EF 20mm f2.8 vs EF 24mm f2.8 IS vs EF 28 f1.8
Started Aug 7, 2017 | Discussions
Chen Guttman New Member • Posts: 6
Hi folks,
My question is regarding the three lenses listed above. My intended use is dual:
1. Use on an EOS 400D body for inconspicuous street photography - this is the primary intention.
2. Use of the lens on a full frame body (most probably 6D, yet to be purchased) for indoor low light photography, size is less of an issue here. This also means that EF-S or third party crop-only lens are out of the question.
Requirements:
1. Fast lens (at least f2.8)
2. Small as possible (preferably similar in size to the 50 mm f1.8 which I own)
3. Wide angle field of view up to effective 40mm (meaning 28mm lens on the 400D), preferably in the vicinity of effective 28-35mm.
4. Budget up to 700 USD.
I am inclining toward the 20 mm due to the effective FOV (32mm) - I can say that most of my shots in 2017 (40%) were at the effective 28mm (17mm on a 17-40L I have). My dilemma is regarding the lower IQ at the center of the 20mm (less of an issue for corners as I will be shooting street), size, and some extent vignetting (though I shoot RAW so can lens profile and fix it in LR). The 24 IS f2.8 has none of the above, smaller in form factor, but is a bit narrower in terms of angle of view (workable) as well as more expensive by roughly 140 USD. The 28 f1.8 will take me to the 44mm effective focal length, faster prime with a bit more shallower DOF, cheap as the 20mm but might be a bit tight for my liking. I can always go backward several steps, but the FOV difference can have a difference in terms of perspective and feel of depth.
I am wondering:
1. How were your experience with either lens for street photography? I am debating whether to comprmise FOV for image quality or vice versa.
Thank you in advance for the help!
Chen
 Chen Guttman's gear list:Chen Guttman's gear list
Canon EOS 20D Canon EOS 400D Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +3 more
Abu Mahendra Veteran Member • Posts: 5,312
Re: EF 20mm f2.8 vs EF 24mm f2.8 IS vs EF 28 f1.8
i say, go with the best of the lot, the EF35IS, and adjust to that focal length.
>> I'm already lovin' my Canon 35IS lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
the second choice would be clearly the 28IS.
Jura S Senior Member • Posts: 1,980
28/1.8 USM is very old lens. It lack sharpness, contrast and is very sensible to direct light.
Alan GT Regular Member • Posts: 337
Hi - why don't you just buy the ultra cheap EF-S 24 2.8 pancake lens for your 400D? You won't get any real image quality advantage on the 400D with the much more expensive EF 24 2.8 IS other than it having IS. The pancake is cheap enough not to worry about the fact that it is APS-C only, and you can easily sell it. If you upgrade to FF you could always get the similar EF 40mm pancake or as someone else sugggested the EF 35mm f2 IS.
Alan
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Alan
Ditto. HIts the bullseye on all your requirements:
Nothing is smaller, lighter, less conspicuous
I reject this out of hand. Buy lenses optimal for the camera system you have. You'll spend more for a suboptimal solution if you buy lenses for a camera you don't have.
Requirements:
Check.
Check, none smaller.
Check.
$150 USD retail, $120 from Canon USA Refurbished with free shipping (but add state sales tax) and same 1yr Canon USA warranty as new).
https://shop.usa.canon.com/shop/en/catalog/ef-s-24mm-f-28-stm-refurbished
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
charlieY Regular Member • Posts: 431
I have 28mm IS. Great lens. Almost L quality.
 charlieY's gear list:charlieY's gear list
Canon 6D Mark II Canon EF 70-300mm f/4-5.6L IS USM Carl Zeiss Planar T* 1,4/50 Tamron 35-150mm F2.8-4 Canon EOS M5 +1 more
arty H Senior Member • Posts: 1,546
If you want to shoot in low light, you need F2. The Canon 35F2 IS was my choice on crop and later on full frame. F2.8 may be a problem when lighting gets low, unless you are on full frame, but F2 is still desirable.
The older 28 may be sharp in the center, but you will need to stop down to get the corners OK, at least according to reviews. I would recommend the 35 F2 IS. It is an excellent lens for your needs. If you think you will be going full frame in 10 years, it might be silly to only buy full frame lenses. However, if you know what the time frame might be, and it is short, It is a different story and it makes sense to avoid putting lots of dough into crop lenses. If you are OK with F2.8 then don't rule out the new Canon 35 F2.8 macro lens.
For shooting in low light, I prefer at least F2. This way you can keep shutter speeds up for people photos. Fast AF is also a help, and you get that with the Canon 35.
Also, unless finances force it, you don't necessarily have to get rid of a crop camera and lenses when you go full frame. There are lots of times when I still use a crop body, since this gives me additional options with field of view.
