Using EOS-M to copy slides/negatives
Started Jul 28, 2017 | Discussions
Gesture Forum Pro • Posts: 10,236
Would the new 28mm macro lens be practical for copying slides and negatives or is a longer focal length needed.  I guess I could get a regular Canon lens and buy the adapter.
Anyone doing this?
Thanks.
Andy01 Veteran Member • Posts: 5,188
Re: Using EOS-M to copy slides/negatives
Never tried with a camera, but copying negatives on a scanner requires a special LED light to backlight the negative (almost like a projector I suppose). I would doubt that front-lighting the negative would not work at all, but I might be wrong.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
Dreamscape Photo
Dreamscape Photo Contributing Member • Posts: 536
I just get my scanned by a proper lab. i tried with cameras and a crap cheap scanner but not good lol. some have done alright though.
Just go out and shoot photos!!!!
 Dreamscape Photo's gear list:Dreamscape Photo's gear list
Fujifilm FinePix S3 Pro Pentax K-x Pentax K-5 Canon PowerShot G5 Fujifilm FinePix S602Z Pro +10 more
jadphoto Contributing Member • Posts: 840
A macro lens will do it, but you're much better off with a film scanner.  As mentioned above, the slide/negative must be backlit.  Some flat bed scanners will do this with a film strip adapter but a dedicated film scanner produces much better results.
I use a Plustek Film Scanner I bought from B&H Photo years ago.  Works a treat.
JD
 jadphoto's gear list:jadphoto's gear list
Canon EF-M 55-200mm f/4.5-6.3 IS STM +1 more
adam8190 Junior Member • Posts: 42
Yes, I've copied 35mm negatives with the EF-M 28mm and my M5.  The original M would work well too.
Like you probably have, I read all the blog posts on the internet debating the merits of traditional film scanning vs using a digital camera.  I decided to try with my M5 and am happy with the results.
Here is what you'll need to mimic my set up:
- A tripod with the ability to turn the top column upside down or horizontal.  I was lucky that my old Manfrotto 190XPROB had this feature.
- A remote release for the camera
- A backlit surface to place the negatives on.  I'm using an Artograph Lightpad ($67 on Amazon)
- Plastic negative holders so they stay flat ($10 - $20)
- A small bullseye bubble level ($7) to ensure the camera is aligned with the negative
- A rocket air blower duster ($10)
Because I already had the tripod, remote release, and lens, this seemed like a better option for me than buying a scanner.  I set the 28mm in macro mode (super macro is not necessary).  I haven't tried 120 film yet, but see no reason why I won't get similar results.  I haven't tried slides.
You'll need to invert the image file in a photo editor on your computer - it's just one click in Affinity Photo.  I haven't tried inverting color negatives yet but don't expect major problems.
Here's a jpeg "scan" from the first roll of 35mm film I tried with this method.
RA40 Contributing Member • Posts: 706
If these are 35mm film images then a dedicated film scanner will be easier. I paid $274 on sale for a Plustek 8200i SE scanner. Has made getting the 35mm films scanned quite nice. You'll spend more to get a lens and adapter set-up and the dust issue will have you in post for hours. If you must then I have also tested a lens combo when a similar thread came up here. That thread is here:
https://www.dpreview.com/forums/post/59707274
Film scanner would be my recommendation.
Mike:)
 RA40's gear list:RA40's gear list
Canon PowerShot G6 Canon EOS M3 Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF 24-70mm f/2.8L USM +10 more
OP Gesture Forum Pro • Posts: 10,236
Thanks.
(unknown member) Senior Member • Posts: 1,232
I've used the M5 (could have been the M3 - I don't remember) to "scan" some odd sized negatives. I built a custom housing/fixture from an Amazon shipping box with one face replaced with a piece of white paper. I used wireless flash to fire a speedlight pointed at the paper so the negative was through-illuminated with diffuse, reasonably white light. Worked well for what I wanted to do. I used the 100mm macro with adapter but I don't see why the 28mm EF-S wouldn't work provided the math regarding subject size works out satisfactorily.
Funkyd3121 Senior Member • Posts: 1,683
I recommend a dedicated film scanner - been using a $410.00 Epson for about 7 years now.  Gets the job done.  The reason I went with this model(4990 - no longer made), I had medium format negs & chromes to scan as well.
 Funkyd3121's gear list:Funkyd3121's gear list
Canon PowerShot G7 Canon PowerShot G15 Canon EOS 30D Canon EOS 50D Canon EOS 300D +9 more
BrianPriceUK Contributing Member • Posts: 806
The main problem with scanners is the price and more importantly the time - neg scanning takes forever! Like Adam, I find using the camera much easier.
I've been using my old Canon 7D with the 60mm macro for copying negs, now I have an M5 and the 28mm and although I haven't used it yet, I'm sure it will work fine.
My new setup will be a copy stand - I've got one I bought second hand on Ebay years ago, but new ones are not expensive, with an A4 LED lightbox and enlarger negative carriers - again common on Ebay. I'll probably get a Z-type camera mount see
Copy Stand
Z-tpe stand
and use Camera Connect on my phone rather than a remote release.
