G7 wifi issues
Started Aug 7, 2017 | Discussions
averagejoe576 Regular Member • Posts: 498
G7 wifi issues
Om vacation hoping for some quick help. I initiate the connection from the G7, I select the G7's ssid from the app, then after a brief wait I get a dialog on the G7,  "WiFi connection completed, if you  have not launched the app please launch it" my phone gives me a prompt "Searching or waiting the camera to transmit pictures". This is where I'm stuck, if I try to exit either I am not connected. Any ideas? I have tried a lot of settings, including disabling smart wifi connect on my phone.
 averagejoe576's gear list:averagejoe576's gear list
Fujifilm X100T Panasonic LX100 Panasonic Lumix DMC-G7 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
Re: G7 wifi issues
when you get that message, press cancel, takes you to the next screen where you press WIFI which takes you to  a screen of available connections including your camera, select that and that then takes you to the screen offering remote operation or transfer image.  The latter is also where to go if you want to view the images you have in the camera on your phone/tablet.
Recent and not so recent pictures here https://trevorc28a.wixsite.com/trevspics
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
OP averagejoe576 Regular Member • Posts: 498
Re: G7 wifi issues
Thanks for the reply. That sound like how I got there in the first place, I can cancel, hit wifi in the top of the "home" screen, pick my G7 and wind up back in same situation. However if found that if I goto the remote connection tab (adjacent the home tab) and hit the options then "set con. dest." from there I was able to get to work.
Re: G7 wifi issues
Actually maybe getting to work was a fluke, just tried a few times both ways and no luck, getting same two messages. Any more ideas?
Wasabi Bob Contributing Member • Posts: 680
Re: G7 wifi issues
Just curious - are you by chance using Android - on an older device still running Ver 4.x or 5.x? Both versions had a known bug that was corrected in 6.x The problem many had was that older and/or unlocked mobile devices did not get the Android update so the problem persisted.
Re: G7 wifi issues
Android 7.0
Here are the messages I described
This is what when the camera "connects". Hitting back exits wifi
This is if I goto "Set  Connec. Dest.", same message (different graphics) if I use the wifi icon at top left of home tab. It never progresses from this state. Hitting cancel leaves me disconnected
ethanejones1234 New Member • Posts: 1
Re: G7 wifi issues
I am using G7 service nearly a week, then I encountered a problem. To solve the matter I tried to reset network settings, but it did not give me the solution. Now, I find https://www.routertechnicalsupportnumbers.com/blog/netgear-a6210-not-detected/. Will the said solutions will help me out?
Re: G7 wifi issues
G7 would normally connect to your smart device (tablet or phone) - where is your router involved?
