How feasible would it be to 3d print a camera lens?
Started Aug 11, 2017 | Questions
MacM545 Regular Member • Posts: 323
I want to print my own lenses. Just how feasible would that be?!
 MacM545's gear list:MacM545's gear list
Sony RX100 II Canon EOS 500D Canon EF-S 18-55mm f/3.5-5.6
ProfHankD
ProfHankD Veteran Member • Posts: 6,171
Re: How feasible would it be to 3d print a camera lens?
Not very.
The best lenses I was able to directly 3D-print on my MakerGear M2 were able to form an image, but resolved maybe a few line pairs per mm -- a good lens should be 30-50.
Key issues:
  • Clarity of the material (e.g., "natural" PLA is often cloudy)
  • Presence of air gaps inside 100% filled structures
  • Insufficiently-precise basic shape (which can be refined by grinding, but then the lens isn't usable right off the printer)
  • Surface roughness (can be corrected by chemical, thermal, or abrasive polishing)
Beyond that, all you'd get then is one element with a very limited set of optical properties (index of refraction, dispersion) -- the lens elements aren't good enough to make multi-element optics.
On the other hand, 3D printing lens mounts, barrels, focus mechanisms, etc. is fairly easy and I do those all the time.
Canon PowerShot SX530 Olympus TG-860 Sony Alpha a7R II Canon EOS 5D Mark IV Sony a6500 +30 more
E Dinkla Senior Member • Posts: 1,394
Resin 3D printing must be the best approach I think. Fresnel lenses would be my goal first.
With a 10M $ budget like this local company got as an extra investment you might be able to do it on normal lens types;
https://www.luxexcel.com/
Met vriendelijke groet, Ernst
750+ inkjet paper white spectral plots: OBA content etc.
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm
ProfHankD
Sounds about right (although it shouldn't have cost that much to develop). There are still issues with resin in that you have a very limited range of mechanical and optical properties. Our nanotechnology center has been doing molecular-level 3D printing, and that could make awesome lenses, but not very big ones.
