Pen F keystone compensation example
Started Aug 25, 2017 | Photos
Day Hiker Forum Pro • Posts: 10,829
8
I'm fairly old school when it comes to digital cameras: aperture, shutter speed, ISO, focus, snap. I admit that I can become overwhelmed with all of the features in the newest cameras. I expect feature bloat to continue unabated well into the future.
One feature that Olympus put in the Pen F is keystone correction/compensation. I started using it a few months back and I have to admit, I really like it. Here are two versions of the same image, one from raw, and one the jpg that the camera generated after I engaged keystone correction. Take a look and I'll finish up my post below:
Pen F, M.Zuiko 12mm f/2 - uncorrected
Same image, in-camera keystone correction
I think the corrected image is 100% better! I believe this new feature can truly improve any images where you must tilt your camera up (or down). Yes, it takes a few seconds to do, but the results can be worth it. I'm using it enough that I've assigned the Fn2 button on my Pen F to activate this feature.
Try it. This is a useful feature.
Edit: I have no idea why my Exif data is bad. No, this was not 1/10000 sec exposure. It was 1/800 @ f/5.6, ISO 200
Jim Pilcher
Bonita Springs, FL, USA
Life is a breeze by the sea
Comment & critique:
Olympus M.Zuiko Digital ED 12mm 1:2 Olympus PEN-F
daddyo Forum Pro • Posts: 12,670
Re: Pen F keystone compensation example
It's a very useful feature for sure -- if one does not have a complete aversion to jpeg capture. I have used Keystone Compensation on a number of real estate shoots, and it has been a real time saver, along with in camera HDR.
God Bless,
Greg
www.imagismphotos.com
www.mccroskery.zenfolio.com
www.pbase.com/daddyo
 daddyo's gear list:daddyo's gear list
Olympus 12-40mm F2.8 Pro
M_G Contributing Member • Posts: 503
Looks a bit "overcorrected" to me
To me the building looks a bit "overstretched" and seems to be "falling" to the left side (especially in the upper half). The rectangular railing on the upper left looks a bit "fancy" compared to the rectangular railing on the right. Also the left column somehow seems to "take a bow" to the left side, i.e. it doesn't go straight upwards.
Probably I wouldn't have even noticed these minor imperfections, if I didn't know that the image was key-stone-corrected. Still I would have corrected the image a little bit less, so that it still looked "natural". Otherwise I also think this is a  very nice feature to have in camera.
Virtual Photon Senior Member • Posts: 1,701
Yes, but on my screen the colors of the RAW look much better.  The jpeg looks like it has a green cast  . . .
 Virtual Photon's gear list:Virtual Photon's gear list
Nikon D500 Nikon Z7 Nikon Z6 Nikon AF-S Micro-Nikkor 60mm F2.8G ED Voigtlander 20mm F3.5 Color Skopar SL II +9 more
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,949
I fully agree and that is the weakness of this correction.
I often apply a *partial* keystone correction in ACR to leave it visible that the image was taken from a lower vantage point but not have verticals slanted too much.
Enjoying the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
wolfychi Senior Member • Posts: 1,158
I agree with the others that it is a bit over corrected. the building looks like it starting to lean towards the left, is there any adjustment of how much it can correct?
I normally use LR to correct any percieved perspective distortion but try to maintain some balance, I have seen many high rise building being so keystone corrected that they lost the natural vanishing point of the perspective.
larsbc Forum Pro • Posts: 18,282
I've used this correction tool in Lightroom (I shoot raw) and find that 100% vertical lines don't always look quite right.  I usually leave a bit of keystoning to keep the image looking somewhat natural.
OP Day Hiker Forum Pro • Posts: 10,829
overcorrection
The image was made on the run, no tripod. It was done through the viewfinder rather than on the larger LCD. It may well be a bit overcorrected. Is anyone willing to give me points for effort?
Jim Pilcher
NowHearThis
NowHearThis Veteran Member • Posts: 4,616
Yes. There is.
