Making the switch to Fujifilm. Saying good bye to Canon (for now)...
Started 11 months ago | Discussions
syrcular Regular Member • Posts: 130
So I've decided to sell off my remaining Canon pieces, and go full on Fujifilm for all my photography, and possibly some video work.  I have an Xpro2, X-T2 and X100F, so I'm all set and in the echo system.
I'm just curious for former Canon or Nikon users that have switched over to Fujifilm, that were in the full frame realm...do you have any regrets?  I know in certain instances, especially in wider aperture, you experience less bokeh and not as shallow depth of field as you do with Full Frame.
But just curious for those that made the switch how you feel now, about it, and what it's opened up (or closed up for you).
Fujifilm X100F Fujifilm X-T2
Joachim Gerstl
Joachim Gerstl Veteran Member • Posts: 7,672
here are my thoughts after the final switch
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Canon PowerShot G7 X Fujifilm X100F Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +8 more
Astrophotographer 10 Forum Pro • Posts: 10,680
Re: Making the switch to Fujifilm. Saying good bye to Canon (for now)...
I used a D800e and got an XE1. I found I used the XE1 more and more.
The main advantage of the Fuji is smaller size, vibrant colours and better white balance.
The main advantage of the Nikon was the usual FF advantages, better DR, better low light performance.
But with the latest X series that advantage is slowly eroded away but I find I have to keep an eye on DR as sometimes overexposed skies turn an ugly cyan which I dislike.
I never have to worry about that with a Sony A7r2. With a Canon their usual problem is shadow noise or banding. Fuji does not have that as its a Sony Exmor sensor.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony Alpha a7R II Sony Alpha a7R III Sony FE 55mm F1.8 Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +1 more
michaeladawson Forum Pro • Posts: 11,772
I have no regrets because I haven't made a total switch.  And probably won't for a long time.  The Fuji cameras are a joy to use.  I love them.  But they just don't do what my Nikon full frame bodies can do.
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Panasonic Lumix DMC-LX3 Nikon D200 Nikon D4 Nikon D800 Nikon D800E +23 more
lexvo Regular Member • Posts: 247
No regret at all
I switched from Canon FF + L-lenses three years ago, main reason was to have less weight and a compact setup. I have no regret I switched.
As for missing FF shallow DOF: well, I liked my fast lenses like the 135/2 but I often would stop them down a bit to get more DOF. So for me, no I don't miss shallow DOF.
What I certainly don't miss is micro focus adjustment. I've spent too many hours tuning AF. I think mirrorless AF is much more consistent in this regard.
 lexvo's gear list:lexvo's gear list
Canon EOS-1D Fujifilm X-T2 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +2 more
dv312
dv312 Veteran Member • Posts: 7,380
Left Nikon FF a few moons ago
At the time I missed the shallow DOF
With Fuji you can still do it but only with a few selected lenses
But after a while I tend to forget , especially since I don't do a lot of portraits
Noise wise I 'm satisfied with Fuji output
I don't usually push past ISO 6400
For sure I don't miss the larger bodies and heavier lenses, nor the clacking of the mirror, and the anemic live view
 dv312's gear list:dv312's gear list
Fujifilm X-T2 Fujifilm X-E3 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR Fujifilm XF 50-140mm F2.8 +2 more
Alfonso Bresciani
Alfonso Bresciani Senior Member • Posts: 1,795
I have been using 2 fuji  fuji x-t2 for about a year and I miss full frame, the noise at hig h( iso ) iso on a crop sensor is also atrocious! The Juji is a joy to operate and amazing to use, however  since I shoot a lot with low light,  (6400 to 12800 iso) i'm thinking on getting the sony a9 to try it out. I miss background separation and bokeh.
I haven't found noise at high ISO on my XT2 to be atrocious, actually very good, class leading.
A9 though seems to handle high ISO very well. Its also 3X the price but it is an amazing camera, I have only demoed it at a store and it felt fabulous and is so fast. It feels Pro.
Greg.
myfujilife
myfujilife Senior Member • Posts: 2,102
Switched from the D750. No regrets. I do find I need to use primes a little more for DOF, but in some respects I’m glad, because not lugging around a 70-200 has been a pleasure. My 90mm gives me amazing DOF.
https://www.instagram.com/theoverratedphotographer/
https://fujifilm-blog.com/2017/07/20/through-a-photographers-eye-athol-hill/
Fuji XT-2, Fuji X-E2, XF16-55mmF2.8 R LM WR, XF50-140mmF2.8 R LM OIS WR, XF23mmF2 R WR, XF35mmF2 R WR, XF90mmF2 R LM WR, XF60mm F2.4
 myfujilife's gear list:myfujilife's gear list
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H1 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 27mm F2.8 +12 more
