Canon 400D focus issue
Started Aug 15, 2017 | Discussions
spacebiscuit New Member • Posts: 3
I'm having issues with the auto focus on my 400D. It is happening with two different lenses which suggests it is the body rather than the lenses, one of which is practically un-used anyway.
I read that the gold contact can become dirty, so I cleaned these with surgical alcohol and when I re-attached a lens it will auto-focus but only one. I have tested it several times but I can only get the focus to work once before I have to clean the contacts again.
Has anyone experienced this issue before? Any suggestions as to how I might fix this issue.
Thanks,
John.
Canon EOS 400D (EOS Digital Rebel XTi / EOS Kiss Digital X)
brightcolours Forum Pro • Posts: 15,885
Re: Canon 400D focus issue
Thanks,
Describe in a more precise way which issue you have with AF. What does actually happen?
John.
OP spacebiscuit New Member • Posts: 3
When I try to focus the lens makes the sound it usually would when focusing but it doesn't beep as it would usually when it has focused. Instead in sounds like the lens is reversing back or further trying to focus again. The lens can be heard making small adjustments without ever locking on.
WilbaW
WilbaW Forum Pro • Posts: 11,643
That's normal behaviour in Servo, so if it's happening in One-Shot it probably means there's something preventing the system seeing an in-focus subject. I would check and clean the mirror and AF sensors with a blower. Don't blow with your mouth 'cos you'll get spit on stuff.
Check out the unofficial Rebel Talk FAQ. Sorry it's out of date, but DPReview still won't allow us to edit our articles.
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
Cleaning the contacts has no use at all, clearly they work as the lens does something. The camera does not see when something is in focus that is the issue. So, like WilbaW suggests, probably there is so much dust on the optics of the AF module that it has trouble seeing when something is in focus. The AF module is situated on the bottom of the mirror box.
Put your camera in manual sensor cleaning mode, so the mirror stays up. Take off the lens, and with a blower (made for cleaning the camera) blow the dust from the optics of the AF module.
Thanks I tried as instructed, I set the camera to manual sensor cleaning mode, the sensor popped up I used a can of compressed air to give it a good clean. Results are the same though, in full auto mode the lens simply zooms in, appears to focus and then zooms out again.
Seppi Evans Forum Member • Posts: 70
I had a 350D and weird things happened when the date time battery was low. Worth checking to see if its OK?
 Seppi Evans's gear list:Seppi Evans's gear list
Leica D-Lux (Typ 109) Ricoh GR II
Mirror?
Hmm, don't use those cans. Use a blower designed for the job.
What did you try to clean? The sensor? Or rather, the AF module optics on the bottom of the mirror box?