NHT
//life motto
if (sad() == true) {
sad().stop();
beAwesome();
 NowHearThis's gear list:NowHearThis's gear list
Panasonic Leica 12-60mm F2.8-4.0 ASPH Olympus E-M1 III Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G 42.5mm F1.7
Re: overcorrection
6
Jim Pilcher
I don't know how to make the adjustment in your Pen-F to reduce the over correction, I would try to make it not so straight vertical, it is not so obvious in your shot, but it does gave the impression or illusion of a wine glass effect, where the buildings top is wider than the bottom.
I worked in 3D rendering for architecture for many years, and the common problem with setting up the perspective view of high rise building is at street eye level looking up, my client always insist having the line 100% vertical (bit of a cliche), upon seeing the finish rendering, they would always ask why the building looks strange, I have to explain to them because the natural vanishing point has been distorted too much.
example of over correction in 3D rendering. it is perfectly straight, but have a strange top heavy feel.
better example, more convincing with a slight vanishing towards the top,
Thank you
Your illustrations were very useful. Thanks.
Jim Pilcher
Re: overcorrection
Yes, of course. Maybe my comment sounded a bit harsher, than it was meant to be. Maybe I should apologize. No need to justify your picture. Everything is fine, I just wanted to share my observations (also on the run). Please excuse any discourtesies of mine, have fun and keep on shooting (and experimenting).
Jim Pilcher
comments and discourtesies
Oh, I felt no discourtesy coming from the comments in this thread. They all seemed very honest. I thank everyone that participated, and I did glean a couple of good tidbits for future experimentation.
And certainly, I will keep having fun and shooting.
Jim Pilcher
tintifax Senior Member • Posts: 1,057
Re: overcorrection
to the OP: 10 points😊👍
Jim Pilcher
with best regards from Vienna
Thomas T
 tintifax's gear list:tintifax's gear list
Olympus OM-D E-M10 II Olympus PEN-F Olympus E-M1 II Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +9 more
10 points!
Thank you, Thomas. That's a grand total of...well...10 points so far!
Jim Pilcher
boxerman Senior Member • Posts: 1,946
medium correction
Nice examples. They agree with my predilections. That is, I almost always find that in situations of fairly extreme vertical convergence, I prefer less than "natural," but not fully corrected. So, that seems to mean that, since in-camera is not adjustable, I will always have to manually correct.
Bummer.
The BoxerMan
 boxerman's gear list:boxerman's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro +4 more
adjustable in-camera
Don't give up just yet. I don't know where you get the idea that in-camera keystone correction is not adjustable. It is quite adjustable, about 10 steps in each direction from uncorrected.
Jim Pilcher
d3xmeister Veteran Member • Posts: 3,395
Yep, same thing with DxO, 100% vertical lines makes it look overcorrected somehow. I always leave a bit too.
For jpeg shooters outhere, I think it is great to have such posibilities in camera, it's really important, and Olympus does offer a lot in terms of in-camera processing.
Aaron801 Veteran Member • Posts: 7,900
Very cool that the camera has this as a built in feature... Still, though I have no issue with folks liking to shoot JPEGs (I know that there are better photographers than myself who do so!), that kind of adjustment is the kind of thing that I like to do with post processing, where I can really fine tune it.
The Pen F seems like a really sharp little camera and I can't help but be intrigued by it (I like good design!) but I can't help but think that with features like this and a control wheel that I understand does nothing at all if you're shooting RAW that the camera is really optimized for JPEG shooters. This would be totally OK with me as it would mean that it's one less thing for me to lust after...
my flickr:
www.flickr.com/photos/128435329@N08/
 Aaron801's gear list:Aaron801's gear list
Olympus PEN-F Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +1 more
Re: 10 points!
Jim Pilcher
we mostly talk about the things that don't work and oversee the many many things that work great. this feature works very fine and I enjoy it very much when shooting jpgs. yes you can over-correct a little bit but the  most important thing is that you have fun, that this feature makes photographing easier and your camera enables you to do things the CanNikonPhotographers dream about 😁
so: well done! you have made photos while other people are tiping on their computers 😏
take your gear out (by MatRanger)
Thomas T
