Shooting time delay comparison - DSLR vs Mirrorless
Started Aug 21, 2017 | Discussions
DVT80111 Veteran Member • Posts: 3,763
I performed this test just this weekend.  It is not scientific by any means. But what I found was no significant difference between the 2 systems.
A pro sports photographer probably will shoot before the action anyway. So the camera that has higher frame rate and better tracking AF will win hand down.
 DVT80111's gear list:DVT80111's gear list
Sony RX100 Canon EOS 6D Canon EOS 70D Sony a7R II Fujifilm X-T30
ThijsH Regular Member • Posts: 305
Re: Shooting time delay comparison - DSLR vs Mirrorless
5
You are comparing a 5 year old $2000 camera against a 2 year old $3000 one...
IMO not a good base for drawing conclusions...
I wear safety flip-flops, so what could possibly go wrong?
 ThijsH's gear list:ThijsH's gear list
Canon EOS 5D Mark III Canon EOS 7D Mark II Canon EF 50mm F1.4 USM Canon EF 400mm f/5.6L USM Canon EF 70-200mm F2.8L IS II USM +3 more
D Cox Forum Pro • Posts: 31,898
I think the Sony A9 has less delay than the A7r2.
Sigma fp
sportyaccordy Forum Pro • Posts: 19,928
5
I'd love to see how you're doing the timing because I have found a pretty clear delay between my A7II and even a D3300
DSLRs are way more responsive than MILCs
Sometimes I take pictures with my gear- https://www.flickr.com/photos/41601371@N00/
 sportyaccordy's gear list:sportyaccordy's gear list
Sony a7 III Tamron 28-200mm F2.8-5.6 Samyang AF 35mm F1.8 FE Samyang AF 45mm F1.8 FE
osv Veteran Member • Posts: 9,970
"The Sony A9's prefocused shutter lag was only 0.020 second with EFCS, which is very fast. Without EFCS, prefocused shutter lag increased dramatically 0.165 second, but with the fully electronic shutter, it was only 0.038 second." http://www.imaging-resource.com/PRODS/sony-a9/sony-a9A6.HTM
"(d5)Manual focus lag was 41 milliseconds, a bit faster than the D4S's 44ms. When prefocused, shutter lag was only 39 milliseconds, which is very fast for a DSLR and once again improved over the D4S's 43ms." http://www.imaging-resource.com/PRODS/nikon-d5/nikon-d5A6.HTM
dan
PerL Forum Pro • Posts: 14,486
Try when the processor is working
You should try when cameras processor is on heavy duty (which could affect the EVF response time) - like when it performs AF-C while shooting a series, saving the images, changing exposure etc.
golfhov Forum Pro • Posts: 11,893
not surprising
"shutter lag" really hasn't been an issue on mirror less for some time. It is often FASTER than a DSLR.
Now EVF lag and AF delays are a different issue. That I don't even feel like getting into...........
Too often people seem to claim "shutter lag"(see several of the responses above) when it isn't the problem they are having or do not know how to use their camera.
You will also find the same issue often when discussing "evf lag" which is a real thing but just like "shutter lag" often incorrectly blamed for errors. Again "EVF lag" is a real thing and cause certain issues BUT it is too often incorrectly attributed to missed shots where the user just plain doesn't know how a camera works
 golfhov's gear list:golfhov's gear list
Panasonic LX10 Sony a7R II Sony a7 III Samyang 14mm F2.8 ED AS IF UMC Tamron SP 70-200mm F/2.8 Di VC USD +11 more
drj3 Forum Pro • Posts: 12,470
Just use the E-M1 MkII with Pro Capture Low and get the 14 images before you pressed the shutter with no delay.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
SoCalWill
SoCalWill Veteran Member • Posts: 6,299
I stood outside for half an hour with my DSLR trying to catch lightning, turns out that fraction of a second needed to move the mirror out of the way is too long to do it. First try with the mirrorless RX100:
Digital Camera and Adobe Photoshop user since 1999.
Adobe Lightroom is my adult coloring book.
 SoCalWill's gear list:SoCalWill's gear list
Sony RX100 III Nikon D810 Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 50mm F1.4 DG HSM | A Apple iPhone XS Max
J A C S
J A C S Forum Pro • Posts: 20,314
You do know that the mirror can be held up in LV, right?
SoCalWill
The K-S2 still moves the mirror when shooting LV, it takes longer than if shooting optically.
J A C S
No electronic 1st curtain?
lv in dslrs is usually a disaster, with some pretty ugly shutter delay... d800, for example.
dan
J A C S
How long?
J A C S wrote:
How long?
prefocused: 0.184sec
w/full autofocus: 1.735sec
http://www.imaging-resource.com/PRODS/nikon-d800/nikon-d800A6.HTM
dan
J A C S
osv wrote:
J A C S wrote:
How long?
Obviously, you do not shoot lightnings without prefocus, let us not change the topic.
For the D54, it is 0.054 sec in LV and not in LV! So the disaster is ... no difference.
J A C S wrote:
osv wrote:
J A C S wrote:
How long?
what part of "prefocused: 0.184sec" did you not get?
what's a "d54" and where is the link to the measurements.
dan
J A C S
osv wrote:
J A C S wrote:
osv wrote:
J A C S wrote:
How long?
What makes you think I did not? I was saying that the second number is irrelevant.
what's a "d54" and where the link to the measurements.
5D4.
J A C S wrote:
osv wrote:
J A C S wrote:
osv wrote:
J A C S wrote:
How long?
except you never said any such thing.
5D4.
link?
dan
osv wrote:
J A C S wrote:
How long?
prefocused: 0.158 second
w/full autofocus: 0.875 second
lv prefocused shutter delay on the d810 is still weak.
http://www.imaging-resource.com/PRODS/nikon-d810/nikon-d810A6.HTM
dan
