An irreverent look at the Quattro vs Merrill thing....
Started Aug 14, 2017 | Discussions
JojoChuang Forum Member • Posts: 62
Re: An irreverent look at the Quattro vs Merrill thing....
dellaaa wrote:
I have a d800, xpro 1 and a nex7. i think the sigma is unique so i thought I'd try it and see. i will use it for landscapes and controlled stuff and see if its worth adding more lenses.
i wanted the dsqh too, but as i said if i need fx lenses, then what is the point
Wait... I'm lost lol.
Do you want a SDQH or SDQ?
I thought the point of using SDQH is for the less crop factor so you would want to use "FX"(DG, full frame) lens to fill the sensor, DC lens on SDQH can work but really depends on which lens. The link I sent earlier is an user use SDQH+17-70(DC) combo, but I can't find out if he use crop or not, since you asked about 17-70.
I am in the struggle of clearing out the lens suit for SDQH as well before I jump in to the pit.
It's tough to find out the information in the dark since Sigma players are so little...:-(
 JojoChuang's gear list:JojoChuang's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sony a7 II Sigma sd Quattro H Sony FE 28-70mm F3.5-5.6 OSS +10 more
dellaaa
dellaaa Senior Member • Posts: 1,201
I have to thank you for this post, I believe that it saved me time and some money (at least for the time being).  At first I was hell bent on buying a SDQ. I own too many cameras as it is, but something about the Foevon sensor intrigued me. I shoot a lot of music performances in auditoriums and landscapes.  For these I use either my Nikon D800 or my Fuji XPro1. I was interested in the SDQ as a step up from my D800 and I was going to use it for landscapes (both in SFD mode on a tripod and handheld in normal mode) and as a walk around hand holdable infrared camera (something none of my cameras are capable of).
I actually ordered the camera, and was all set to get the 17-70 but in the end canceled the order. I canceled it for the following reason, partially after reading your post and doing some further research, I value your opinion, am I correct in my decisions below?
Reasons I didn't buy the SDQ:
1) Disappointed with SFD mode – other cameras such as the Pentax have a SFD mode, but they do this is to increase detail, it looks to me from the samples that I have seen that the SDQ’s SFD mode doesn’t in fact increase resolution, but minimizes noise and smooths out the image. The sample that I have seen actually look softer than their non SFD counterparts.
In the end how much better image quality would I get from the SDQ compared to my D800? The web is full of claims, some saying the SDQ equals MF and out resolves the D800, but honestly, are we just splitting hairs at this point?  Would the results from the SDQ be appreciably better than the image below?
2) Infrared quality is not so wonderful – I didn’t realize this until your post, but the quality if IR on this camera is poor. The images I have seen look splotchy and as you say Monetish. I challenged you at first but after looking at them they aren’t so good.
3) Effecs of a polarizing filter are difficult to see in the SDQ. I never realized this but I have see some posts to that effect.
As for the rest of the SDQ vrs D800, there is no contest IMHO. I can shoot astronomical ISO on the D800 compared to the SDQ, I can pull multiple stops out of the shadows in a RAW file, the af is far superior, I can go on.  So here is the image, how much better can it be?  Many thanks for your time.  (I still haven't 100% ruled out the SDQ bad case of GAS)
D800 down sampled 200 f4 macro
 dellaaa's gear list:dellaaa's gear list
Canon PowerShot G10 Sigma DP1 Merrill Nikon D800 Sigma SD1 Merrill Fujifilm X-Pro2 +4 more
SiFu
SiFu Veteran Member • Posts: 6,373
Hello!
Without adressing much else, but since you asked, that image could be many, many, many times better - regardeless of the camera used - with lighting to fit the subject, better framing and more carefully placed focal plane.
That said, the detail level does not look good either, especially for a D80x shot. Care to share a 100% crop of the head?
Thanks!
Best,
Alex
carpe diem, quam minimum credula postero
dellaaa
Sorry, but I find your comments are kind of pedantic and unwarranted.
In the first place the post was directed at the OP. I was looking for a quantitative comparison between the SDQ and the D800, the image was posted as a reference point in that respect.
The image is straight out of the camera, zero crop, I posted it merely as an example of the D800's image quality capabilities, that was in my post.
As for the lighting, it was taken hand help outside using a flash and soft box, as for the focal plane, its exactly where i wanted it on the head of the butterfly.
I do agree the image doesn't look sharp posted here, IDK if its the jpg conversion but the tiff looks much better.  I will retry with a high quality jpg on a 100% crop.
TN Args
TN Args Forum Pro • Posts: 10,683
I know you jumped down SiFu's neck for daring to comment on a post that you directed to the OP, but I will make the same mistake -- since you could have gone PM to the OP if you really wanted to block us from discussing your questions.
SFD mode is definitely not softer than a single exposure. And it has far better detail (and colour preservation) in the shadows due to absence of noise. But it does not increase the pixel count, so there is no more actual detail across the well-exposed areas of a scene. My example.
The 19.5 MP sdQ resolves about the same perceptual detail as a 36 MP Bayer without a strong AA filter. Maybe a tad more but not much. You need a sdQH if you want significantly more -- it will roughly match a 45-50 MP Bayer. Search this forum for 5DSR vs sdQH, there are one or two good threads.
 TN Args's gear list:TN Args's gear list
Sigma dp0 Quattro Panasonic Lumix DMC-GX7 Olympus E-M5 II Sony a7R III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
SiFu
Hello!
You asked how much better the image could be and I gave my honest opinion - to me, this is a nice snap but not a high-quality macro/closeup and not representative of what can be done, either by the D810 or other cameras.
If you don't like or care for honest replies, why ask in the first place?
Best,
Alex
dellaaa
Excuse me but I replied, civilly, to the comments because composition, focal plane and lighting were not the object of the post.
You answered the questions I posted, namely how much different/better would IMAGE QUALITY aka resolution, noise etc.  be, not how can I improve the composition/lighting/technique of the posted image.  I was in my back yard testing a new soft box and it was a recent image so I posted it.  Many thanks for your information,
SiFu was more interested in bashing the image. on non camera related issues.  Do you see  my point?  Thanks again btw, I will msg the OP directly, I thought I had replied to the first post, but apparently I didn't.
SiFu
Hello!
You seem to not undestand that there is a difference between (undeserved and uncalled for) bashing and simply giving honest (invited) feedback.
If you don't want to receive honest feedback, don't ask for it - or at least don't go whining and call it bashing afterwards.
And yes, the part about proper lighting does also adress direct properties of the file - better defined and more visible fine detail, cleaner shadows, better tonal range. As does the placement of the focal plane - less "dead" oof wing space (=more detail).
Best,
Alex
