G12 problem
Started Aug 11, 2017 | Discussions
Mo Kwart
Mo Kwart Senior Member • Posts: 1,261
G12 problem
My daughter's Canon G12 has stopped producing usable images. The below photo is what she is getting. Anyone have any experience with this? Thanks in advance for your input.
 Mo Kwart's gear list:Mo Kwart's gear list
Fujifilm X-T1 Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R +4 more
Canon PowerShot G12
Geodude Contributing Member • Posts: 596
Re: G12 problem
Do you get the same image if you download the SD card as that on the LCD? Have you tried another/ new SD card out of interest?
 Geodude's gear list:Geodude's gear list
Panasonic Lumix DMC-FZ50 Canon PowerShot G1 X Canon PowerShot SX50 HS
Enders Shadow
Enders Shadow Veteran Member • Posts: 3,604
Re: G12 problem
If you go into the menu, is the display normal? You could try removing the SD card then check if LCD live view is still messed up. The G12 is a nice camera. Mine still gets regular use.
Phil
 Enders Shadow's gear list:Enders Shadow's gear list
Canon PowerShot G12 Olympus Tough TG-3 Fujifilm X30 Canon EOS 7D Mark II Nikon D500 +19 more
Mo Kwart
OP Mo Kwart Senior Member • Posts: 1,261
Re: G12 problem
My kids are on vacation and don't have access to a computer, but they do have a properly working G10 in addition to the faulty G12.
The menus look normal as well as the previous photos from before the problem.
They took the card out of the G12 and put it into the G10. The bad images were still there, but the card photographed and played back fine in the G10.
Upon returning the original card to the "faulty" G12 the camera bagan to work fine and still does. Sounds like either a loose connection or a bug/dust in the card slot. I suggested that they blow out the card slot, but not to have high hopes for not seeing the problem again.
Do bad SD cards ever act this way?
Re: G12 problem
That's a very odd but interesting fix! Perhaps the G10 reset the SD card? Is that possible?? Although doubt it because assume card not reformatted and just a photo was taken on the G10. As long as it continues to work I wouldn't worry! Sounds like a great outcome to me...
Mo Kwart
Re: G12 problem
No, not formatted in G10. Great outcome as they finished the trip with the G12 working. Thanks very much for the various ideas.
