pro • Posts: 10,122
Read with Google translation.
http://cweb.canon.jp/ef/info/ef85-f14-usm/interview.html
 aftab's gear list:aftab's gear list
Canon G1 X II Panasonic FZ1000 Canon EOS 5D Canon EOS 5D Mark III Nikon D600 +23 more
Thank you! There's lots of discussion about eliminating color aberrations which is what I'm looking for.
1Dx4me Senior Member • Posts: 6,365
Re: Looks good!
post processing is done very poorly, also! i enlarged the shot and it looks horrid! i wouldn't attempt to print this shot more than 8x11 (if that much)!
The 85 L 1.2 was good for lateral CA, but bad for axial CA (purple fringing)
The new one seems better for axial CA. MTF curves tell nothing about axial CA, because it's out of the plane of focus. It's also tell nothing about colors, vignetting, distorsion and flare.
Tazz93
I don't judge CA off the MTF charts (not sure that's even definitively possible), the samples do a good job of confirming that. My only worry is, the samples look processed. If that's the case a lens profile would make a lens that suffers from CA issues look perfect. Personally I'm waiting for a Lens Rental MTF, or the DXO Sharpness "Profile". I find these two resources very comparable and relatable to image resolution.
As far as distortion, flare, vignetting, and colors... samples tell the entire story.  The only thing you'll need to confirm is there are no adjustments made to the sample images.
J A C S
Those must be JPEGs from the camera, as usual. You can use an exif tool to see what has been corrected.
Tazz93
Great point, I'll look and see if the exif info reveals any correction.
J A C S
I looked and it seems that they used all possible corrections. Vignetting was less than 100%, somewhere around 60-70%.
Tazz93
Wow...
Thanks for taking a look. I haven't been able to look at it yet, but that is a little disturbing (but as referenced earlier not very unexpected).
J A C S
