G80 - horrendous unfixable moire?
Started Aug 6, 2017 | Discussions
Tony Collins Senior Member • Posts: 1,735
Yesterday for a friend, I took some pictures at their wedding "recreation" (Not a wedding, but a party for family who were not able to join them in florida)
For the first time in a year, I've had many shots ruined by moire problems. Here is one of the worst examples, showing before and after lightroom's adjustment brush moire tool (Just a rough/ready painting on - will have to be more precise later).
Does anyone have an alternate fix for this?
Fortunately I was doing this as a favour, and for free. If this is the best fix I can get then the G80/85 would be completely unsuitable for a pro wedding photographer - imagine explaining THAT to a paying client
Tony Collins
 Tony Collins's gear list:Tony Collins's gear list
Panasonic Lumix DMC-GF1 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Samyang 7.5mm F3.5 Fisheye Panasonic Leica 100-400mm F4.0-6.3 ASPH +1 more
Panasonic G85
epozar Senior Member • Posts: 1,094
Re: G80 - horrendous unfixable moire?
"Moire in not a big problem".. "easily fixable" ..
has a similar experience with female Black pantyhose for example. Or money in closeup.
 epozar's gear list:epozar's gear list
Olympus 40-150mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro
Paul80 Regular Member • Posts: 101
I wonder if that is the result of the G80/85 not having an Anti-aliasing filter
It gives a sharper image but can give Moire if the conditions are right, as it looks to be in your examples
 Paul80's gear list:Paul80's gear list
Panasonic Lumix DMC-G6 Panasonic G85 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +8 more
No wonder her.. it *IS* the result of no AA filter.
The very problem with most new cameras
Tom Axford Veteran Member • Posts: 6,629
Cameras need AA filters!
Horrendous moire is the result of the current ridiculous fashion for cameras with no AA filter!
Many people prefer cameras without AA filters because they produce sharper pictures, but completely forget that the price you pay is moire and other aliasing artifacts.
It is time for the camera manufacturers to return to making cameras with effective AA filters.
drj3 Veteran Member • Posts: 9,660
Re: Cameras need AA filters!
5
Maybe the Nikon D800/D800E solution, offer the camera with/without AA filter.  I photograph mostly wildlife and the people I photograph are rarely dressed in suits, so I have no desire for a camera with an AA filter.  I have seen moire maybe 10 times in over 300,000 images, so for me, not a problem.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +7 more
Jacques Cornell
Jacques Cornell Forum Pro • Posts: 12,041
Not unique to G80. Also, a simple fix.
15
I have encountered moiré on cameras both with and without AA filters. This is certainly not limited to the G80 or even to AA-filterless cameras. One way to avoid moiré when you encounter it while shooting is to slightly change the magnification of the subject in the frame, either by zooming or changing the distance. Moiré is an interference pattern that occurs when the spatial frequency of the detail matches the spatial frequency of the pixels on the sensor. Changing the distance or focal length changes this relationship and eliminates the moiré.
If you think digital is hard, try slide film.
http://jacquescornell.photography
http://happening.photos
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic Lumix DMC-LF1 Panasonic FZ1000 Panasonic LX100 Sony a7R II Panasonic Lumix DMC-GX8 +47 more
d3xmeister Veteran Member • Posts: 3,380
That looks horrible.
I'm not sure the AA filter or the lack of it would have made a big difference. There are some type of fabrics that will do that.
Some years ago I was shooting a wedding and the bride's mother had this outfit turned out photos just like yours. I was using a Nikon D3s, which have a strong AA, and a 24-70mm. We had a backup Nikon D80 (also strong AA filter) and a 18-55mm VR lens so I took that and shot wide open where the lens was pretty soft. Nothing work. In the end I realised I can somehow control the amount of moire by framing much tighter when this woman was in the frame, there was a point where moire was almost gone.
Based on this experience, and others, I think a AA filter would not have made much difference in your situation.
left eye
left eye Senior Member • Posts: 1,993
Try introducing aperture diffraction
There's been similar questions raised over in the MF forum in relation to the GFX50S.
Cameras with AA filters can reduce moire but they never eliminate it. On a tripod Pentax pixel-shift cameras (K-3II, K-1) can eliminate it, but require a static subject.
Fuji X-trans camera are a sure bet to reducing moire and 90% mostly eliminating it, due to their odd 3x3 RGB filer arrangement (as opposed to the standard bayer 2x2 grid).
In your case the only advice is stop the lens down so that diffraction kicks in, this acts in the same way as a AA filter, adding blur.
I suggest to try some test shots of a material that causes this problem, at f5.6 then quite stopped down, f11, f16 maybe even f22.
 left eye's gear list:left eye's gear list
Olympus E-300 Fujifilm GFX 50S Panasonic GH5 Fujifilm GF 50mm F3.5 +5 more
bsas
bsas Contributing Member • Posts: 619
I am curious if any photoshop guru here have a magic tip to remove it in post
 bsas's gear list:bsas's gear list
Sony Alpha NEX-7 Sony a7R Panasonic Lumix DMC-GX85 Sony a7R III Sony a7 III +13 more
left eye
As far as I know, colour rainbow moire yes - can be just about eliminated, but not luminance banding - this requires retouching.
