Canon EF 200/2.8 overexposing and errors
Started Aug 20, 2017 | Questions
Baracuda Junior Member • Posts: 48
My Canon EF 200/2.8 USM is around 10 years old and recently started overexposing images. After running the same shot through all the f-stops it is clear that the camera exposes correctly at f2.8 and increasingly overexposes the higher the f-stop with f8 already being severely overexposed.
I am also getting occasionally error messages regarding the contacts of the lens but the contacts are clean and not damaged.
I have the same issues with this lens on my Canon 80D and older 40D. All my other lenses work great with these bodies.
Any ideas?
Canon EF 200mm f/2.8L II USM Canon EOS 40D Canon EOS 80D
BAK Forum Pro • Posts: 26,019
Re: Canon EF 200/2.8 overexposing and errors
5
What happens when you  press the depth of field buttons?
BAK
Steve Balcombe Forum Pro • Posts: 15,582
5
Got to be the diaphragm sticking. As BAK suggests, see what happens when you press the DoF button.
OP Baracuda Junior Member • Posts: 48
Thank you both for your answers. You are right. The diaphragm is stuck. I pushed the DOF preview button many (40+) times at F32 and I can see through the lens that it only closes a tiny bit but not what it should.
I also tapped the lens in the palm of my hand a few times trying to see if something is lodged in the diaphragm but that did not help either.
Next step is to go through a local lens repair shop to get this fixed. It's a great lens and probably worth the repair cost.
