E-M5 II Hi-Res vs E-M1 II Hi-Res image IQ.. What are the differences?
Started Jul 26, 2017 | Discussions
Impulses Forum Pro • Posts: 10,039
Re: Don is right. I got it wrong.
Peter 1745 wrote:
Donald B wrote:
TomFid wrote:
Donald B wrote:
Peter 1745 wrote:
HiRes mode uses electronic shutter. In the E-M5ii the maximum shutter speed is 1/20sec and in the E-M1ii is 1/50sec (slightly lower at high ISO).
your information is totally wrong . hi res only uses the lower shutter speed for FLASH photography.
I think he's referring to the readout speed, not the shutter speed. But since multiple exposures are combined over multiple readouts, it's not a bad approximation. A high shutter speed would just make sharp artifacts.
No hes quoting the flash sync speeds for both cameras when using electronic shutter.
Don
I use HiRes mode in macro work where I use flash as my light source and have the restricted sync speeds I mentioned.
In general photography without flash HiRes mode has no such limitation. I forgot this when I posted above. Sorry for any confusion I caused.
High Res is still using the e-shutter tho, so regardless of what the shutter speed is the readout speed limitation is still there...
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
