Which is better? 75-300mm or 40-150mm crop
Started Aug 28, 2017 | Discussions
Po Sen Tsui Regular Member • Posts: 289
I am using an Olympus 75-300mm f4.8-6.7 II lens for telephoto shots and things like birds and other wildlife on my EM-10 Mk II body. It's a good lens that provide a good reach in a compact size. The IQ is not bad considering the price of the lens. However this lens just doesn't work in low light. I am considering to switch to the 40-150mm f2.8 pro lens for better IQ and low light performance. But then I will be missing the 300mm focal length (That's 600mm in full frame terms!!!) because it is really useful if you want to shoot birds and wildlife, and 40-150 plus the 1.4X teleconverter is still a little bit short compare to the 300mm. So I am curious, can I use a 40-150mm to shoot birds at let's say 150mm and crop it and have a better result or will I just be better off sticking with the 75-300 if I really want the 300mm focal length? Given the bird should end up at the same size in the final picture. Do any of you guys have any experience in this kind of situation? Thank you very much for helping in advance! = )
P.S. And yes I know there is a 300mm f.4 pro lens but that's just way too expensive for a non-pro like me. And I heard that the Panasonic 100-300mm f4-5.6 Mk II is not that big of a difference with the 75-300mm and is not worth the trouble switching to it.
 Po Sen Tsui's gear list:Po Sen Tsui's gear list
Olympus E-M1 II Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-100mm F4.0 Venus Laowa 7.5mm F2 MFT Olympus 100-400mm F5.0-6.3 IS
Denjw
Denjw Veteran Member • Posts: 6,853
Re: Which is better? 75-300mm or 40-150mm crop
5
Imaging Resource review of the 75-300mm states:
"Optically the Olympus 75-300mm does very well, but not where you'd want it to - it's super-sharp at 70mm, not at the 300mm where I suspect the grand majority of users will want to use this lens. At 300mm, it's only above average, there's noticeable chromatic aberration, and the maximum aperture of ƒ/6.7 is one of the slowest I've seen for SLR lenses"
http://www.imaging-resource.com/lenses/olympus/75-300mm-f4.8-6.7-ii-ed-m.zuiko-digital/review/
Compared to the review of the 40-150mm
http://www.imaging-resource.com/lenses/olympus/40-150mm-f2.8-pro-m.zuiko-digital-ed/review/
Check out the blur tool of both lens at 150mm, then look at the 75-300mm at 300mm.
I don't own the 75-300mm but own the 40-150mm + MC14 which I have shot birds with.
The sharpness/resolution of the 40-150mm with or without the TC enables images to be cropped significantly with little discernible loss of IQ. Using the TC lessens the difference in focal length.
IMO the 40-150mm cropped would still have a better quality image then the 75-300mm at full focal length.
Here is a unedited full sized image of a tiny bird taken with 40-150mm + MC-14.
Spotted Pardalote only 8-9cm in size
But you need to weigh up the Pros and Cons particularly price, size & weight which to some (many) is significant.
 Denjw's gear list:Denjw's gear list
Olympus E-300 Olympus E-30 Olympus E-5 Olympus E-M1 Olympus E-M1 II +17 more
M_digicapt Veteran Member • Posts: 3,289
>>IMO the 40-150mm cropped would still have a better quality image then the 75-300mm at full focal length.<<
Very interesting comment. I'd love to see evidence backing this statement. I'm saving for a long tele and it would be very useful know.
will focus
will focus Senior Member • Posts: 2,640
I have the 75-300 and the thing is scary sharp from 75 on up to the mid twos. It does seem to struggle at full focal length but I have been surprised by it even out there. I just wouldn't bet the rent money on every shot @ 300 being a keeper. They're not.
I had the same conversation with myself over the last week or so. I am just getting back into photography after a several years long hiatus and I am getting the feel for the Olympus system. As with any system you have to know where the lines are. I think I have found the line on the 75-300 and I think if I can convince myself not to try and overextend the lens beyond 250-ish, my IQ consistency with it will improve. I just have to get over the habit of twisting it all the way out.
