NX30 Viewfinder Clarity
Started Aug 7, 2017 | Questions
BaldEgo Regular Member • Posts: 296
I just picked up a used NX30. When I was reviewing images today for this first time, I noticed that the images seemed much clearer on the rear display than on the EVF which really surprised me, given the higher resolution of the EVF. On all of the other cameras I've used, I've found the opposite. I tried adjusting the diopter but I couldn't get the EVF to display the same level of sharpness as I could get on the rear screen. Has anyone else experienced this issue? Im trying to determine if this is an issue with this particular copy or is a function of this camera model in general. Or, am I overlooking a setting in the set-up which might address the problem?
Samsung NX30
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 21,163
Well, they both have a different look...
Although my NX30 EVF is fairly sharp (considering its resolution), it does look a bit different than when looking at the LCD.  I noticed that right after I got it (got mine new).  I just accepted it and began shooting.  The NX30 is really a fine photographic instrument and I enjoy using it - that's for sure.  In the end, the IQ from that camera can put a smile on your face.
Sincerely,
Bernd ("Ben") Herrmann
Fuquay Varina, North Carolina USA
 Ben Herrmann's gear list:Ben Herrmann's gear list
Canon EOS M Fujifilm X-E2S Fujifilm X-T2 Fujifilm X-T20 Canon EOS M6 +4 more
Ben Herrmann
Let me add on to this...
Using the NX30 the other day I found that although the EVF is supposed to be a hi-rez version, it does indeed look a little pale (colorwise) when comparing it to the LCD which is brighter and richer in colors.  I think this has to do with the type of EVF it is, allowing it to be adjusted up and down and actually stretched (pulled) out.
Sincerely,
OP BaldEgo Regular Member • Posts: 296
Re: Let me add on to this...
Thanks Ben. I really appreciate the follow-up.
Chris62 Contributing Member • Posts: 693
For me rear screen is less sharp than EVF so when I want to evaluate the sharpness I look to EVF and magnifying the picture.
The problem of EVF is its optics - it is difficult to find right adjastment.
Or the center is sharp and sides not or opposite.
Colours can be adjusted in menu.
 Chris62's gear list:Chris62's gear list
Panasonic Lumix DMC-LX7 Samsung NX30 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +2 more
