River Thames, Milenium Bridge, St Pauls
Started Aug 15, 2017 | Photos
dylanphotolight Regular Member • Posts: 414
10
 dylanphotolight's gear list:dylanphotolight's gear list
Panasonic Leica D Summilux Asph 25mm F1.4 Olympus 25mm F1.2 Panasonic 12-35mm F2.8 II Panasonic 35-100mm F2.8 II
Comment & critique:
Paul Boddie Regular Member • Posts: 193
Re: River Thames, Milenium Bridge, St Pauls
Excellent composition! At first I thought it was two pictures vertically stacked, and when I realised what I was looking at, I had an even higher regard for the composition. The upper part has a Matrix vibe to it, whereas the lower part is arguably more Jason Bourne.
Amusingly, the figures on the bridge look as if they've had some Matrix-like digital treatment, but it turns out that the horizontal lines overlaying them are actually lines of text on the glass, and that text is very nearly readable, too. So some credit must also go to the gear as well.
All in all, very nice indeed! Sorry if there's not much criticism here, though.
ahaslett
ahaslett Forum Pro • Posts: 12,654
I like the idea and elements a lot but somehow they don't fuse.  For example the bridge support doesn't quite line up with the dome, the line of the railing is positioned so it interferes with the detail on the dome and the people on the stairs don't fit into their framing.
It makes me want to take a camera there and explore your idea, so kudos for creative inspiration.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
OP dylanphotolight Regular Member • Posts: 414
Thanks, for your comment, I think its a good example of what m3/4 can do even with a old camera :). even if I had been using Full Frame I don't think it would be a better Image.
Yours Dylan Garcia
www.dylan-garcia.co.uk
Andrew
Hi
I also think that the position of the people could be different maybe if the man was more on right.
Yours Dylan Garcia