One thing I considered doing was to pick up the tc1.4 and use it in conjuction with the 75-300, again disciplining myself to moderate my use of the zoom to upper mid levels. If that doesn't work the way I think it should, then I'd still have the 1.4 tc to add to the 40-150 down the road. I save some money up front and make reasonable steps while building my oly kit.
 will focus's gear list:will focus's gear list
Sony a7R II Olympus OM-D E-M10 II Sony a7R IV Sony 70-200mm F2.8 G SSM II Sigma 24-70 F2.8 DG DN +1 more
Ulric Veteran Member • Posts: 4,559
The 40-150 is an excellent lens, and the lens itself can probably do 2x the resolution of the 75-300, but a 2x crop means an effective 4-5 MP sensor and that becomes the limiting factor.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
Tooks Regular Member • Posts: 196
When I was a FF DSLR user, the 300mm f2.8 lens was my choice for low light wildlife photography.
One of the things that attracted me to the m4/3 system was the availability of the 40-150 f2.8 with the FOV of that same FF/300mm setup, but in a tiny package by comparison.
The 40-150 is a great lens, and with the 1.4 tele converter offers you an f4 420mm equivalent, which is a pretty good length for wildlife.
F2.8 or f4 will certainly help with regard to AF in poor light, but it won't be the answer to every problem. I haven't owned an E-M10 in a good while, but I don't remember AF being its strongest point, certainly in comparison to the E-M1 line.
The 75-300 can deliver some good images, I had some good success with it at the long end particularly using the electronic shutter and good long lens technique.
I think rather than worrying about whether I could crop the 40-150 images to the same FOV as the 75-300, I'd concentrate on what the 40-150 can do in its own right. Even in the FF DSLR world, 600mm is a specialist focal length and although it helps with the 'bird on a stick' portrait shots, it's not a free pass to interesting wildlife images. And that's before you consider the technique required and atmospherics that impact images at that focal length. Sorry for indulging myself a bit here, but I think m4/3 cameras and lenses have given us some easily obtained long focal lengths, but the downsides of using them successfully haven't gone away.
Anyway, if I had to keep just the one lens for my own photography needs, and weight/size not withstanding, it would be the 40-150 f2.8. I'd like to cheat if I may and keep the 1.4 tc as well though!
 Tooks's gear list:Tooks's gear list
Nikon 1 V2 Nikon Z5 Nikon Z fc Nikon 1 Nikkor VR 10-100mm f/4.5-5.6 Nikon 1 Nikkor VR 70-300mm f/4.5-5.6 +4 more
daddyo Forum Pro • Posts: 12,670
Splitting hairs...
11
There is no question about the quality of the 40-150mm Pro. I don't own it, but have seen enough images from it to know that it is an outstanding lens.
However, it is questionable whether there is enough benefit over the 75-300mm if you are talking about a 300mm field of view. Given the cost, size, and weight of the 40-150mm vs the 75-300mm, I would be hard pressed to upgrade just to be able to crop to 300mm or near.
The 75-300mm is a very impressive lens in my opinion -- if it is use properly. Contrary to a lot of comments, I am very pleased with the image quality I get at full zoom and wide open with mine. Yes, it is sharper at less than full zoom and stopped down a bit, but it is barely perceptible -- you have to be pixel peeping to really see any difference.
Here are a couple examples from my 75-300mm at full zoom and wide open -- I can live with this IQ.
God Bless,
Greg
www.imagismphotos.com
www.mccroskery.zenfolio.com
www.pbase.com/daddyo
 daddyo's gear list:daddyo's gear list
Olympus 12-40mm F2.8 Pro
Digital Dick Senior Member • Posts: 2,379
I have to disagree. More pixels on the subject is better than cropping in almost all cases unless the optics of the longer focal length lens sucks. My 75-300 has enough resolution and contrast 300 to be the best choice.
Dick
 Digital Dick's gear list:Digital Dick's gear list
Olympus OM-D E-M5 Olympus E-M5 II
Okapi001 Veteran Member • Posts: 5,145
5
No. 40-150 2x cropped (to 300 mm) is remarkably good, but nowhere near as good as 75-300 at 300 mm.
Just a very quick test, done a minute ago from a window in my apartment.
75-300 mm
40-150 mm pro x2
 Okapi001's gear list:Okapi001's gear list
Olympus OM-D E-M10 II Olympus PEN-F Olympus E-M1 II Olympus OM-D E-M1X OM-1 +18 more
OP Po Sen Tsui Regular Member • Posts: 289
Re: Splitting hairs...
wow, these are quite amazing pictures! Do you remember how far are these subjects to you when you took these pictures?