Pete Berry Veteran Member • Posts: 3,560
I'm assuming that you're shooting 1080p since you didn't mention 4K. Minimal to absent moire is IMO the single biggest contribution of Panny's 4K implementation, as it can be seen from across the room when present.
Simply shoot 4K and put it on a 1080p timeline and 90% of your moire will be gone.
Pete
Hatstand Senior Member • Posts: 1,601
Fix, using Photoshop
19
Try this:
https://photographylife.com/how-to-remove-moire-in-photoshop
I did a quick and dirty attempt, see below.
The original version, for reference:
And the (quick and dirty) fixed version:
Fixed version
Sorry, I neglected to include parts of his jacket, at the left side of the image, in my selection area... but I couldn't be bothered to re-do. You may be able to do better with this method, if you take your time (which I didn't), and if you have the raw file (above link mentions using "down sampling process in Photoshop" with raw to get much better results)
Ideally, you should detect and avoid it at the time, as described by others above, and indeed - be aware that in can happen even on cameras with AA filters...!
It can also happen with layers of thin/translucent fabrics - where moire is visible to the human eye (ie. nothing to do with digitisation artifacts...!) it which case, the camera correctly captures the moire that you see with your own eyes!
left eye
Pete
Filming? - maybe I missed something; I think he's taking photographs as most of us do with cameras.
left eye
Re: Fix, using Photoshop
Hatstand wrote:
Try this:
Fixed version
good call !!!
I'm going to see if this actually works, if so, it's slightly time-consuming ...but valuable fix.
Pete
Well, you got me there, but never in 8 years of m4/3 - now GH4 and AA filter-less GH5 - have I seen moire like that.
And yes, I still do take still images in my feeble old age:
https://www.dpreview.com/members/2779399177/galleries
daddyo Forum Pro • Posts: 12,670
I feel your pain -- me too!
I just did a portrait session with a retiring county sheriff's officer. He had to turn in his uniform the next day and wanted a portrait for his aged mother. We did the shoot and all looked great until I uploaded the files and saw the horrible moire pattern on his shirt.
Fortunately, I was able to fix most of it fairly easily using the two step process linked to in one of the above responses.
Lesson learned! I was zooming in while shooting to make sure his face was in good focus, but did not scroll around the image -- had I, I would have seen the clearly obvious moire patterns on his shirt, and adjusted my crop and or aperture to eliminate it during the shoot.
I have so very rarely encountered moire in the past that it simply did not occur to me to check -- hopefully, I won't forget in the future.
A little over a year ago I did an indoor group portrait of 215 people for a company. Every thing went great except several of the shirts worn by some of the men in the group had those very small checkered patterns -- moire city! I was able to fix those pretty well and the time was worth it since the company ordered a bunch of large prints from that shoot -- but it was a pain, non the less.
P.S. The first camera company that figures out a very good in-camera fix when moire is detected will have a big selling point for portrait/event photographers. In lieu of that, hopefully someone will develop a sophisticated software fix that is very quick and simple to use.
God Bless,
Greg
www.imagismphotos.com
www.mccroskery.zenfolio.com
www.pbase.com/daddyo
 daddyo's gear list:daddyo's gear list
Olympus 12-40mm F2.8 Pro
Terrible Photographer
Terrible Photographer Regular Member • Posts: 481
bruh, do you even Capture One? This doesn't happen in that.
 Terrible Photographer's gear list:Terrible Photographer's gear list
Nikon D4 Nikon D800E Olympus E-M1 II Olympus OM-D E-M1X Nikon AF-S Nikkor 24-70mm f/2.8G ED +16 more
citizenlouie Contributing Member • Posts: 815
I don't like camera without AA filter either.  I don't mind sacrificing a little sharpness for the sake of moire reduction.  I was just thinking whether to get an E-M1 MKII to see if it has better tonality and rendering than E-M5 MKII (I used E-M1 MK1 before and it rendered tonality better, though not due to AA filter issue).  E-M5 MKII after the latest firmware, the over-sharpening effect is to the point of distasteful.
I took out of E-620, which of course has strong AA filter and "outdated" sensor, renders the tonality much better if lighting is not an issue.  I just wish camera companies stop this removing AA filter nonsense (fine tune AA filter, rather than removing it for cost saving, is the key).  Sharpness is only a small part of the entire photo's rendering, and it should be delegated to optics (e.g., lenses) for a more natural looking photo.
 citizenlouie's gear list:citizenlouie's gear list
Olympus E-620 Olympus E-5 Nikon Df Olympus OM-D E-M10 Olympus E-M5 II +14 more
OP Tony Collins Senior Member • Posts: 1,735
Yep, it's a still image, shot in raw. Both the lightroom processed raw, and the jpg show the same effect.
Shots of the same suit at different magnification (distance/focal length) still show some moire, but much more manageable.
Tony Collins
