can EP5's built-in flash triggers optical slave ?
Started Aug 9, 2017 | Discussions
zzzxtreme
zzzxtreme Senior Member • Posts: 1,219
hi guys, does anyone know if the built-in flash of EP5 can trigger this thing if I stick this to the built-in flash ? some built-in flash is not powerful enough to trigger these. even 1mm close. Have a chance to get ep5 cheap, so I'd like to find out about this first. any help is greatly appreciated
 zzzxtreme's gear list:zzzxtreme's gear list
Pentax K-5
Olympus PEN E-P5
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
Re: can EP5's built-in flash triggers optical slave ?
Yes, it can but you will have to set it to Manual and adjust the power level otherwise you will trigger the slave with the pre-flashes.
Allan
hindesite Veteran Member • Posts: 4,893
I would think so:
I use these slaves:
They are capable of running very high voltage old flashes with no problems and seem quite sensitive.
I also use the built in optical trigger on my Nissin with no problems.
As others have said, you just have to avoid the pre-flash situation.