According to the Exif File, these were shot at about 20 & 30 ft. respectively.
I believe I used the DTC (Digital Teleconverter) on both of these shots, so they are technically a 2X crop.
God Bless,
Greg
The 40-150mm shot looks sharper?
75-300 mm
40-150 mm pro x2
If you zoom in on the cap's strap, the shirt seams or the plastic clip on the dog's collar I can clearly see more detail on the 40-150mm f2.8.
This doesn't proof anything conclusively, but now I know that I should carefully research the matter before I buy...
Thanks!
John Kubler
John Kubler Regular Member • Posts: 322
7
I had the Pana 100-300 for five years and recently switched to the Olympus 75-300. I am very satisfied and shoot a lot of pictures at 300mm, closeups for butterflies, insects and flowers and further a way at the zoo. The sharpness at 300mm is excellent. When shooting without tripod, which the norm, I usually shoot with the e-shutter. Attached picture was shot at 300mm, f6.7 (wide open), 1/160s and ISO 400.
JMK
 John Kubler's gear list:John Kubler's gear list
Olympus PEN E-PL1 Olympus OM-D E-M5 Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +16 more
Ronsol Regular Member • Posts: 119
5
My experience with the 75-300mm has also been excellent, even fully extended.  In my opinion it is  a jolly good lens at a great price.
 Ronsol's gear list:Ronsol's gear list
Olympus E-M1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8 Pro +1 more
RamblinR Regular Member • Posts: 317
5
I think the 75-300 is a very sharp lens but distance to subject is always going to put a lens to its limits.  If I shoot at 300mm and the subject is half filling the framing the image quality will be excellent.  But ... if shooting things distant (which is usually what you want this lens for) that's when it looses it's sharpness.  I often shoot surfers and when I do I try to keep the lens under 250mm because this would generally be a sharper shot than 300mm for the 50% or more crop I may have to do.  But, if the surf shots composition didn't require 50% cropping then 300mm would offer a sharp image.
So I guess what I am saying is ... always get as close to the subject as you can for best image quality.
 RamblinR's gear list:RamblinR's gear list
Olympus E-M1 II Olympus E-M1 III Olympus Zuiko Digital 1.4x Teleconverter EC-14 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +7 more
Michael1000 Senior Member • Posts: 1,690
That shot of the bird sticking its head out of the tree trunk is priceless!  The squirrel one is good, too.
(unknown member) Veteran Member • Posts: 7,274
Re: The 40-150mm shot looks sharper?
5
And if you look the photographs, you should immediately spot that the 75-300mm is focused to background of the head, on the ground, rendering  the man as the dog OUT OF FOCUS!
So no wonder you will see more details with 40-150mm cropped one!
If you want even more fair comparisons, look at the cigarette stump on the ground just right from the mans head. Even when it is just partially out of focus with 40-150mm, you can see how 75-300mm will clearly render far more details in the grass blades and the stump itself!
The 75-300mm is no louche at 300mm, and it doesn't really matter in the scenarios it is most often used as the thermal waves in air will render most often all long telephoto lenses to same ball park.
The real differential comes when you go to very close ranges or in situations where everything are optimally so that sharper lenses like 300mm f/4 can really capture sharper images instead same blur that heat waves distorts.
This is huge differential that makes most sharpness tests moot because they are done either in the laboratory, indoors or ultra low distances, instead in purposed distances.  Alone close-focusing can be softer than far focusing as the lenses focal length and sharpness is optimized for infinity (macro for 1:1).
So example on soccer match that is photographed in direct sunlight, a more important thing is magnification and fast shutter speed than the sharpness.
Doing a common 8x10" prints and it renders lenses like 300mm f/4 moot by sharpness compared to 75-300mm @ 300mm as you are wasting resolution benefit in small print.
Requirement to increase the ISO is as well one thing that makes sharper lenses benefit negligent. But in situation like ISO 200 vs ISO 800 there can be a benefit. So f/4 is the difference maker over f/6.3 that is just 1.3 stops slower (ISO 200 vs 500) and it can be very tiny even in many cases (unlike example ISO 3200 vs 8000).
Add there some motion blur and again the sharper lens has lost its benefit.
