Raw Support for Nikon D500
Started Aug 22, 2017 | Questions
PeterD07 Senior Member • Posts: 1,485
According to Apple (https://www.apple.com/aperture/specs/raw.html)  Yosemite OS (mine:10.10.5) should enable raw support with Aperture 3 which I'm using, however, it does not. It only shows previews when in import mode.
Does anyone here that owns and processes D500 Raw files  know if El Capitan actually works. I can't go with Sierra.  Specifications seem not to be realistic so hopefully actual experience is better. Thanks
Nikon D500
DNikonist New Member • Posts: 14
Re: Raw Support for Nikon D500
I'm also interested to hear if there is a workaround this problem. Still using Aperture.
Tom_N Forum Pro • Posts: 13,812
Did you see the '****' next to the D500 entry? The corresponding footnote says "Requires OS X Yosemite and Photos or other supported imaging applications."  I wonder if that is an oblique way of saying that "You don't get Aperture support in this version."
Another thread here on DPR pointed to this Apple Support Note for RAW formats supported by El Capitan. It shows D500 support as a feature of RAW Compatibility Update 6.19, with a footnote saying "Nikon D5, Nikon D500: Nikon RAW L format only."
For reference:
DPReview – Nikon Pro DX SLR Talk – D500 raw files and Mac
This would not be a good place to post, as it is a nine month old thread.
Ellis Vener
Ellis Vener Veteran Member • Posts: 8,294
Why not Sierra? A hardware constriction?
 Ellis Vener's gear list:Ellis Vener's gear list
Nikon D850 +1 more
jtstanco Regular Member • Posts: 215
I just tried a D500 NEF sample downloaded from the review on this site. I was able to open it successfully with Aperture, Pixelmator, and Preview on a10 old MacBook Pro running El Capitan as well as a new iMac running Sierra. All three Apps use the Apple RAW converter.
I suspect there is an error on the Apple page for Aperture RAW support. The Yosemite RAW support page (https://support.apple.com/en-us/HT203088) does not list the D500.  As Tom_N mentions above, it looks like D500 support was added to El Capitan as part of the RAW Compatibility Update 6.19
Hope this helps.
 jtstanco's gear list:jtstanco's gear list
Canon EOS 70D
Jim in Hudson Senior Member • Posts: 2,232
Hope this helps.
This must be the case as the the final Yosemite update came out well before the D500 was released.
To the OP:  is there anything that prevents you from upgrading to El Capitan?
 Jim in Hudson's gear list:Jim in Hudson's gear list
Olympus E-M1 Pentax K-3 Sigma 10-20mm F4-5.6 EX DC HSM Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +4 more
DenWil
DenWil Veteran Member • Posts: 3,402
High Sierra coming soon.
Hope this helps.
I have too many devices  that need to be shaking hands to not  update all of them  in a timely fashion. It minimizes unforeseen incompatibility issues. I have minimal  non-MAC peripherals. No problems with Epson since SnowLeopard.