OP Chen Guttman New Member • Posts: 6
Hi Abu Mahendra
Thank you for your reply. The 35 on a crop sensor will be ~56, way beyond the focal length I am looking for. So this is not an option.
Chen
Alan
Hi Alan
You've got something there. Since i will be using a FF in the coming month or two, I will want to have the 24mm handy for both bodies, thus i am opting for the 24mm.
The "sell later" aspect is not that attractive for me, I prefer to buy and keep. When selling equipment you loose money, no matter what you do.
Chen
Chen
Just in case of any confusion the 24 2.8 pancake lens I mentioned is EF-S mount and cannot be used on FF.  The 24 2.8 IS lens is EF mount and can be used on either FF or your 400D.
I find 24mm too wide for general street use on FF.  It is wider than you get with your 17-40 on the 400D.
Alan
Hi Arty,
Thanks for your comment. Your case is good for the 35. Reading your post I would say that my requirements priority would be:
FOV>Form factor>lens speed>Budget (on FF sensor)
The FOV of 35 is a bit too narrow (56mm equiv.) which is beyond my shooting style. Speed is indeed critical (also to have shallower DOF), however, I have less issue with shooting at ISO3200.
The 35 macro is actually EF-S and with that LED ring (even when turned off) it will be conspicuous.
Your comment, as well as the other members, helped me focus my intentions on the 24mm f/2.8. Thanks for the help and support!
Chen
Chen
Alan
Hi Alan,
Thanks for the clarification, that's the reason why either pancake lenses were on the list  - one is too long for street (my style) and the other is limited to crop only sensors.
Thank you for the support, it helped me select - I will go for the 24 f/2.8 lens.
Chen
snigs Regular Member • Posts: 153
I have used the 24 2.8 IS USM and the IS is fantastic and useful. It is small lens which has IS and USM.
In this shot, I had the shutter to 1/6 second to capture some movement
John Lennon Wall, Prague. Sony A7II + Canon 24 f/2.8 @ f/8, 1/6, ISO 50
Hi Snigs
Nice shot and impressive hands (with the IS)
I have noticed you use Sony body with Canon lens.
1. How it the compatibility with the adaptors? I understand AF is working but slower.
2. How is the transition to EVF instead of OVF? Is it that good? How's the operating time of the camera, that you have live view in the viewfinder?
Thx for the input,
Chen
Chen Guttman wrote:
https://www.flickr.com/gp/60652531@N00/929334
Hi Snigs
Thanks Chen - the canon IS + sony IBIS is really useful.
Yes, I don't have any native lenses, so cannot really compare.
Most of the modern lenses work with PDAF once I upgraded to software version 3.1 for the Sony. The AF is really quick and comparable/better than my Canon Rebel body (400D). The Fotodiox adapter is fine, but often I have seen that the adapter refuses to focus and either I manually help by bringing the focus near enough and then the adapter works, or reset the camera body. I think people have better experience with Metabones or Sigma adapter, but there is no option to update the software in Fotodiox.
The adapter does not AF with my Tamron 28-75/2.8 lens and that is a bummer. It is one of the sharpest 2.8 lenses that I have used (for the weight). Also it does not work with 50 1.8 II, 24 f/2.8 and 35 f/2 (older lenses).
The adapter does add a bit of bulk, but I find that it works fine with prime lenses (and fails with large 2.8 zooms as the camera + lens combination feels uncomfortable).
There is an odd flare that happens with this adapter (and most of this kind) when there is a light source just outside the frame - most likely internal reflections from the adapter - you can flock it yourself, or get the Metabones T adapters.
The adapter does not work at all for video and it hunts forever. But I don't shoot much video to begin with, so not much experience with that.
And you have to keep IS on and IBIS on for 5-axis stabilization. And there is no Eye-AF or DMF, or magnification for AF lenses in AF mode. . For that you need the big bucks for either native lenses, or Metabones adapters ... And I think that the USM makes more noise with the adapter than on a native Canon body.
This is phenomenal experience once you adapt to the EVF. It is nice, clear and bright, and sharp. Manual focusing in bright sunlight with older lenses is a breeze. If you use Loxia or other E-mount compatible manual lenses, it auto-enlarges on focus change. The peaking is not very accurate for fast lenses, but it is quick to magnify and then you can accurately focus. I have used it quite successfully with canon FD lenses, and I still use this with FD 135 f/3.5 lens
I have not noticed any particular lag in low light, but I tend to take my time (to the chagrin of my wife and daughter). Under very low light, the EVF is grainy, but AF works well enough to not worry in many cases. I don't think I will buy another camera that does not have a built in EVF. I am sold on the convenience, and the electronic level built into the EVF.
Thx for the input,
You are most welcome - regards Snigs
Chen