Subject that doesn't have good contrast (low light situations) and again the sharper lens loses the benefit, but then again it can offer the better separation if the subject has strong contrast but it is in low light situation.
So it is up to many many variable when a technically sharper lens (like 300mm f/4) can reveal its benefit over less sharp (75-300mm) and if such times when it would are rare (<10%) then question is, is it worth it? Does the subject really benefit from that tiny sharpness benefit then? Rarely.
If we talk about differences between lenses like 100-300mm (mk1 vs mk2) vs 75-300mm, it is negligent difference (between good copies on all).
So it mainly comes to only a technical argumentary and choice making, that makes it personal justification to boost the ego "I have the better one" and "I made the good choice" than for actual use and results making.
And this is what the sensible photography equipment manufacturers are doing. They don't go by the numbers, charts etc. They go by the final result.
If their customer audience is 80% of people that are doing 98% of the time prints size of 16x11" and 2% just little bigger and otherwise photos are on Full HD or HD displays, that is the starting point where the comparison will be made as it is the output that rules everything.
And if you can make smaller and lighter without sacrificing the image quality in the output compared to best possible product you could manufacture, it is huge benefit. But when pixel peepers and gear heads gets their hands on the product, they throw the product out of the context and just trash it or praise it.
Thanks. I originally checked them on the phone screen and mistakenly assumed both where focused on the same place. I just loaded them to the computer and you are right. Then again a fair comparison would have both lenses focus on the same place...
I don't even print, but do a lot of cropping. After checking the price difference, the 75-300mm looks even better...
I agree with the rest of you post.
mchnz
mchnz Senior Member • Posts: 1,949
I own both lenses and use them with an E-M5 MkII. They're primarily used for perched birds in forrest/bush conditions where I can often get with 4-10 metres of my subjects. Processed images at flickr (see sig).
I haven't analysed the heck out of it, but I'm not missing the 75-300 much. I do seem to be able to crop a lot for web/screen presentation.
I think this is a tough call. People here are arguing both ways. It may depend on what you're shooting and whether you want to print big or just view on screen. Maybe you're after one really sharp lens to complement the 75-300. Maybe you're always out at 300 mm.
It seems the primary reason you're thinking about the 40-150 f/2.8 is low light. Same for me. In my case this means winter overcast and rainy days. I wanted to be able to walk with the camera in the rain, so that pushed me strongly to a purchase.
When I only had the 75-300 I primarily used the small single focus square. When applying the same technique in darker conditions with the 40-150, I think it may hunt and miss more than with the 75-300. I think this is because the wide open depth of field available to the AF mechanism is smaller for the 40-150. When the birds are not well lit the AF has less to work with. It always focuses wide open, so stopping down doesn't help. Perhaps I need to work differently when the light is really bad or the DOF really shallow. The E-M1's focus limiter seems like it would be very useful for my circumstances.
The other DOF issue is the lack of it.  At f/2.8 or f/4 I need to be careful about what parts of the bird are in focus.   With the 75-300 I default to f/8 to reduce the DOF issue's, but I can't do this in poor light.
Depending on what you mean by darker and what kind of subject you're targeting, you may find some wins due to a wider aperture, but maybe also some losses due to narrower DOF.
Other things to note:
The 40-150 lens hood is complicated and many here report it falling to bits. Mine failed at around 6 months (waiting for a warranty replacement). I've bought a $10 JJC LH78II from ebay as a stand in.
The DR-66 decoration ring that sits in place of the tripod ring is not included. Mainly this is a comfort issue if holding the lens without the tripod ring. Some people use a wide black rubber band.
The lens is mainly metal, gloves required in winter.
These things aside, I'm happy to be carrying this lens around in the forest without regard to the rain. It's not too heavy for day walks - but not my cup of tea for travel or multi-day hikes. It's nice to be able to use a very sharp lens.
spatz Junior Member • Posts: 29
The 40-150 looks sharper to me - there are probably other differences (higher contrast on the 40-150), and perhaps the 75-300 could do with some additional sharpening, but if these were the final images, I would prefer the 40-150 photo out of these two.
Another consideration is, of course, light - shooting at f/2.8 vs f/6.7 gives you a factor of ~6 in exposure time. At these focal lengths, and if you care about pixel-level resolution, you probably want to be shooting at 1/500, so unless you shoot in very bright light, the 75-300 introduces either blur (both shake and subject movement) or noise.