Brian
Thanks.  As much as I enjoy scanning at times, it really isn't practical for translating hundreds of slides or BW negs to digital, so thanks for the info.  I'm thinking of seeing what my kit lens can do.  Then, consider investing in a 60mm EF lens and adapter.
Try it with a 52mm close-up filter kit
Brian
nahueljo New Member • Posts: 4
I just created an account just to thank you because looking at that photo result convinced me that this is the way to go for me. The scans from the lab are ok, but they are low res jpeg files that I think are even scanned a bit out of focus or with some softness applied.
So I'm going to buy this lens for my Canon M50 and build a scan setup. Thanks!
 nahueljo's gear list:nahueljo's gear list
Canon EOS M50 Sigma 30mm F1.4 (E/EF-M mounts) Sigma 56mm F1.4 DC DN | C (X-mount)
aeren Junior Member • Posts: 39
Dear Adam
Thanks for the information.
Recently, I've been reserching for digitalisation of negatives with camera. I have one question;
Your example photo seems little grainy to me. Since I don't have o experiace I wonder. Is it normal for process, or is it lighting isssue? What do you think?
 aeren's gear list:aeren's gear list
Canon PowerShot SX120 IS Canon EOS 80D Canon EOS M5 Canon EF 70-200mm F2.8L IS II USM Tamron SP 24-70mm F2.8 Di VC USD +4 more
R2D2 Forum Pro • Posts: 26,530
Dedicated scanners typically have a very deep depth of field. The softness comes from the “dust-removal” software that they get run through afterwards.
Do a test run at a number of labs to see which suits you best.
A DIY setup can be as simple or complex as you want. Do avoid the (numerous) pitfalls. And be prepared to spend copious amounts of time in post, even with good software (such as Silverfast).
Biggest tip: Get your negs/slides as DUST-FREE as possible!  Avoid scratching!
Best of luck!
R2
aeren wrote:
Dear Adam
It appears to be the original film grain.
R2
Dareshooter Veteran Member • Posts: 5,842
R2D2 wrote:
aeren wrote:
Dear Adam
R2
Indeed so Adams set up did it's job getting right down to the grain which IMHO looks quite attractive. I think we have become spoiled today and as a former slide shooter I avoided shooting anything over ISO 100 wherever possible. ISO 200 if I really had no choice. ISO 400 meant putting the camera back in the bag , shrugging my shoulders and thinking oh well not meant to be  today but tomorrow, who knows ?
Yes I’m always able to see the grain and can tell the difference between different film stocks when I look carefully.
I’m still using a similar set up, except I upgraded to a copy stand and 35mm film holder from Negative Supply. No difference in the quality of the scans, but it sped up my process and saves me time.
Best of luck!
R2
Thanks!
I got my lens today and did some test scans to compare with the scans from the lab. So far, I'm very happy! here's a test comparison, with some zoom:
Hopefully you're able to tell which one is which lol
Left is mine, right is the lab. In mine I see the grain is a lot "finer" and subtle, plus a lot better tonal range I think?
I scanned a few color ones and the result is not as good as the lab. Color needs a lot more post-processing and my DYI setup is lacking something to hold the negative flat on the light bed. Right not I have a cheap (but very bright) LED panel with cardboard cutout to block the light outside the frame of the image (poorly...) and my canon m50 on a tripod.
And yes, dust is your works enemy 🤣
Larry Rexley Senior Member • Posts: 1,238
Best of luck!
R2
Thanks!
Very interesting! Good result.
I have a lot of my Dad's old Kodachrome slides. I transferred about 10 boxes of slides so far. I used the M6 mark ii and Canon EF-S 55-250 IS STM with an extension tube, in a dark room the slides about 3-4 feet away from the lens, behind the slides was a piece of white paper lit by 2 3000k LED work lights.
This worked very well for me --- as I could use my standard workflow using DxO Photolab to process the results quickly. DxO excels at white balancing, adjusting colors and tones, contrast --- but it's best attribute is its ability to sharpen and de-noise. I was able to bring the grain to the level where you just see a hint of it.
I have tried quite a few film scanners and like you found them FAR too slow to make doing more than just a handful of slides or negatives very painful.
I just got the EF-M 28mm macro a month ago --- based on your results I am going to try that next! I think I will try putting a bunch of empty filter rings, and then some 'step-up' rings (I have a full set stepping up from 49mm to 82mm with many rings) to see if 35mm slides will 'fit' in one of the rings.... I'll try to make a make-shift slide adapter at the right distance to fill the frame with a slide.
I'll report back how it goes.
Here's a sample from my 55-250 work... a slide of me holding a kitten at the age of 8! The film was badly faded but I was able to get some color out of it.  It might not have even been done with DxO.... at any rate my post-processing skills are far better now and I'm sure I could do much better with the latest DxO PL!
 Larry Rexley's gear list:Larry Rexley's gear list
Canon EOS M6 II Canon EOS M200 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +21 more
