Asking recommendation for 24-70mm f/2.8 on 5D IV under 1K
Started Aug 11, 2017 | Discussions
LSeries New Member • Posts: 10
Hello,
Beginner here, looking for a lens recommendation for 5D Mark IV that I am hoping to buy
Settled on a F/2.8 24-70 after giving a lot of thought pondering about the 25-70 f/4  and 24-105 f/4 versions
Per DXO Mark scores - are the below result -
Canon EF 24-70mm f/2.8L : DXO Mark 24 Sharpness 16MPX
( $850 Old )
Canon EF 28-70mm f/2.8L : DXO Mark 27 Sharpness 19MPX
($550 Old )
Tamron SP AF 28-75mm F/2.8 DXOMark 23 Sharpness 19MPX
($200 Old )
Tamron SP 24-70mm F2.8 DXOMark 30 Sharpness 21MPX
($850 Old )
Looking for a 24-70 F/2.8 Lens. I've been shooting the aps-c and found I tend to take most shots at that range ( around 40-70 ish of the full frame equivalent)
Not including the 24-70 mm f/2.8 L II as that is beyond my budget. ( as max I can spend is $1K). Not looking for a combination just a single lens that I can use to carry around.
Primary usage will be to use for (small family events - Indoor/outdoor), some low light ( camping ),  none of minimum video.
What I like most when looking at a picture most is Bokeh, Color saturation , Sharpness in that order.
The only other lens I have is the nifty fifty which sits right in the middle which I have found to use more than the 18-135 IS USM 3.5-5.6 that I have and would be selling off.
If there are any more info that might help you with your recommendation please let me know.
Canon EF 24-70mm f/2.8L USM Canon EOS 5D Mark IV Tamron SP 24-70mm F2.8 Di VC USD
rickpoole Senior Member • Posts: 1,241
Re: Asking recommendation for 24-70mm f/2.8 on 5D IV under 1K
Have you considered waiting on the new Tamron 24-70 f2.8 G2?  Tamron's marketing indicates it will be just as good as the Canon 24-70 f2.8 II but include a 5 stop IS.  It is only slightly over your budget ($1199 at most places).  It will be a month or so before review are out to see if it really lives up to its claims.  I was debating getting a 5D4 and the Sigma Art 24-70 but after reading Lens Rentals' review I decided to wait and see if the Tamron is better.
 rickpoole's gear list:rickpoole's gear list
Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +7 more
OP LSeries New Member • Posts: 10
Yes, I've thought about the Tamron 24-70 G2. However since this is essentially going to by my first actual expensive lens purchase  , I am thinking of buying something old/refurbished as I think that would give me more value for the money compared to buying something new.
As for Tamron ( current one in market ) I have seen sprinkles of comments as to how people has faced issues; had it not been the case I would have pulled the trigger on the current one but cannot quantify the risk of buying old and then having to pay additional if I get a bad copy that is not covered by warranty.
Thank you for the suggestion.
Tazz93
Tazz93 Veteran Member • Posts: 3,484
While I respect price sensitivity
Be careful when taking that approach. Buying two lenses a year and a half apart is more expensive in the long run.
Don't handicap yourself needlessly. Set your goals, stick to your goals, but be sure to reassess them when needed.
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
gavin
gavin Veteran Member • Posts: 8,242
I use the 24-70/2.8 I on my 5DII and now IV. it works fine.
 gavin's gear list:gavin's gear list
Sony RX100 III Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-85mm f/4-5.6 IS USM +5 more
BAK Forum Pro • Posts: 26,019
Priorities
RE > What I like most when looking at a picture most is Bokeh, Color saturation , Sharpness in that order. <
The fuzzy part of the picture counts the most?
Color depends far more on how the camera is set than on the brand of lens.
Anyway, bottom line: go buy a new Tamron 24 - 70 stabilized f2.8
It will work fine.
BAK
justlikeit Regular Member • Posts: 126
24-70 f2.8 mkI is a good lens. It's well made with metal parts. Even it is pre-owned, it will last long. I have this for over 15 years, still works like new.
 justlikeit's gear list:justlikeit's gear list
Canon EOS 6D Canon EF 50mm f/1.2L USM Canon EF 85mm F1.8 USM Canon EF 300mm f/2.8L IS USM Canon EF 24-70mm f/2.8L USM +5 more
Pedro Courelas
Pedro Courelas Regular Member • Posts: 195
One good copy of the Tamron 28-75 is awesome. Smal and very versatile sharp. And cheap.
